Front and Rear Springs, Strut and Shock Replacement
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Thread: Front and Rear Springs, Strut and Shock Replacement
  1. #1
    Rookie Boeing767 is on a distinguished road.
    Join Date
    Nov 2012
    Location
    MI
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default Front and Rear Springs, Strut and Shock Replacement
    I have an '02 Tundra (215K) that has never had any suspension component replaced.
    Next week my mechanic is replacing front springs, struts and associated hardware, e.g. mounting brackets, etc...
    In the back shocks are being replaced.
    I'm also having the brakes done (front - PowerStop rotors and pads / rear- Beck Arnley Brake drums and shoes).
    My quandary concerns the front suspension. I am looking at the Monroe Quick Strut replacement. I am strictly a street guy with most of my driving being highway.
    The alternatives are: buy the quick strut and use a KYB or Bilstein 5100 strut rather than the Monroe product at least that way I get all the new components in one easy package.
    Or, buy an OEM coil spring and either KYB or Bilstein 5100 strut but now have to purchase all the extras required to do a good replacement job. Also, is the Monroe Coil Spring a decent spring considering my driving habits?
    For the rear probably a KYB or Bilstein 5100 replacement.
    Not looking to 'lift' the truck. Just want to stay stock. From what I've read the Bilstein 5100 will work for that.
    Any thoughts and or comments greatly appreciated.
    Cheers
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp is a pinnacle in their own mind. bnjp's Avatar
    Join Date
    Feb 2012
    Location
    Knoxville, TN
    Posts
    214
    Liked
    51 times
    Rep Power
    1562
    Default Re: Front and Rear Springs, Strut and Shock Replacement
    IMO the Monroe strut would be a downgrade. I used OME springs and Bilstein shocks.
    2003 SR5 4x4 Access Cab
    5100 Bilstien shocks on 3rd notch -- 265/75/r16 Nitto Terra Grappler tires -- Hellwig rear sway bar
  4. #3
    Join Date
    Nov 2012
    Location
    MI
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Would replacing the Monroe Quick Strut with the KYB or Bilstein strut be an adequate compromise? There just isn't any definitive information out there concerning the Quick Strut. I hate to spend all the money for each individual component, but I will, if the Monroe is really inadequate.
    Thanks for your response.
  5. #4
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    293 times
    Rep Power
    12181
    What about going with OME springs, and since youre not lifting, go with Bilstein 4600 or OME struts? Why go with 5100s adjustables if youre not going to lift and take advantage of their adjustability? The 4600s are what Toyota uses in their stock TRD suspension packages.
    Call Wheelersoffroad to see if they have the 4600s, I know they carry 5100s. They also have the Tacoma isolators you would need with the OME coils, as well as lift blocks or AALs, and Ubolts, if you need to just level out the rear.
    Slee Offroad also has the OME coils and OME Nitrocharger struts to go with them.
    Either way, both places should have everything you would need, all in one order.
  6. #5
    Join Date
    Nov 2012
    Location
    MI
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks Stone Blue.
    That was one question I did have as I was reading a lot about the adjust-ability of the 5100's. Certainly makes sense to go with a strut that is non-adjustable since I am not looking at lifting.
  7. #6
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    Avoid the QuikStrut product! Repeated anecdotal evidence says that coil sag is horrible. Monroe just does not have the engineering experience in the light truck/SUV market.
    I would contact AJUSA.COM or SHOCKWAREHOUSE.COM and see if they have the Bilstein 4600 (aka "HD") shocks and struts in stock. You can go OME for the coils, or just pick up a replacement OEM set. TOYTEC.COM also has stock height replacement Eibach coils that will work as well. IIRC, they're about $160 for the pair.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  8. #7
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    293 times
    Rep Power
    12181
    Slightly offtopic, but anyone know why all the AJUSA threads in the Vendor forum and Group Buy/Special Offers forums disappeared?...Are they no longer a site sponsor?
  9. #8
    Junior Member yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future.
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    I would recommend the Bilstein HD shocks and struts. That's what I have on my truck for the past 60,000 miles or so. Slightly stiffer than stock and handles great!
  10. #9
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    339
    Liked
    181 times
    Rep Power
    5945
    If you're looking for factory ride get the Bilstein 4600's. AJUSA.com has them on sale right now for $81 for the fronts and $60 for the rears with free shipping until the 25th. That's what your truck came with from the factory
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
  11. #10
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Quote Originally Posted by UPbuilder View Post
    If the Bilstein 4600's are the same thing as the HD's, then I'm pretty sure they did not come on Tundras from the factory. Not even the TRD models. They are stiffer than factory shocks. I think most Tundras came with Tokicos?
  12. #11
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by yamatoy View Post
    Bilstein made the TRD shocks for Toyota. The 4600 series are the aftermarket equivalent.
  13. #12
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Quote Originally Posted by Remmy700P View Post
    Aren't the 4600's stiffer though?
  14. #13
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    293 times
    Rep Power
    12181
    Well, I doubt they are any stiffer than the 5100's, which are touted as an off-road shock....And which the OP was considering getting.....
  15. #14
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Quote Originally Posted by Stone_Blue View Post
    I was just inquiring as to the stiffness of the 4600's due to the post made by Upbuilder that said he should go with them if he wants a factory ride even though the 4600's are indeed stiffer than factory shocks.
  16. #15
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    339
    Liked
    181 times
    Rep Power
    5945
    Imo they are going to be the closest thing to the factory ride with an aftermarket shock. I have the 5100's and they are not stiff and harsh, firmer than stock, yes, but they soak up the little stuff comfortably while providing better road feel and a huge improvement off road.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
