Secondary Air Injection System Pump
+ Reply to Thread
Results 1 to 11 of 11
Thread: Secondary Air Injection System Pump
  1. #1
    Supporter skipo's Avatar
    Join Date
    Jun 2006
    Location
    Plantation, FL
    Age
    58
    Posts
    103
    Liked
    1 times
    Rep Power
    12
    Default Secondary Air Injection System Pump
    I have code 2445 on my scan guage, it says something about the Secondary Air Injection System Pump, truck is out of warranty, expensive part, anybody else have this go out
    TUNDRA DC 4WD NATURAL WHITE XSP
    Enkei 20" Deep Six Alloys, ARE LSII Tonneau Cover,Borla Dual Exhaust, LSD, JBL 6 Disc Changer, USA Spec Auxiliary Input, Sirius Sportster, Scanguage w/ Blendmount
    http://www.myspace.com/skiposurfever
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Do a AIP bypass. Search is your friend. Part cost = $10
  4. #3
    Veteran Member kovawa's Avatar
    Join Date
    Feb 2008
    Location
    so cal
    Posts
    531
    Liked
    173 times
    Rep Power
    10365
    Default Re: Secondary Air Injection System Pump
    No more searching needed, read this- Production AIP Bypass Module
    2006 DC 4X4 SR5 Phantom Grey Metallic. Mods include: Full Tint,LED lighting inside & Out. 900 watt JBL/Alpine audio System, Mishimoto Aluminum Radiator, OBX Stainless Steel Headers, Magnaflow Muffler, TRD Dual Exhaust, Polyurethane Upper/Lower Control Arm & P/S Rack Bushings.Rancho RS9000 adjustable shocks.
  5. #4
    Join Date
    Jun 2007
    Location
    Mitchell, IN
    Age
    31
    Posts
    108
    Liked
    2 times
    Images
    1
    Rep Power
    8
    I had an issue with this and it involved a lot of trips to the dealer and painful dealings with my extended warranty company. Endedup totaling about $3500 when it was all said and done. Problem started with CEL for emission code. Took it in and the they replaced the primary and secondary air switching valve. A week later the CEL came back on, different emission code, but same system.Took it back in, they vacuum checked the lines and code went away. Three days later same code shows up. Take it back to the dealer and they get with the Toyota engineers. Engineers say to replace the air pump, which is a $1600 part. When they pulled the part it was rusty and contaminated from some sort of water/moisture intrusion. Problem free for 10k miles. Glad I had the warranty because I didn't have to pay a dime out of pocket for the repairs.
    Silver Sky Metallic 06 Tundra DC X-SP
    Mods
    Viper 5900 w/ Remote Start & Keyless
    JBA 2011S Headers
    Kenwood CD Player
    Sirius Sat Radio
    Memphis 250W Amp
    300W JL Audio Stealthbox
    ARE Z-Series Cap
    A Big Set of NUTS Hanging From the Hitch
  6. #5
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,382
    Liked
    3166 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by SNYDS View Post
    ...Engineers say to replace the air pump, which is a $1600 part...
    That's a load of ****. Guys are replacing their corroded/rusted air pumps with off-the-shelf GM pumps for about $25, plug-and-play. It's a giant scam.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  7. #6
    Join Date
    Jun 2007
    Location
    Mitchell, IN
    Age
    31
    Posts
    108
    Liked
    2 times
    Images
    1
    Rep Power
    8
    Your probably right. But extended warranty took care of it with a little persuasion. So if it ever happens again I'll look into that.
    Mods
    JBA 2011S Headers
    Kenwood CD Player
    Sirius Sat Radio
    Memphis 250W Amp
    ARE Z-Series Cap
  8. #7
    Join Date
    Jun 2006
    Location
    Plantation, FL
    Age
    58
    Posts
    103
    Liked
    1 times
    Rep Power
    12
    Thread Starter
    Just got the truck back, pump was replaced $1200.00, another $500.00 for labor, pump was seized up, luckily GEICO mechanical breakdown insurance took care of it, good to be back on the road again
  9. #8
    The Friendly Dragon by the Sea Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    51
    Posts
    2,876
    Liked
    183 times
    Images
    45
    Rep Power
    16219
    I have a feeling that I'm about to join this aip failure club. Mine started resonating through the firewall one evening when it first turned cold and now they clack and getting louder. Since they sit on the back of the block against the firewall all of their new noises come right into the cab. No codes yet so I'd probably get the run a round if I took it in to the dealer and tried to get them replaced. My warranty runs out next year so I'm on the fence about this.
    RIP 2006 Tundra DC with: Eclipse AVN5500 Navigation System, Kicker IX500.4 driving infinity kappa 60.9cs door speakers, Kenwood KAC-X20 driving an infinity kappa 100.9w sub in sound ordnance bass bunker, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Ballistic Enigma 20x9 wheels & Nitto nt420 285/50R20 tires, Hellwig 7697 & 7700 sway bars, Stinger SPP2150 Battery, Big 3 wire upgrade with 1/0 Raptor, Rancho RS5000 struts/shocks, Dynomax VT 17956 muffler, EBC Slotted Sport Rotors & Yellowstuff Kevlar pads, Russell SS brake lines, Cheetah GPS Mirror
  10. #9
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,094
    Liked
    339 times
    Images
    8
    Rep Power
    42560
    Put pxsp's bypass kit on it!
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  11. #10
    Join Date
    Apr 2013
    Location
    Texas
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Mendonsy, I got a 05 tundra and I've installed the aip override relay. The truck no longer drives in
    limp mode but the eng light came back on. I'm getting codes p0418 and p2445. Do u
    have any suggestions? Thanks in advance.
  12. #11
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,094
    Liked
    339 times
    Images
    8
    Rep Power
    42560
    I don't, but this might help you.
    http://www.justanswer.com/toyota/1r6...418-p2445.html
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
