Towing
+ Reply to Thread
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By Highwaylizard
  • 1 Post By tundra3400
Thread: Towing
  1. #1
    Rookie sab26az is on a distinguished road.
    Join Date
    Jun 2012
    Location
    Arizona
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default Towing
    I have a 2004 Toyota Tundra DC and was adivsed of a towing problem involving the transmission. My mechanic told me that there was a technical service bulletin reference some part in the transmission that cannot handle a load of more than 3500 lbs if I plan on towing said load regularly. I cannot find anything about this for myself. The repair is going to cost a little over 900 dollars.
    Has anyone heard of this or am I getting ripped off.
    I will try to get more info on what the specific part in the transmission is for more info. I want to say it was an output shaft but am not 100% sure.
    Ohh and the reason I ask I because I am looking to purchase a travel trailer and want to make sure that I can tow it. Its gvw is 3850lbs.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member tuggajb is on a distinguished road.
    Join Date
    Feb 2011
    Location
    az
    Posts
    21
    Liked
    2 times
    Rep Power
    3
    The trans problem was for 00 02 late have changed the part early 03
    Sent from my Autoguide iPad app
  4. #3
    Supporter pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712 has a criminal record for giving away rep points. pirates712's Avatar
    Join Date
    May 2009
    Location
    New York
    Posts
    937
    Liked
    35 times
    Rep Power
    8383
    Default Re: Towing
    I believe the problem involves some kind of bearings in the overdrive (4th) gear. Just turn off overdrive while towing.
    712
  5. #4
    Random Poster Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold.
    Join Date
    Jul 2004
    Location
    South Glens Falls ,NY
    Age
    41
    Posts
    321
    Liked
    9 times
    Rep Power
    19
    Default Re: Towing
    I would have that mechanic dig up the TSB before going through with that repair. Like Tugga said , I think that was pre '04.
  6. #5
    Beer Me ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra's Avatar
    Join Date
    Feb 2008
    Location
    Central California
    Age
    25
    Posts
    1,636
    Liked
    353 times
    Images
    57
    Rep Power
    22264
    Default Re: Towing
    never had a problem when towing our boat with my tundra. and its over 3500
    Jason
    It's got 4 wheels with a bed and it starts every time I turn the key.
    If You seek advice, then LISTEN with your EARS not your MOUTH.....
  7. #6
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,373
    Liked
    1296 times
    Blog Entries
    78
    Images
    65
    Rep Power
    175260
    Default Re: Towing
    I used to own and operate a landscaping business and a tree service and used my 2004 DC to tow all kinds of loads WAY over-gross without a single problem. Always tow with over drive off and you should not have any problems.
    Your mechanic is incorrect in his advice and I second the motion for production of the TSB regarding this "issue."
    Hippo likes this.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  8. #7
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,103
    Liked
    172 times
    Images
    27
    Rep Power
    6289
    Default Re: Towing
    yea the issue with the trans was for 00 to 02 and i believe it involved the Torrington bearing cages that are a part of Overdrive and they would come apart and chew up the rest of the trans. But this shouldn't affect your truck.
    oofy15354 likes this.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  9. #8
    Join Date
    Jun 2012
    Location
    Arizona
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: Towing
    Thank you all very much for your advice. I looked all over the web and could not find that TSB for the I will be asking for a copy before doing any repairs.
  10. #9
    Lurking Member ChrisA will become famous soon enough. ChrisA will become famous soon enough. ChrisA will become famous soon enough. ChrisA will become famous soon enough. ChrisA will become famous soon enough. ChrisA will become famous soon enough. ChrisA will become famous soon enough.
    Join Date
    Jan 2007
    Location
    Richmond, VA
    Posts
    46
    Liked
    3 times
    Rep Power
    10
    Default Re: Towing
    Quote Originally Posted by tundra3400 View Post
    I have an 2000 that I tow my race car with, the car and trailer are 5000-lbs plus a loaded truck bed. I turn off Over-drive when I tow. Should I still have concern? Would rather get a more capable tow vehicle than drop $900 into this one. It seems to do okay when towing in general, but it does struggle a good bit when traversing mountains.
    Chris
    '00 Tundra Access TRD 4x4
    '99 SpecMiata #190
    Do it no matter what. If you believe in it, it is something very honorable. If somebody around you or your family does not understand it, then that's their problem. But if you do have a passion, an honest passion, just do it.
    - Mario Andretti
  11. #10
    Fellow Tundra Owner RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch has done just about everything...and then some. RitcheyRch's Avatar
    Join Date
    Aug 2002
    Location
    Santa Clarita
    Posts
    1,720
    Liked
    19 times
    Images
    2
    Rep Power
    1068
    Default Re: Towing
    Thankfully, I havent had any issues with my '02 Tundra towing my boat either.
    Quote Originally Posted by ZapcoTundra View Post
  12. #11
    Join Date
    Jun 2012
    Location
    Arizona
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: Towing
    I have contacted the mechanic on this and am waiting a reply...I will let you know what I hear. The local dealership advisor said he didn't know of any TSB relating to this but did not instill the most confidence with his answer.
  13. #12
    Lurking Member w4glm is on a distinguished road.
    Join Date
    Mar 2008
    Location
    country
    Posts
    23
    Liked
    8 times
    Rep Power
    6
    Default Re: Towing
    Good advice - Turning off O/D when towing.
    My Tundra an 01 has the V-6 engine, I live in the country and tow a heavy trailer with large round hay bales,
    been doing it since I bought it and always turn off the O/D when hauling anything
  14. #13
    Veteran Member oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354's Avatar
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    20
    Posts
    1,351
    Liked
    261 times
    Images
    21
    Rep Power
    11089
    Default Re: Towing
    If you turn of the OD, you should be fine
    2001 Black AC V8 4x4
    Current Mods: TrailFX Tube Steps, Uniden CB Radio with PA, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Plastidip Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front AUX lights, JVC Headunit, Kicker Front Components, Pioneer Rear Speakers, Magnefine Filter, Viper Remote Start, Single in-Dual out 2.25in Exhaust
    Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Exhaust Leaks
    To Do: Diff Fluid, Kenwood DDX419, 5100s Front and Rear set to 1in, Diff Drop, Poly Rack Bushings
    Quote Originally Posted by italiantundra88 View Post
    dave, every one has a weekness, yours is just any work on your truck
Posting Permissions
  • You may not post replies
  • You may not edit your posts
