06 Tundra Front Caliper Brake lines corrosion solution with stainless lines?
+ Reply to Thread
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Puffnstuff
  • 1 Post By Sportsmanphil
Thread: 06 Tundra Front Caliper Brake lines corrosion solution with stainless lines?
  1. #1
    Rookie cnckeith is on a distinguished road.
    Join Date
    Nov 2008
    Location
    Outer Banks
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default 06 Tundra Front Caliper Brake lines corrosion solution with stainless lines?
    Anyone out there with a braided stainless front caliper brake lines installed that can tell me if the stainless steel brake lines will replace both the stock rubber line AND the very short steel line that goes from the caliper to the rubber line connection? thanks in advance!
    (i drive thru lots of wind blown sand and salt water and the stock short steel line will rust thru due to constant sandblasting and salt corrosion. so rather than keep replacing them i thought i'd check into the stainless lines I see advertised all the time. I looked at many web sites and could not find any photos of a installed set so i could tell if the stainless lines go directly to the caliper or connect to the short stock steel line that then connects to the caliper, which wouldn't help my problem)
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed is a pinnacle in their own mind. 5 Speed's Avatar
    Join Date
    Feb 2002
    Location
    Santa Barbara, CA
    Posts
    831
    Liked
    62 times
    Images
    19
    Rep Power
    1646
    Default Re: 06 Tundra Front Caliper Brake lines corrosion solution with stainless lines?
    With all the tundra frame rust issues if you actually drive through salt water I bet your frame will rot off before your brake lines rust through
  4. #3
    Join Date
    Nov 2008
    Location
    Outer Banks
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    well gee thanks for the insightful advice, such mental prowess i am in awe.
  5. #4
    Supercharged Member Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    49
    Posts
    2,686
    Liked
    64 times
    Images
    45
    Rep Power
    2514
    None of the aftermarket lines replace the factory hard lines only the rubber portion.
    Remmy700P likes this.
    2006 Tundra DC with: Eclipse AVN5500 Navigation System, Kicker IX500.4 driving infinity kappa 60.9cs door speakers, Kenwood KAC-X20 driving an infinity kappa 100.9w sub in sound ordnance bass bunker, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Ballistic Enigma 20x9 wheels & Nitto nt420 285/50R20 tires, Hellwig 7697 & 7700 sway bars, Stinger SPP2150 Battery, Big 3 wire upgrade with 1/0 Raptor, Rancho RS5000 struts/shocks, Dynomax VT 17956 muffler, EBC Slotted Sport Rotors & Yellowstuff Kevlar pads, Russell SS brake lines, Cheetah GPS Mirror, Volant CAI
  6. #5
    Join Date
    Nov 2008
    Location
    Outer Banks
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thanks for the info!!
  7. #6
    Junior Member Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind.
    Join Date
    Sep 2012
    Location
    North Carolina
    Posts
    134
    Liked
    43 times
    Rep Power
    1663
    Stainless will corrode too.
    The benefit to stainless braided lines is less expansion while under pressure, therefore better brake feel. If you want stainless brake lines only for corrosion purposes, you will be wasting your money.
  8. #7
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,670
    Liked
    857 times
    Images
    24
    Rep Power
    21818
    Quote Originally Posted by Sportsmanphil View Post
    where did you get this information?
    InlineTube.com sells stainless steel hard brake lines (not sure if they have prebent for tundra or we have to bend our own) and states:
    "Both stainless and OEM steel perform exactly the same for braking. The difference is the material. Both lines have the fittings on the ends, cloth wrap and spring wrap identical to the factory originals and are very hard to tell apart. The OEM steel lines are a tin coated steel line identical to the original and will last as long as the original. The stainless steel lines will neverrust tarnish or corrode."
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  9. #8
    Join Date
    Sep 2012
    Location
    North Carolina
    Posts
    134
    Liked
    43 times
    Rep Power
    1663
    Quote Originally Posted by SuckersWalk View Post
    Stainless does rust, just does it a touch slower than non stainless.
    I believe the OP is talking about braided brake lines which replace the rubber section of brake lines. It appears you are talking about the hard pre-bent lines.
    Replacing the rubber brake lines with braided stainless lines is what I am talking about in my first reply. Replacing the hard pre-bent lines with stainless will have no effect on brake pedal feel.
  10. #9
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,670
    Liked
    857 times
    Images
    24
    Rep Power
    21818
    I thought he was looking for something to replacing his rusty hard lines.
  11. #10
    Join Date
    Sep 2012
    Location
    North Carolina
    Posts
    134
    Liked
    43 times
    Rep Power
    1663
    He may be.. I assumed when he said braided he was talking about flexible lines..
    I live below the rust belt but my Tundra has a touch here and there.. I think I might take the bed off and POR the underside of the bed, frame and axle..
    Once upon a time you paid for under coat at the dealer as an extra. No one does that anymore.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
