New wheels and rubbers, maybe
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree11Likes
Thread: New wheels and rubbers, maybe
  1. #1
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    Default New wheels and rubbers, maybe
    well i know ill need new tires soon down the road so i was kicking around the idea of 265/75r16. looking on here ive seen some trucks with the FJ cruiser 17 inch rims and i like them. i know this topic has been talked about a lot and i have searched a lot but it doesnt fit exactly to what im looking for with my truck. i have the 5100 set at the 3rd notch(~1.5 inch lift) on my 2000 v6 4x4 AC and was wondering with the FJ rims could i go to 285/70/17 and have no issues with rubbing anywhere. i also dont want to use wheel spacers.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 196,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch, 5000K 35 Watt HID Fog Lights
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    Default Re: New wheels and rubbers, maybe
    No. You will rub somewhere.
    I will make no recommendations on which rubbers to get. That's between you and your gf, sheep, etc.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #3
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    334
    Liked
    172 times
    Rep Power
    5076
    I run 265/75r16 on stock suspension no probs. It's only about a 1/2" bigger than 265/70/r16.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
  5. #4
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    Thread Starter
    Quote Originally Posted by UPbuilder View Post
    yes i no they work. i like those 17 in rims but it seems like i can only get 265/70r17s which is the same size as 265/75r16. so i guess it would not be worth the money on new rims.
    o well thanks for the replies though guys.
    CBTMA Member
  6. #5
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,624
    Liked
    840 times
    Images
    24
    Rep Power
    20864
    i might get new wheels and tires too.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  7. #6
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    Thread Starter
    Quote Originally Posted by SuckersWalk View Post
    i just cant bring myself to spending the money on them yet. maybe when i need tires later on i will be able to then.
    CBTMA Member
  8. #7
    Junior Member fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation. fishontro would rather be driving his reputation.
    Join Date
    May 2007
    Location
    RB
    Posts
    129
    Liked
    34 times
    Rep Power
    661
    I've had my eye on Nitto Trail Grapplers or Hankook DynaPro ATM RF10 in a 255/75r17.
    Currently I'm running 265/70r17 on stock 10 spoke wheels. They are a tad small with my Billy's at the 3rd notch for my preference. BUT, I don't want to go any wider, that's me though.
    Like you, I don't really want to use spacers, hence the 255/75.
    I'm also considering BFG KM2's in 255/80r17 or KM's in 255/75. I still have a year to decide.
    Good luck...
    Had to edit....remembered that FJ wheels are 16.
  9. #8
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,624
    Liked
    840 times
    Images
    24
    Rep Power
    20864
    Quote Originally Posted by tundra3400 View Post
    me either, but i might get some someday. i've still got plenty of tread left.
    tundra3400 likes this.
  10. #9
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    Thread Starter
    Quote Originally Posted by fishontro View Post
    Good luck...
    they FJ alloys are 17's from what ive read on here. they are 17x7.5 with a larger backspacing.
    CBTMA Member
  11. #10
    Join Date
    May 2007
    Location
    RB
    Posts
    129
    Liked
    34 times
    Rep Power
    661
    Your right, the stock FJ wheels are indeed, 17".
    My mind is so wrapped up on the "Trail Team's" Black wheels that I forget about other FJ wheels.
  12. #11
    Veteran Member kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes.
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    770
    Liked
    85 times
    Images
    48
    Rep Power
    4291
    I have a set of the 16" FJ Cruiser TRD wheels sitting in my garage that I plan to mount in the near future. Picked up the set of 5 on Criagslist a few months ago. Trying to decide whether to mount Hankook Dyna Pro ATM, or the Kumho Road Venture AT. I'm currently running the AR Outlaw 2 with Firestone Destination MT.
    Attachment 92137Attachment 92138Attachment 92139
  13. #12
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,365
    Liked
    1286 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    What are you going to do with your orther rims? Are they 16 or 17 inch rims?
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  14. #13
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    770
    Liked
    85 times
    Images
    48
    Rep Power
    4291
    Lizard, they are 16". I will probably sell them with the tires (285/75/16) when the time comes.
    Highwaylizard likes this.
  15. #14
    Junior Member wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top. wishiwerefishing likes to be on top.
    Join Date
    May 2012
    Location
    biloxi mississippi
    Posts
    254
    Liked
    70 times
    Rep Power
    12128
    Those trd rims are sweet! I have kumho road venture at.285 75 16 There nice ..not very loud. They clean up easy . They have around 37,000 miles on them with about 50-60% tread. The tread ran down quick on the front outer tires, I needed an alignment.
    Sent from my Desire HD using AutoGuide.Com Free App
    Attached Thumbnails Attached Thumbnails New wheels and rubbers, maybe-uploadfromtaptalk1354625368407.jpg   New wheels and rubbers, maybe-uploadfromtaptalk1354625393088.jpg   New wheels and rubbers, maybe-uploadfromtaptalk1354625442628.jpg
    kanaduh and Remmy700P like this.
  16. #15
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    Thread Starter
    Quote Originally Posted by wishiwerefishing View Post
    do those 285/75/16s rub at all on anything? it looks like your truck is sitting on stock ride height.
    CBTMA Member
Posting Permissions
  • You may not post replies
  • You may not edit your posts
