rear end noise?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree4Likes
Thread: rear end noise?
  1. #1
    Join Date
    Dec 2011
    Location
    Hemet
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Default rear end noise?
    Has anybody experienced a kind of wop, wop, wop noise from the rear end? It starts around 30mph and doesnt change while accelerating or decelerating. It doesnt change in neutral or while applying the brakes.
    2002 AC with 265/70/18s
    Thanks for any feedback...
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,331
    Liked
    3126 times
    Images
    47
    Rep Power
    162921
    Default Re: rear end noise?
    Tires.
    tundra3400 likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Dec 2011
    Location
    Hemet
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Nope...I have replaced my tires about 15k miles ago and still have the noise...I have rotated the tires several times and again..I still have the noise.
    Could it be the rear wheel bearings?
  5. #4
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,331
    Liked
    3126 times
    Images
    47
    Rep Power
    162921
    It could be a bearing. It could be a bent rear drum backing plate rubbing. Hard to tell over the interweb you know?!??
  6. #5
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,534
    Liked
    2605 times
    Rep Power
    235827
    Is it a wop wop wop or a woom woom woom? The later could be a rear end going out.
    280,318 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Fitch Fuel Catalyst, Long Tubes and true duals with twin Aero Turbines, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the frontand rear differentials, Cooper Discoveer ATP tires
  7. #6
    Supercharged Member Jonesy's Avatar
    Join Date
    Oct 2009
    Location
    San Diego Bay Area
    Posts
    3,583
    Liked
    4347 times
    Images
    37
    Rep Power
    81060
    Quote Originally Posted by Remmy700P View Post
    Sign me up for a bearing. Jack the rear tires off the ground and see if you can find any movement/looseness when wiggling the wheel. Slip the transmission into neutral and rotate the wheels. Look for anything rough or gravely and listen for any noise that's out of the ordinary. Even if you don't find anything loose it still could be the wheel bearing. Just my two cents worth.
    2005 4.7L~RCLB~LSD~DSM~2 WD~Cold Weather Package~Towing Package
    Flowmaster American Thunder Cat Back~
    Retrax Pro Bed Cover
    Bed Mat~Split Spoke Alloy Wheels~BAK Bed Rail Covers
    32K Miles & Counting
  8. #7
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,587
    Liked
    1000 times
    Images
    38
    Rep Power
    44364
    yea but when a bearing goes bad it usually gets louder the faster it rotates. the way the OP stated it, the noise is the same after 30 MPH.
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 214,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s
    CBTMA Member
    Sometime in the Future:
    3" LED flood cubes, 4" LED hyperspot Pods
  9. #8
    Join Date
    Dec 2011
    Location
    Hemet
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    your right highwaylizard it is more of a woom, woom.. if its the rear end will I see shavings or anything?
    @ Tundra 3400 the noise picks up with speed to a point, but ya, not until 30 or so
  10. #9
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,587
    Liked
    1000 times
    Images
    38
    Rep Power
    44364
    Quote Originally Posted by pvpct View Post
    oh ok yea you didnt mention that in the OP. i would say that its a bearing then.
    CBTMA Member
  11. #10
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,534
    Liked
    2605 times
    Rep Power
    235827
    Do a shot drain of the differential oil. Clean the area around the fill bolt and loosen it. Remove it and using a clean Styrofoam cup, run a shot of differential oil into the cup and then put the plug back in. If it is silvery or has flakes in it then you know the rest of the sad story.
  12. #11
    Join Date
    Nov 2005
    Location
    Mesa, AZ
    Age
    45
    Posts
    154
    Liked
    1 times
    Rep Power
    10
    X2 on a bearing, although I wouldn't rule out a bent axle shaft. Is your truck always empty? Does the noise change if you are carrying a load?
    Get Your 90915-20004 Oil Filters Here
    Want a Case of Them?
    Want OEM parts but don't want to pay retail? I sell most OEM parts at 25% off list. Just send me a PM and tell me what you're looking for.
  13. #12
    Lurking Member Built_Not_Bought's Avatar
    Join Date
    Oct 2008
    Location
    Bay City, MI
    Posts
    30
    Liked
    0 times
    Images
    4
    Rep Power
    7
    Have same noise as OP with my 06 had it for a long time, got truck with 39k on it now have 72k still makes same noise. Drives me crazy. Replaced a wheel bearing nothing changed. Thinking it is carrier bearing or maybe rear lsd / carrier.
    Let me know if you fixed the problem.
  14. #13
    Join Date
    May 2012
    Location
    Buena Park
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Here is how I normally check for rear noise. Jack up rear wheel put jack stand on both sides. Put it in drive let it spin the wheel you can probably here where is that noise coming from
  15. #14
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,327
    Liked
    2726 times
    Images
    216
    Rep Power
    255659
    If it's more of a whhhoooof noise I'd say watch what you eat.
    The rear end could be going out, mine made a similar noise for over a year and eventually it got louder/more pronounced. It eventually got to a point where when I decelerated it made a whirring noise and sometimes a noise that sounded like I had empty cans bouncing around in my bed. Even more eventually, my rear end locked up a few times while driving from a stop... yikes. I put the rear axle up on jack stands, put blocks in front of the front tires, put it in drive and went behind to listen. I was angry to hear the thump thump thump of my blown out rear end, but it had to go sometime. There is a pin in the carrier that came out, wedging itself between ring and pinion, it destroyed everything.
    Good luck.
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  16. #15
    Veteran Member CoachRon's Avatar
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    25
    Posts
    566
    Liked
    67 times
    Images
    26
    Rep Power
    6591
    I have a "whoom whoom whoom" at speed, but haven't figured out if it's my new tires or my rear end yet. My diff fluid is pretty metallic for having changed it only 15k miles ago, but not any more metallic than what a regular oil change looks like. It was super nasty when I did change it though. Probably the first change it ever had, around 85k miles.
    What kind of life span (in miles) does a rear end have once it starts making noise?
    tundrunk, I remember reading a while back about your dilemma, but can't remember the details. What kind of price am I looking at if my rear end eventually goes out?
    2000 Tundra SR5 2WD... Camburg UCAs, Camburg 2.5" coil-overs, Deaver 10-packs, Bilstein 5100s, Moog LBJs, BFG A/T 285/75/16s, TRD bead-lock wheels, K&N air filter, 18" MagnaFlow muffler, clear corners, Sylvania fog/headlights, full LED conversion, Kenwood head unit & 6-3/4" 3-way speakers, Sound Ordnance B-8PT 8" subwoofer, Coverking neoprene seat covers... so far...
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
