Question Steering wheel won't return to center
+ Reply to Thread
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Remmy700P
Thread: Steering wheel won't return to center
  1. #1
    Junior Member 87runner's Avatar
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    155
    Liked
    36 times
    Rep Power
    5293
    Default Steering wheel won't return to center
    So I replaced my rack last weekend (2000 4x4 Tundra) along with both lower balljoints and outer tie rods. Everything went in well, I bled the PS system, had the truck aligned etc. The truck tracks straight and the rack feels nice and tight, however, when I turn a corner the steering wheel will return most of the way but not all the way. Typically I have to manually return it 30 degrees or so no matter which direction I am turning. I checked my torque specs on both lower balljoints and outer tie rods and everything is torqued correctly. Not sure if this is typical for a remanufactured rack if it has a break in period but want to see if others have had similar experiences.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3190 times
    Images
    47
    Rep Power
    162921
    Default Re: Steering wheel won't return to center
    Post up your final alignment numbers. I'll bet money that caster is set way too low...
    tundra3400 likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    155
    Liked
    36 times
    Rep Power
    5293
    Thread Starter
    Post alignment numbers
    Toe: 0.04 degrees driver/ 0.04 degrees passenger side
    Total Toe: 0.08 degrees
    Camber: -0.05 degrees driver/ 0.24 degrees pass
    Caster: 1.25 degrees driver/ 1.24 degrees pass
    Pre-alignment caster was 0.75 (driver) and 1.31 (pass). Sounds like others have had success adjusting their caster to around 2.00 degrees. Should I consider taking the truck back to the alignment shop and having them bump my caster up closer to 2 degrees?
  5. #4
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3190 times
    Images
    47
    Rep Power
    162921
    Yes. Cross-camber is atrocious. Driver's side camber needs to be corrected to the positive (for a rear wheel drive vehicle) and caster needs to be increased on both sides.
    Are you at stock height?
  6. #5
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    155
    Liked
    36 times
    Rep Power
    5293
    Thread Starter
    I have Bilstein 5100's set at 2 inches in the front on 255/85 16's. Looks like I will be headed in there first thing tomorrow to get this resolved. I purchased a lifetime alignment package from this particular shop and unfortunately they give me grief every time I come in. Probably because I have taken full advantage of the lifetime alignment and periodically get the truck re-aligned. Oh well, guess that's how it goes when you offer packages like that
  7. #6
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3190 times
    Images
    47
    Rep Power
    162921
    Print out DJ's alignment specs (attached) and take them in with you. Have them align it to those.
    Attached Files Attached Files
  8. #7
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    155
    Liked
    36 times
    Rep Power
    5293
    Thread Starter
    Sounds good, thanks for the help! Will report back with the results...
  9. #8
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    155
    Liked
    36 times
    Rep Power
    5293
    Thread Starter
    Got the truck back from the alignment shop, they didn't do it exactly to spec but close
    Toe : 0.05 driver/ 0.06 Pass
    Total Toe 0.11
    Camber: 0.07 Driver/ 0.06 pass
    Caster: 2.02 driver/ 2.07 pass
    Truck does seem to be driving a little better, however the steering wheel still doesn't want to center. Tech thinks the new balljoints might need some time to fully seat and loosen up. Sounds possible, maybe I will drive it a bit longer and see if things improve. I will say, I do like running the caster in the higher end of Toyota's recommended level, just seems to drive better, steering is more responsive
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
