Question Transmission Problem?
+ Reply to Thread
Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By Remmy700P
  • 1 Post By KentJ
Thread: Transmission Problem?
  1. #1
    Lurking Member Tundra06DC is on a distinguished road.
    Join Date
    Mar 2009
    Location
    Iowa
    Posts
    27
    Liked
    0 times
    Rep Power
    5
    Default Transmission Problem?
    A few times when I have braked to a hard stop there is a delayed, hard THUNK in the drive train. The first time this happed I looked in the rear view mirror to see if someone had rear-ended me. Yesterday on the way to work I had to brake hard to avoid running a stop light and the same thing occurred. While accelerating after the light turned the truck was slow as if it was in a low gear, but the rpms weren't climbing much. Further down the road there was a rough shift and things returned to normal. The sluggish acceleration and abnormal shift occurred again on the same trip after a normal stop (no thunk). Everything seemed normal on the trip home after work.
    Has anyone else experienced these symptoms? If there is a problem with the transmission I would like to get it repaired while it is still on warranty. My 06 doublecab has around 63K miles on it. The transmission fluid was flushed at 55k.
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,174
    Liked
    2091 times
    Images
    47
    Rep Power
    126643
    Default Re: Transmission Problem?
    I would do the following:
    1. Treat the ATF with Auto-Rx (Auto-Rx for transmissions)
    2. Check torque on the four rear transmission mount bolts
    3. Check operation of e-brake bellcranks
    4. Lube driveshaft (if 4WD)
    5. Drain/fill rear differential
    6. Check torque on rear leaf spring u-bolt mounting nuts (98 ft/lbs)
    arseum and tundra3400 like this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  3. #3
    Veteran Member 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    #4 for sure.
  4. #4
    Supporter SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,763
    Liked
    924 times
    Images
    24
    Rep Power
    26125
    ^ i'm with this guy.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  5. #5
    Junior Member bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind. bgeorge is a pinnacle in their own mind.
    Join Date
    Dec 2004
    Location
    MASS
    Posts
    144
    Liked
    20 times
    Blog Entries
    1
    Rep Power
    1593
    I have an 05 AC which had transmission problems due to two corroded pins in the 15 pin connector that is connected to the wires coming out of the transmission. We have snow and salt here in New England. It seems that the connector does not have dielectric grease packed in the connector from the factory.
    Along with all of the above I would unplug the connector and take a good look at the pins then pack it with grease if it is Ok when you put it back together. If there are any pins corroded or broken off, looks like a dealer job.
    Do a search for lubing the drive shaft. It involves a lot of grease with 8 spots (with 4x4) and lots of grease in the last one (back). There are a lot of posts about feeling a bump when stopped and this stops it.
  6. #6
    Rookie hobbes1956 is on a distinguished road.
    Join Date
    Jun 2005
    Location
    tallmadge, oh
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I live in NE Ohio with an '05 also with corrosion on electrical pins at connector to transmission. 3 corroded for sure and 1 broken off. Crappy type connector with no dielectric grease for protection. It's in an AAMCO shop today (11/13/2012) being repaired, approx. $400.00. Replacement connector hooked to transmission costs about $80.00 with the rest for labor/supplies. I suggested replacing the cable connector (female plug part) also but service guy said entire electrical harness would need replaced and was about $1000.00! He feels confident he can clean and reuse old one...we'll see.
  7. #7
    Join Date
    Dec 2004
    Location
    MASS
    Posts
    144
    Liked
    20 times
    Blog Entries
    1
    Rep Power
    1593
    How did you find out it was the pins? I brought it to the dealer and they wanted to replace the transmission for 3K. I was not happy and took it to the local transmission shop where they found the problem. I also found it on the internet. It cost me the $400.00 also. I wrote and called Toyota with no response from them. I asked for my money back from the dealer for finding the wrong problem and wanting to charge me for a new transmission. They refused.
  8. #8
    Veteran Member tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    9693
    Quote Originally Posted by bgeorge View Post
    thats why i dont like dealerships!
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 198,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  9. #9
    Lurking Member KentJ is on a distinguished road. KentJ's Avatar
    Join Date
    May 2011
    Location
    Vancouver
    Posts
    24
    Liked
    2 times
    Rep Power
    3
    This sounds very similar to what my tranny was doing. Any time I slammed on the brakes it would slam back into gear after a few second pause. It felt like I was being hit from behind. If I tried to accelerate while it was doing that it would rev up and slam back into gear, like a neutral drop. Chirped the tires, big clunk, not good. My truck is an '06 as well.
    I also had a couple times where there was no power afterwards, it seemed to me like it was stuck in 3rd gear and wouldn't downshift. The engine did its best to load up the torque converter but of course the RPMs wouldn't get very high and acceleration was slow. The engine was also working like hell to overcome the high gearing. Turning the truck off/on made it go away.
    The short of it was the tranny was slightly low on fluid, so as the fluid sloshed to the front of the pan, the pickup would gulp in some air. Of course that caused a brief drop in hydraulic pressure so the clutches etc released, immediately engaging again when the pressure was back on, causing the clunk.
    The long story is I had it checked out by a mechanics instructor at my work (I work at a college with automotive programs). It was holding a pending error code, DTC 2714, regading one of the shift solenoids. I bought the parts and had them replaced, free labour.
    The problem was worse after that, it was happening with any quick stops (not just panic stops like before) but also did it in tight turns and when gunning it in reverse (backing up a steep driveway). I took the truck to a reputable Trans mechanic and he quickly spotted the low fluid. He added 2.5 litres and it's been fine ever since, about 6 months now. Only charged me 1 hour labour as I provided the fluid (the fluid that should have gone in when the solenoid was replaced). He could have ripped me off but lucky for me he's a good guy.
    I thought the fluid might be low from the start, and let the automotive guys check that for me. They thought it was OK but they were wrong. When they opened the check plug on the trans a little fluid came out like it's supposed to. But I think the tube (see picture) filled with fluid as the truck drove around, so all that came out was the contents of the tube. They mistook that to mean the level was set properly.
    Worth checking out.
    -Kent
    Remmy700P likes this.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
