Question Another DRL question
+ Reply to Thread
Results 1 to 6 of 6
Thread: Another DRL question
  1. #1
    Rookie blks14 is on a distinguished road.
    Join Date
    Aug 2012
    Location
    OC
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Another DRL question
    Hi all,
    I have a 2004 DC sr5. I have searched up and down the forum on how to disable the DRLS. Apparently there should be a relay/mod i can unplug between the batt and fender. I can not find it. Please see the pic of my engine bay and correct me if im looking in the wrong place. Any help would be greatly appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    Default Re: Another DRL question
    In the picture you posted there is a gray harness plug in the top right corner of the pic right where the sunlight is shining. That is the plug for the drl resistor. Unplug it and tape up the ends to keep dirt out of them. If you remove the battery it will be easier to get to.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 196,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch, 5000K 35 Watt HID Fog Lights
  4. #3
    Veteran Member marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest is almost part of the TundraSolutions family. marvbest's Avatar
    Join Date
    Aug 2004
    Location
    Las Vegas, NV
    Posts
    772
    Liked
    215 times
    Rep Power
    5641
    While you have the battery out you should also clean the battery posts with a battery post wire brush and the cable connectors with baking soda disolved in water. Auto parts stores sell anti-corrosion washers (pack of 2 with one green and one red) that you should put on the battery posts (red on positive, green on negative). Those washers will minimize or eliminate future corrosion.
    "You can lead a smart-ass kid to knowledge, but you can be sure that he'll have to argue with the facts"
  5. #4
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,026
    Liked
    292 times
    Rep Power
    11256
    Not sure this will help, as its for a '00, but....
    TSB – EL011-00 2000 Tundra Daytime Running Light Disabling Procedure.pdf
  6. #5
    Join Date
    Aug 2012
    Location
    OC
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks soooo much...... All this time I was looking for a relay i didn't think it was that resistor.
  7. #6
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    your welcome. it was the first mod i did on my truck. i couldnt stand the DRLs.
    CBTMA Member
Posting Permissions
  • You may not post replies
  • You may not edit your posts
