Rough idle in gear '01 SR5
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Thread: Rough idle in gear '01 SR5
  1. #1
    Rookie archcycle is on a distinguished road.
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Default Rough idle in gear '01 SR5
    2001 Tundra SR5, 3.4L
    I have a rough idle when in gear and it seems to be worse in the rain. It's not terrible but just seems like it should be smoother. I just bought the truck a week ago with 131,000 miles.
    Ran a can of sea foam through it starting at 1/8 tank and ran it just about empty
    Changed the air filter
    Swapped worn K16TR11 plugs with new PK16TR11s gapped to .043
    Cleaned the throttle plate
    Wires are very clean probably recently replaced
    Replaced both vacuum lines running to the airbox (cracking)
    Cleaned the MAF sensor
    First it idled really high around 1500, dropped to 1200 after a minute or so, and I took it for a test drive and before getting out of the neighborhood the check engine light came on. Turned around, stopped and started it several times in the driveway and it kept coming on, left for a few minutes and came back and it started up with no light and at normal idle around 500.
    Drove it around for a while and it seems like there's been little or no change. I can feel some shake in the steering wheel while idling in D but it's not like it's in danger of stallilng.
    It idles perfectly smooth in N. Any ideas what to try next?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind.
    Join Date
    Sep 2012
    Location
    North Carolina
    Posts
    134
    Liked
    43 times
    Rep Power
    1663
    Default Re: Rough idle in gear '01 SR5
    What was the code?
    While in Drive, hold the brake and give it some gas, see if it starts a hard miss or idles up normally.
    What does it do under hard acceleration?
  4. #3
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    I don't have a computer to pull the code so check engine is all I've got to go on right now. I've put about 45 minutes of city driving on it and it since this morning and it's running exactly like it was before I did the work this morning.
    Very smooth when it first comes down from high idle and settles around 825
    Put it in D and it drops to about 550-600 and goes from a smooth HMMMMMMM to a rough sounding BRRRRRRRR with a little bit of steering wheel shake
    Approaching stops it's perfectly smooth until it drops under about 800 right before coming to a full stop and starts with the roughness
    I put it in D and revved it slowly with the brake applied and once it got near 1000 (seems like 800 is the crossover point) it smooths out perfectly again. I'm not feeling or hearing misfires or hesitation. It has the feel of poor timing or poorly adjusted butterflies.
    Under hard acceleration it feels good and shifts fast and smooth un the mid 4000s. I can hear a little bit of ticking around 3500 and i'm pretty confident it's the lifters not a knock.
    I'm leaning toward a vacuum issue because it only happens when in gear and only at the very bottom of the tach. What's normal idle speed in gear and in N? I have factory service manual books 1 & 2 in the mail but am not expecting for another week or so.
  5. #4
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    179 times
    Images
    27
    Rep Power
    6289
    take your truck to an auto parts store and have them run the code for free. post it up and well see whats going on. it could be the idle speed control motor/sensor is still dirty or failing.
    also i hope you used only MAF cleaner on the MAF sensor and that you didnt touch the bulb it in. that can cause the sensor to fail.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  6. #5
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,113
    Liked
    2029 times
    Images
    47
    Rep Power
    121449
    My guess is the TPS.... or something goofy with the torque converter.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  7. #6
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by tundra3400 View Post
    I'll see about getting the code pulled and report back. Would it still be there if the light is no longer on? The check engine light went away the morning I did the work and hasn't returned. I cleaned the MAF correctly with MAF cleaner so no worries about that one unless it were actually bad but I'd think (hope) it would still be showing a code if that were the case.
    I've found that occasionally it comes to rest dead on at 800 when I come to a stop and it sits there idling perfectly smooth for a while before dropping down low.
  8. #7
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    The code is P0110 'intake air temp sensor 1 circuit'
    That was the only code
  9. #8
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,113
    Liked
    2029 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by archcycle View Post
    Failed, dirty, or poorly connected MAF sensor.
  10. #9
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    So the IAT is a part of the MAF? I found some things googling this at the Advance parts counter about some wires on the MAF being for the IAT (unlisted in their system at least by that name) but decided to hold off in case those wires were going INTO not out of the MAF
    Damn. Trip back out later. Better to have waited instead of throwing parts at it though. Any thoughts on the remanufactured ones at auto parts stores vs expensive dealership ones?
  11. #10
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    Clean you MAF sensor first, clean the connections and coat them with dialectic grease. If that fails then look into buying a new MAF.
    Tundra Fuel Economy: Cleaning the MAF and Throttle Body
    Tundra Fuel Economy: MAF Sensor and Throttle Body Cleaning
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  12. 11-20-2012 06:12 PM
    H. M. Murdock
    Reason
    Double post
  13. #11
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by Highwaylizard View Post
    I hosed it down with MAF cleaner from front and back in the initial job so it's definitely clean. I have some concern that it just threw the code after I cleaned it (when i first got the check engine light that went away) and maybe it was still a little bit soaked with MAF cleaner but it's hard to argue with the code. Time to replace it and see. Deer season starts in a few days so the truck that starts when you turn the key and runs acceptibly might get bumped
  14. #12
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,113
    Liked
    2029 times
    Images
    47
    Rep Power
    121449
    Yes, it is part of the MAF sensor component.
    tundra3400 likes this.
  15. #13
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    What brand of MAF cleaner did you use? Have you had a chance to inspect your electrical connections? Could be something simple. Keep us posted on what you find out.
  16. #14
    Join Date
    Nov 2012
    Location
    Florabama, FL
    Posts
    14
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    I used CRC cleaner. I did not unscrew it from the housing like in your blog post though- I just sprayed it heavily from front and rear while it was still in the intake which I had already removed to do the throttle body cleaning. Maybe it's not clean?
    The connectors look like new
    Rough idle in gear '01 SR5-maf-connector.pngRough idle in gear '01 SR5-maf-top.jpg
    Is this intake air temperature sensor a replaceable component of the MAF or is it just a synonym for it? Dealership had no idea what I was talking about and said $188 for a MAF compared to $78 for whatever aftermarket brand that Advance carries.
  17. #15
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,113
    Liked
    2029 times
    Images
    47
    Rep Power
    121449
    The MAF assembly provides the ECU with both... airflow and intake air temp sensor readings.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
