Question Need new shocks for my Stepside.....
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Like Tree9Likes
Thread: Need new shocks for my Stepside.....
  1. #1
    Rookie EdMP3006 is on a distinguished road.
    Join Date
    Oct 2010
    Location
    Maryland
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Hey guys,
    My truck is at 112K miles and i'm just now needing to replace the front shocks, but I'm going to replace the back ones too......my question is, well, more of a statement...I don't know what kind to get for it....
    I'd love to lift it, but that is not an option right now, so I just need to replace the shocks....I was looking at Rough Country, but they don't make Front shocks for my 2003 Stepside Tundra, here is an older picture of her.....
    Gonna switch back to the original factory 17"s once I get around to getting tires for them.....look forward to hearing some good opinions!
    Ed
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    Default Re: Need new shocks for my Stepside.....
    If you want levelling lift, get the Bilstein 5100 series ride-height adjustable front struts and matching rear shocks. You can set the ride height on the fronts anywhere from stock up to about 2.5" of lift.
    I -- and many others here -- are running these shocks. Pics in may Garage.
    Fronts are $97/ea and the matching rears are $75/ea.
    Contact TSer AJUSA to order.
    tundra3400 likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #3
    Junior Member yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin has done just about everything...and then some. yotabangin's Avatar
    Join Date
    Jun 2012
    Location
    Round Rock, TX
    Posts
    157
    Liked
    40 times
    Images
    3
    Rep Power
    869
    We can prolly lock this thread up ;-)
    You say you can't afford a lift? well do as Remmy says and get bilstein 5100s all the way around and you can lift your truck with just struts. So for less than 400 bucks you can get new shocks AND lift your truck. Sweet deal huh? Id set the billys at their top notch (2.5)inches and just throw a 1inch block in the rear for like 40 bucks and be done with it. You will love the new stance of your truck sir. Budget boost all the way. And it rides quite well.
    Texas Tundra15 likes this.
    2003 Access cab step side / bilsteins all the way around / OME 886 springs / camburg UCA and uniballs / removed sway bar / toytec AAL in the rear with 2 inch blocks and hellwig 1250 helpers / toytec 3 degree shims / streetacos carrier bearing drop 2 1/4inch / Pro Comp alloys 16x8 and firestone destination all terrains 285/75/r16 / Alpine type R 12' sub and deck
  5. #4
    Join Date
    Oct 2010
    Location
    Maryland
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Hey yotabangin...
    Nice to see another Stepside around......where would I look to get a 1" blocks?
    I guess talk to TSer like Remmy suggested?
    Ed
  6. #5
    Join Date
    Oct 2010
    Location
    Maryland
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Bueller? Bueller?
  7. #6
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    843 times
    Images
    24
    Rep Power
    20864
    use the link Remmy gave you in post #2 above. not only do they have shocks, they can get you ANYTHING you need for your tundra, including blocks for the rear.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  8. #7
    Veteran Member oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354's Avatar
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    20
    Posts
    1,351
    Liked
    261 times
    Images
    21
    Rep Power
    11089
    They are actually slightly cheaper at Wheelers Offroad, another supporting vendor (and actually, owner) of these forums. AJUSA does not carry lift blocks or leafs as far as I can tell, Wheelers does though. Both are great companies to work with and either can answer any questions you might have. Wheelers especially is known for their customer service.
    Remmy700P likes this.
    2001 Black AC V8 4x4
    Current Mods: TrailFX Tube Steps, Uniden CB Radio with PA, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Plastidip Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front AUX lights, JVC Headunit, Kicker Front Components, Pioneer Rear Speakers, Magnefine Filter, Viper Remote Start, Single in-Dual out 2.25in Exhaust
    Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Exhaust Leaks
    To Do: Diff Fluid, Kenwood DDX419, 5100s Front and Rear set to 1in, Diff Drop, Poly Rack Bushings
    Quote Originally Posted by italiantundra88 View Post
    dave, every one has a weekness, yours is just any work on your truck
  9. #8
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    336
    Liked
    175 times
    Rep Power
    5076
    Bilstein 5100's for sure! I installed a set on a customers truck recently and he called me one night to say they are the best shocks he's ever had. He took it off road and hammered on it good, said he never bottomed and drove 45 mph through a rough section that he previously had to baby it through. Better than new according to him. I'll be getting a set myself soon. AJUSA.com is the place to go!
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's.
    http://thebrakedoctor.com
  10. #9
    Join Date
    Jun 2012
    Location
    Round Rock, TX
    Posts
    157
    Liked
    40 times
    Images
    3
    Rep Power
    869
    My bad man, didn't see your question. The blocks you can get just about anywhere and are easy to install. The bilsteins set on 2.5 and a 1.5 inch block and you be lookin sexayyy. Toytec has a 1.5 block and also shims but you prolly don't need them
  11. #10
    Junior Member Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805 is more than famous, they're infamous. Delatorre805's Avatar
    Join Date
    Dec 2010
    Location
    Oxnard
    Posts
    99
    Liked
    24 times
    Images
    7
    Rep Power
    3308
    Quote Originally Posted by oofy15354 View Post
    He would be better of ordering off ajusa since they have free shipping and no sales tax for sales out of Cali... I just got mine today for 209 from ajusa...
    '03 Tundra SR5 A/C 2WD
    -Custom Jardine Exhuast System
    -Willwood Slotted Rotors
    -K&N Cold Air Intake FIPK
    -JBA Headers
    -BFGoodrich A/T
    -Enkei 360 Wheels
    -Bilstein 5100 Adjustable Height 2"
  12. #11
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    843 times
    Images
    24
    Rep Power
    20864
    ^ zactly
  13. #12
    Join Date
    Oct 2010
    Location
    Maryland
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    So getting the 5100's for my "Yota"....do I need the extra 1" block for the rear, or should I be ok without it?
  14. #13
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    843 times
    Images
    24
    Rep Power
    20864
    pull the trigger already, jeez.
    you'll be okay without the blocks. if you want to raise the rear, get the blocks.
  15. #14
    Join Date
    Oct 2010
    Location
    Maryland
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by SuckersWalk View Post
    Haha, I did this morning...had to wait to get the ok from the wife
  16. #15
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    843 times
    Images
    24
    Rep Power
    20864
    four months to get an okay? you need a younger wife.
    Remmy700P and Bradthetech like this.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
