unknown rusty gate sound
+ Reply to Thread
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By tundrunk
Thread: unknown rusty gate sound
  1. #1
    Veteran Member 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac has mentally logged off-topic. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    Default unknown rusty gate sound
    coming from the drivers side front. 5100's on the middle notch less than 10k miles on them. diff drop added just because it was cheep! if i hit a dip in the road going fast enough to cause the front end to compress the shocks i get a sound like the shock is squeeking. i assume it is the shock. any way to tell just by looking at it or what?
  2. #2
    Veteran Member tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    193 times
    Images
    27
    Rep Power
    8732
    Default Re: unknown rusty gate sound
    i think im starting to hear the same thing on my 2000, i have the about 5K on 5100s at the middle notch. it sounds like a bushing of some sort. you could try to lube all the bushing to see if the noise goes away but idk what kind of lube to use.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 198,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  3. #3
    Veteran Member oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354 likes to be on top. oofy15354's Avatar
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    20
    Posts
    1,359
    Liked
    262 times
    Images
    21
    Rep Power
    11150
    If you can find a place where it happens consistently, bring a can of WD-40 with you and spray down a single bushing and hit the bump. If the noise is gone, there is your culprit. If not, spray something else and repeat until the noise goes away. I did this with U-joints to find which one was failing
    2001 Black AC V8 4x4
    Current Mods: TrailFX Tube Steps, Uniden CB Radio with PA, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Plastidip Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front AUX lights, JVC Headunit, Kicker Front Components, Pioneer Rear Speakers, Magnefine Filter, Viper Remote Start, Single in-Dual out 2.25in Exhaust
    Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Exhaust Leaks
    To Do: Diff Fluid, Kenwood DDX419, 5100s Front and Rear set to 1in, Diff Drop, Poly Rack Bushings
    Quote Originally Posted by italiantundra88 View Post
    dave, every one has a weekness, yours is just any work on your truck
  4. #4
    Join Date
    Sep 2009
    Location
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    Thread Starter
    and then is it a question of a loose bolt in the bushing or what is the actual cause of the squeek? i don't remember there being any lube that came with the shocks.
  5. #5
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,170
    Liked
    2090 times
    Images
    47
    Rep Power
    125681
    baja, if it is coming from the strut, then it is a larger issue than lubrication. The strut internals (piston, valve, seal, etc) have failed and the strut needs replacement.
    I'd do as oofy suggested... start hitting spots with WD-40 (forward UCA bushing, rearward UCA bushing, LCA bushing(s), etc) one at a time and see if it stops. Don't forget your sway bar bushings.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #6
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,306
    Liked
    1237 times
    Images
    216
    Rep Power
    196487
    I'm not sure if I'd use WD on bushings, it might dry them out since WD displaces moisture. You might be better with an actual lubricant, perhaps Pro Long or something Teflon based. A squeak could be metal to metal contacting, if that's the case, lubrication is only hiding the issue rather than resolving it.
    If it turns out not to be shock related, what you may need to try is, lift your front end up on jack stands, loosen your upper control arm pivot bolt, then set your truck down on the ground and snug it up again. The stock upper arm has a tension effect when it's tightened up, and if you went from stock height to 2-2.5" taller the upper arm may be having a bind in the bushings.
    Does the sound seem to happen on compression or on rebound? I know you said it happens when you cause compression but I don't want to assume you meant the noise happens during compression. Noises like this are hard to diagnose through a forum.
    CoachRon likes this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  7. #7
    Join Date
    Sep 2009
    Location
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    Thread Starter
    lemme go hit that damn bump. i'll be back later.
  8. #8
    Join Date
    Sep 2009
    Location
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    Thread Starter
    broke out the graphite spray and hit the UCA then the LCA and the squeek is still there. if i pull up and down on the grill guard i can replicate it all day long. was graphite not the right lube or is the offending squeek somewhere else like the steering rack?
  9. #9
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    193 times
    Images
    27
    Rep Power
    8732
    you said you lubricated the UCA/LCA bushings. that only leaves the upper and lower shock bushings. maybe it has something to do with the rack.
    CBTMA Member
  10. #10
    Join Date
    Nov 2009
    Location
    Posts
    5,306
    Liked
    1237 times
    Images
    216
    Rep Power
    196487
    I don't think the steering rack can make that kind of noise. Just as a refresher, do you have any modifications to your front suspension other than the 5100s?
  11. #11
    Join Date
    Sep 2009
    Location
    Posts
    1,455
    Liked
    232 times
    Images
    14
    Rep Power
    13316
    Thread Starter
    no other mods to the front. i'll keep spraying and see what happens.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
