Biggest tires possible on stock 4x4 tundra??
+ Reply to Thread
Results 1 to 7 of 7
Like Tree6Likes
  • 2 Post By SuckersWalk
  • 3 Post By Remmy700P
  • 1 Post By Rrumbler
Thread: Biggest tires possible on stock 4x4 tundra??
  1. #1
    Join Date
    Aug 2012
    Location
    Virginia Beach
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Biggest tires possible on stock 4x4 tundra??
    Hey guys,
    I tried searching but couldn't find anything. I was wondering if anybody knew what the biggest size tires are that you can put on a stock 4x4 tundra. I was possibly thinking of doing a 3" lift but right now i am just gonna ride stock height. Anybody know of the max size? planning on getting BFG All Terrains. Any info is appreciated!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3134 times
    Images
    47
    Rep Power
    162921
    Default Re: Biggest tires possible on stock 4x4 tundra??
    Yes. 32". That's the equivalent of a 265/75R16 or 265/70r17.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Supporter SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,433
    Liked
    2021 times
    Images
    26
    Rep Power
    67158
    you must have not searched correctly because this has been covered at least one hundred times. follow the link in my signature below for a "how to" search article written by one of the moderators here. good luck.
    Salty_Dog and tundra3400 like this.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Search for your answer.
    http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  5. #4
    Join Date
    Aug 2012
    Location
    Virginia Beach
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Remmy, thanks for the info!
  6. #5
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3134 times
    Images
    47
    Rep Power
    162921
    And, do not do a "3 inch lift". 2.5" of lift is the max that the stock front geometry can handle. If you want more than that, you will be looking at a couple grand for a 5-6" drop-shackle lift.
  7. #6
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,352
    Liked
    2783 times
    Images
    216
    Rep Power
    255670
    I concur with Suckerswalk, no research was done. Can somebody please delete this thread?
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  8. #7
    Join Date
    Apr 2009
    Location
    Las Vegas, Nevada
    Age
    73
    Posts
    589
    Liked
    296 times
    Rep Power
    24180
    I have 275/70rx17 Yokohama AT's ( spec says 32.7") on my totally stock 2002 AC, on MB Motors 17x8 wheels with stock backspacing, and they have a rub at total lock in either direction on flat ground; add in some terrain variations, as in mild off roading, and it gets worse on compression of the suspension. I tried spacers to get rid of the backside (inside) rub, and got frontside rub on the fenders; took the spacers off. The tires are worn into the bars now, ready for replacement, and even now, with over 45K miles, they still rub; not as bad as when new, but rub they do.
    sgtbuck989 likes this.
    Rrumbler - Tired, re-tired, and just generally wore out. Wrenching and banging on stuff for over sixty years.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
