Average lift out of OME coils (883, 884, 885, 886). - Page 10
+ Reply to Thread
Page 10 of 12 FirstFirst ... 5 6 7 8 9 10 11 12 LastLast
Results 136 to 150 of 180
Like Tree56Likes
Thread: Average lift out of OME coils (883, 884, 885, 886).
  1. #136
    Veteran Member Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24's Avatar
    Join Date
    Feb 2007
    Location
    Sunnyvale,CA
    Posts
    1,335
    Liked
    126 times
    Images
    108
    Rep Power
    11913
    Default Re: Average lift out of OME coils (883, 884, 885, 886).
    Quote Originally Posted by Localsnap88 View Post
    ay Derek, question... did you absolutelyyy neeed the T.C. Ball Joint removal kit in order to remove the upper balls from the spindle, and to get the new joint slug/ parts seated? reason i'm asking is because I ordered the kit from KLM performance and in the mean time all the rest of my suspension parts have arrived (camburgs, 885s, isolators, lower bjs, tie rod ends) .. Now just yesterday I found out KLM was out of stock on the Total Chaos removal kit so they canceled my order... Wheelers DOES have it in stock but if I order it from them tonight (thursday) I probably wont get it for a week... the guy i spoke to at wheelers mentioned I cound probably/ he has used big sockets in place of the metal caps in the kit in order to get the balljoints "popped". do you think this would be too much of a hassle - aka you think me and my certified mechanic friend would be able to get the job done without the kits , just finding the right diameter sockets to do the job? and especially pressing in the new spindle slug adapter? thanks for your input man
    Ah man that sucks! Yes if you had a deep socket that fit right on top and a wider open socket for the bottom to go around the ball joint it will work. You could also do to a metal shop and see if they can make you the slug adapters, it's really nothing but pieces of metal welded together,mother must be making $$$$ off of these adapters. You can make this work!
    2000 Tundra TRD 4x4: 5100's & OME 885~Camburg UCA's~3 Leaf Progessive Pack~ARB RD129~JBA Headers~14" Magnaflow single out~Volant CAI~Raceline wheels~265 MTZs~re-badged black~WAAG Push Bumper~(4)55W 6000K HID Spot Lights~Diff breather mod~clear corners~TC Bushings~No Sway Bars~35%/5% tint~Sound-deadening everywhere
    Life's a bore, I'm going pig hunting...
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #137
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    I just used a socket!!!
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  4. #138
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    and definitely heat up that spindle when you're pressing them out and put the uniballs in the freezer for a while before you press them in. it'll make it a lot easier.
  5. #139
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,203
    Liked
    1121 times
    Images
    216
    Rep Power
    189194
    You mean put the adapter in the freezer, not the uniball.
    Good tip, I didn't do that for the passenger side, but when I did it for the driver side, the adapter went RIGHT in.
    seanpistol likes this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  6. #140
    Junior Member huntark03 is on a distinguished road.
    Join Date
    Mar 2012
    Location
    Maumelle, AR
    Posts
    59
    Liked
    4 times
    Rep Power
    2
    Thread Starter
    Installing 884's in the morning. Went with them based on the premise that on a second gen Tacoma the Eibach coils provide ~1.6'' of lift, and ToyTec says that on the second notch of the Tundra 5100 they got 2.75" of lift. The 884s on the second gen Tacoma yield ~2" of lift. Based on the difference and the math, the 884's on the second notch of the Tundra 5100s should yield ~2.5" which is what I am looking for...
    Comments welcome...
  7. #141
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,025
    Liked
    289 times
    Rep Power
    11256
    ^^ Good Luck??....
  8. #142
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    Quote Originally Posted by huntark03 View Post
    Based on the difference and the math, the 884's on the first notch of the Tundra 5100s should yield ~2.5" which is what I am looking for...
    Comments welcome...
    I'd be surprised if that works out that way
  9. #143
    Join Date
    Feb 2007
    Location
    Sunnyvale,CA
    Posts
    1,335
    Liked
    126 times
    Images
    108
    Rep Power
    11913
    No way, sorry. 884s are a shorter spring than the 885/886 and what I have, 885, on the second notch I know I did not gain 3 inches of lift, maybe 2.5 inches. Let us know though!
  10. #144
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,025
    Liked
    289 times
    Rep Power
    11256
    I dont know, Derek....
    First I'll comment on huntarks expectation...I'd be surprised if you get 2.5" on the first notch....3rd, maybe....2nd, possibly....
    As to Derek's reasoning, the 884s are only 0.20" shorter. I doubt that 0.20" of unsprung length is gonna give that much difference in lift....UNLESS, maybe the spring rate is also very different, meaning once loaded, the 884s may compress a lot more, giving a bigger difference in final lift.
    BUT, there again, Remmy stated on the 1st page of this thread, the specs for both 884 &885s...They were the same specs I came across doing research....
    The advertised rates are the SAME for the 884 & 885....Meaning they should (relatively) compress about the same amount....And with 5100s set on the same notch using either spring, I wouldnt be surprised if there is only at most an inch difference in compressed lift, due to that 0.20" difference in length.
    OME884 390mm (15.35"), 590lbs/in
    OME885 395mm (15.55"), 590lbs/in
    With my 5100/885s on 2nd notch, I have 2 3/4" lift....But the tail of the truck is on a slight incline, and not leveled yet...I expect it'll end up at 2", maybe 2 1/4" once its leveled....We'll see...
    But then again, this is all anecdotal and theoretical speculation, since there are so many factors and variables involved, as evidenced by so many different people getting so many different results with the same sets of OME/5100's...(And I may also just be full of cr@p...LOL)....So I guess we'll have to see what huntark ends up with...
    Just for grins, I'm guessing he'll get 1"-1.5"...
  11. #145
    Junior Member Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88 is more than famous, they're infamous. Localsnap88's Avatar
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    57
    Liked
    14 times
    Images
    1
    Rep Power
    2794
    Quote Originally Posted by seanpistol View Post
    right on Sean, do you remember what size socket you used to pop the balls out of the spindle, and what size to sink the new slug adapter In? if not , no biggie, I ll just have to start trying different sizes on for fit when i take her apart and hope I have the right sizes that let me get it done.
    2004 TRD AccCab 4x4 - Bilstein 5100s (f&r), OME 885s, Camburg UCAs, diff. drop, 1.25" tapered blocks (rear), Airaid Intake Tube & Synthaflow-Filter, 18" Magnaflow (single in/out) , Wheeler's Poly Anti-sway kit, Level 8 Tracker wheels (16x8.5), 265/75/16 Cooper AT3's, AVS visors, Stampede bugshield, clear corners, SS Nerf Bars, Black/Red Euro-tails, LED third-brake light, BigStick stub antenna, Tinted, Adrian Steel toolbox, TRD rolled exhaust tip, Ultragauge, LED interior conversion, Kenwood h/u, Alpine coaxials (f&r)
  12. #146
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    I don't, but it's easy to figure out when you're in there. You needa deep socket to push them out. I pushed the slug adapter in with one of the pieces that came in the 4x4 ball-joint press kit that I rented from Autozone. It's really not too bad of a job, I posted a paragraph in Derek's DIY thread on what helped make it easier for me. Good luck!
    Localsnap88 likes this.
  13. #147
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    57
    Liked
    14 times
    Images
    1
    Rep Power
    2794
    gracias my friend. hopin I can get a day off from work this coming monday, tuesday or so and get things rolling. will keep ya posted on how things go
  14. #148
    Join Date
    Nov 2009
    Location
    Posts
    5,203
    Liked
    1121 times
    Images
    216
    Rep Power
    189194
    The lift ratio for our trucks is 1:1.6. Every one inch of lift at the coilover assembly translates into 1.6 inches of lift at the wheel. Anybody who has bothered with a spacer lift will know that a 3" spacer lift is just over 2" tall.
    Hypothetically, because I copied my way through algebra(yet got a better grade than the guy I copied off), if Derek got 2.5" of lift from 885's at the second notch, the 884's should yield 2.2" (or so) lift on the second notch. I don't know the amount of lift each notch provides, and this thread is too long to bother reading to find it, I've never seen so much talking about fractions of inches.
    The problem with the equation is, you must be dealing with springs of equal rating in order to estimate using relaxed length of the spring. This is the flaw with comparing lift achieved by Eibach springs vs lift achieved by OME springs. I'm still laughing every time I see this thread grow, my truck's suspension articulates so much that depending on what I ate I may lose 1" of lift on any given day.
    Derek24, Stone_Blue and huntark03 like this.
  15. #149
    Join Date
    Mar 2012
    Location
    Maumelle, AR
    Posts
    59
    Liked
    4 times
    Rep Power
    2
    Thread Starter
    Quote Originally Posted by Stone_Blue View Post
    I made a mistake in my original post. I meant 884's on the second notch. I have the coils on the shocks now and I am waiting till the morning to replace my CV axles while the struts are out. I will report after my drive around the block at some point tomorrow. Thanks for all the thought put into your response!
  16. #150
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,025
    Liked
    289 times
    Rep Power
    11256
    Huntark, definately post up what you get for numbers....Will be interesting to see what 884s on 2nd notch get vs 885s on 2nd notch...
    That would get us closer to comparing apples to apples...lol
    Derek24 likes this.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
