Transmission Flush at 100K - need to use Toyota Fluid?
+ Reply to Thread
Results 1 to 15 of 15
Like Tree5Likes
  • 3 Post By Remmy700P
  • 2 Post By Tones
Thread: Transmission Flush at 100K - need to use Toyota Fluid?
  1. #1
    Join Date
    Jun 2007
    Location
    Los Angeles
    Posts
    179
    Liked
    0 times
    Rep Power
    9
    Default Transmission Flush at 100K - need to use Toyota Fluid?
    I took my vehicle to Firestone for a trans flush last year, and they told me they won't use anything but the mfg recommended fluid, which is something like $20 a bottle or a ridiculous amount. Does anyone know if this is necessary and can it be done with using aftermarket fluid? It seems like a hassle to do the change myself so I was looking for a shop that had the machine but if they were charging me for the factory fluid then it is not cost effective to do anymore.
    As a side note I recently upgraded to HID and I think it looks great.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Default Re: Transmission Flush at 100K - need to use Toyota Fluid?
    I'm assuming from your forum name that you have a 2005 Tundra V8. This model year utilizes the Aisin-Warner A750X transmission. This transmission requires the use of the 'highly friction-modified', i.e. Toyota World Standard ("WS") ATF. The only aftermarket supplier that I know that makes an ATF compatible with this specification is Amsoil.
    PM TSer Tundradrenalin. He's an Amsoil distributor and can help you out, maybe save you some $$$.
    Here's Aisin WS ATF for sale at $6.50qt: http://www.lowrangeoffroad.com/index...d-atf-0ws.html. You've got to buy it in bulk (12-16 quarts) to make the minimum shipping charges worth it.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
  5. #4
    Supercharged Member Jonesy's Avatar
    Join Date
    Oct 2009
    Location
    San Diego Bay Area
    Posts
    4,218
    Liked
    4938 times
    Images
    37
    Rep Power
    81735
    2005 4.7L~RCLB~LSD~DSM~2 WD~Cold Weather Package~Towing Package
    Flowmaster American Thunder Cat Back~
    Retrax Pro Bed Cover
    Bed Mat~Split Spoke Alloy Wheels~BAK Bed Rail Covers
    32K Miles & Counting
  6. #5
    Join Date
    Sep 2012
    Location
    SE WI
    Posts
    28
    Liked
    2 times
    Rep Power
    3
    Getting the fluid level right is the tricky part, make sure you measure what you take out. Or see what your dealer charges, mine did the 4 quart swap for $50.
  7. #6
    Join Date
    Jan 2012
    Location
    Alberta, Canada
    Posts
    87
    Liked
    30 times
    Rep Power
    10
    Um, the transmission has an overflow valve on the bottom of the pan, you unscrew it and start filling your transmission and once it gets to the right level it comes out and its at the right level. Nothing tricky to it.
    Also my service manual says that transmission pan and drain removal takes 1.3L.
    2. TRANSMISSION PAN FILL
    (a) Remove the refill plug and overflow plug.
    (b) Fill the transmission through the refill hole until fluid begins
    to trickle out of the overflow tube.
    (c) Reinstall the overflow plug.
    FLUID LEVEL CHECK
    NOTICE:
    The fluid temperature must be between 46C (115F) and
    56C (130F) to check the fluid level.
    (a) Remove the overflow plug with the engine idling.
    (b) Check that the fluid comes out of the overflow tube.
    If fluid does not come out, proceed to step 7.
    If fluid comes out, wait until the over−flow slows to a trickle and
    proceed to step 8.
    06 DC Limited /-/ Stan's Header's /-/ Borla /-/ Flex-a-lite /-/ Volant /-/ Camburg Coil-overs + UCA's /-/ Alcan +2 rear leafs /-/ Icon rear shocks /-/ V-LED's
    To install list: Icon Extended Travel
    Coil-overs
  8. #7
    Supporter SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,604
    Liked
    2170 times
    Images
    26
    Rep Power
    67158
    Quote Originally Posted by MisterPX View Post
    that's a good price considering the fluid alone will run about $40 +/-.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  9. #8
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    << double post >>
  10. #9
    Junior Member TundraDad1's Avatar
    Join Date
    Dec 2010
    Location
    Glennville, GA
    Posts
    74
    Liked
    20 times
    Images
    7
    Rep Power
    827
    The only thing that has ever concerned me about this process is how do you determine the temperature of your fluid, while checking??
    2005 Tundra D/C 4x4 Limited-Finest Vehicle I've owned yet!! "Freedom is not just a right, it is a responsibility!!"
    Bilstein 5100's all around, (Set on 3rd Notch up front), Westin Sportsman Grill-Guard, Dirty-Deeds Ind. BAMuffler, (Love it!!), Flexi-Lite Dual Electric Fans, (Best MPG Improver yet!!!), Upgraded Head&Fog bulbs, & a few other tidbits that probably won't matter to you all, but I really like!!!
  11. #10
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by TundraDad1 View Post
    10-15 minutes of driving usually does it. If you really want to be accurate, I suggest the Torque Pro app.
  12. #11
    Veteran Member Tones's Avatar
    Join Date
    Dec 2005
    Location
    Houston, TX
    Posts
    568
    Liked
    7 times
    Rep Power
    23
    Valvoline Maxlife gets a lot of rave reviews. I haven't used it, but it does state it is compatible with the WS.
    http://www.valvoline.com/pdf/maxlife_atf.pdf
    SuckersWalk and Jonesy like this.
  13. #12
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by Tones View Post
    Note that it states that it is compatible with T-III and T-IV ATF as well. WS and these previous formulations are not compatible, so the characteristics of this ATF cannot work in both. I'm guessing that the low-viscosity requirements of the WS spec will not be met with this Valvoline ATF.
  14. #13
    Join Date
    Dec 2005
    Location
    Houston, TX
    Posts
    568
    Liked
    7 times
    Rep Power
    23
    Maxlife is a full synthetic fluid and others have reported great success with it, including WS applications. It should work fine.
  15. #14
    Join Date
    Nov 2012
    Location
    Austin NW
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    $20 is bogus.
    Should be more like this for the OEM stuff. If you PM me I can tell you what dealer to order it from. I use him for all my Toyota parts.
    00289-atfws fluid qt . List 9.33 cost 7.00 ea
    2006 Tundra
    2005 Sequioa
    1995 Supra 'built not bought'
  16. #15
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Here's a link to purchase WS ATF online. It's listed at $6.50/qt before shipping. I suggest buying 12 quarts at a time to save on shipping.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
