Russell Speed Bleeders installed.... - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Like Tree4Likes
Thread: Russell Speed Bleeders installed....
  1. #16
    Veteran Member 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,443
    Liked
    229 times
    Images
    14
    Rep Power
    12376
    Thread Starter
    Default Re: Russell Speed Bleeders installed....
    i just looked and the pro-valve bleeder looks to be the same size as the front brake bleeders. definately smaller than the rear bleeders...... hmmm.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,666
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    so what did you end up with?
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  4. #18
    Join Date
    Sep 2009
    Location
    Posts
    1,443
    Liked
    229 times
    Images
    14
    Rep Power
    12376
    Thread Starter
    still there as is. went to inspect a low rear tire and got out the soapy spray, took the rim off and got the compressor out. plugged in the compressor and the #%$^&*@#* valve stem is leaking! %$#&. how does that happen? it's the 4th one in like 4 years.......
  5. #19
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,110
    Liked
    2027 times
    Images
    47
    Rep Power
    121449
    Based on the above reference from speedbleeder.com, the 2003 and later 13WL calipers use the 7mm x 1.0 Russell Speed Bleeder, part #639570. The rear drums continue to use the 10mm x 1.0, part #639560.
    Salty_Dog likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #20
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,666
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    holy follow-up batman!
  7. #21
    Join Date
    Sep 2009
    Location
    Posts
    1,443
    Liked
    229 times
    Images
    14
    Rep Power
    12376
    Thread Starter
    thanks for digging the info up and closing out this thread.
  8. #22
    Junior Member p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind. p-car-tower is a pinnacle in their own mind.
    Join Date
    Sep 2006
    Location
    Germantown, MD
    Posts
    271
    Liked
    20 times
    Images
    1
    Rep Power
    1335
    Quote Originally Posted by jack mccarthy View Post
    I've read that the speed bleeders tend to wear out quickly and don't seal properly after several bleedings. Just what I've read from a couple other general forums, so I decided to go with the original.
    I've had them on my race for for ~8 years now (8 bleeders in total) and bleed ~4 times per year. No problems with any of them sealing.
    I wouldn't hesitate to put them on my other vehicles if I bled their brakes a lot.
    Jerome
    '06 Tundra AC Ltd 4x2 - Phantom Gray
    '89 Porsche 944 Turbo (track car / wallet deflator)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
