problems starting
+ Reply to Thread
Results 1 to 7 of 7
Thread: problems starting
  1. #1
    Rookie jeffcheesey is on a distinguished road.
    Join Date
    Apr 2012
    Location
    Lakewood , Colorado
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Default problems starting
    help please i have a 2000 tundra with 139,000 k on it and some times it doesnt want to turn over. battery is new i cleaned all connections at the battery . when i turn the key i can hear the relay click( in the fuse box in the engine compartment) and the throttle position set but no starter turn. after trying multiple times something finally catches and the motor will turn over and start.
  2. #2
    Junior Member Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some. Tundra1Dan has done just about everything...and then some.
    Join Date
    Jun 2012
    Location
    Ontario
    Posts
    54
    Liked
    17 times
    Rep Power
    1053
    Default Re: problems starting
    Could maybe be the brushes in the starter are worn, just a thought.
  3. #3
    Veteran Member tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    193 times
    Images
    27
    Rep Power
    8732
    double check all the connection, especially on the pos battery terminal. my truck did the same thing. replaced the starter with a reman and it continued. come to find out it was the contacts or the plunger on the stater motor its self plus the loose wing nut on the pos teriminal. had a brand new one put on and it has worked since.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 198,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  4. #4
    Join Date
    Apr 2012
    Location
    Lakewood , Colorado
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    after reading past threads about simular starting problems i was pretty convinced my starter is going out but today after the usual 6 attempts then starting my check engine light came on with a P0340 ( camshaft position circut malfunction) . is this a sympathy code? or the source of my starting problem . thanks in advance for any replies.
  5. #5
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,170
    Liked
    2090 times
    Images
    47
    Rep Power
    125681
    OBD2 - OBDII Code P0340 TOYOTA - Camshaft Position Sensor 'A' Circuit Bank 1 | Engine-Codes.com
    Start with the easy (and less expensive) diagnoses first, i.e. a poor battery connection, starter connection, etc. Replacing the starter entails removal of the entire intake system.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #6
    Join Date
    Apr 2012
    Location
    Lakewood , Colorado
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    battery is new , all connections at the battery have been taken off an cleaned . can i access the starter connections without removing the manifold ?
  7. #7
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    193 times
    Images
    27
    Rep Power
    8732
    Quote Originally Posted by jeffcheesey View Post
    this depends on if it is a V6 or a V8. the V8 is a PITA to get to the starter. the V6 isnt as bad.
    CBTMA Member
Posting Permissions
  • You may not post replies
  • You may not edit your posts
