Cylinder 7 misfire detected
+ Reply to Thread
Results 1 to 3 of 3
Thread: Cylinder 7 misfire detected
  1. #1
    Junior Member dogger's Avatar
    Join Date
    Mar 2002
    Location
    Mt Juliet, TN
    Posts
    133
    Liked
    0 times
    Images
    6
    Rep Power
    13
    Default Cylinder 7 misfire detected
    My Tundra started running rough today, and the "check engine" light came on.
    I plugged in my scanner and it came back with P0307 which is a #7 cylinder
    misfire detected. I had a similar situation about 9 mos ago and it turned
    out to be a bad coil pack on cylinder 5. I replaced the coil pack and the
    problem went away that time.
    This time - not so much. I pulled the coil pack from cylinder 7 and replaced
    it with one off the wife's Sequoia. No improvement and same code. I pulled
    the spark plug and it was dark brown and looked like it was just along for the
    ride. I pulled a plug out of the Sequoia and installed it along with the coil
    pack and still no improvement and same code. I pulled all of the plugs and
    found all of them very dark brown with gaps about .045 or more. I installed
    these plugs 25000 miles ago and each one was gapped to .031. The plugs
    are NGK BKR7EVX-11s. I know the "tune" on the supercharger ECU is very
    rich which explains the plug color, but the big gap has me confused. I
    re-gapped all the plugs back to .031 and installed them with all the coil
    packs from the Sequoia, no improvement and same code. I plan to
    replace the NGKs with E3-64s since they appear to have such a short
    service life.
    I think I have covered the electrical end of the diagnostic, so I'm thinking
    possible bad fuel injector? Maybe even a CAT related problem. This is a
    Three catter Cali truck.
    Truck has 55000 miles and gets a bottle of injector cleaner every third
    tank full.
    Any help/suggestions would be greatly appreciated.
    Thanks.
    dogger
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    606
    Liked
    50 times
    Images
    7
    Rep Power
    2082
    Default Re: Cylinder 7 misfire detected
    Bad gas? Octane too low? Intake valve carbon build-up? Lazy O2 sensors? How often do you change the PCV valve? Is the air filter clean/new? How is the compression?
    Have you monitored engine performance with a scanner yet? Did it reveal anything unusual?
  4. #3
    Join Date
    Mar 2002
    Location
    Mt Juliet, TN
    Posts
    133
    Liked
    0 times
    Images
    6
    Rep Power
    13
    Thread Starter
    Thanks for the suggestions.
    Gas is good name brand 93 octane from a station with high turnover. PCV replaced every 12 months. Air filter is a TRD reusable, last cleaned and oiled 2 months ago. Compression is good
    and consistent among all cylinders. I ran the scanner with the Truck idleing and didn't get any unusual readings on the freeze frame. I think I have some weak and/or non functioning coil
    packs caused by the oversized gap on these plugs which worked the coils too hard and now they are failing. I just ordered eight new ones that I plan to swap in with new plugs.
    Fuel injectors are all in limits and the Cats are good.
    I'll post the results when i get the coils and plugs installed.
    dogger
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
