Valve cover bolts
+ Reply to Thread
Results 1 to 11 of 11
Thread: Valve cover bolts
  1. #1
    Junior Member yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future. yamatoy has a brilliant future.
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Default Valve cover bolts
    So I noticed a leak coming from where the passenger side valve cover meets the head. So I went to the dealer to pick up a new gasket and spark plug tube seals. When I went to remove the valve cover bolts, they all unscrewed with virtually no resistance. The Haynes manual says the torque specs for these are 53 in/lbs which obviously is not very tight at all, but these almost seemed like I could unscrew them with my bare fingers! Got me thinking that maybe this is the reason I'm experiencing a leak there. Nevertheless, I'm still going to replace the gasket though. Anyone else have a similar experience? Also, the valve covers have never been removed before, so it's not like someone was in there before and forgot to tighten them down enough.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,043
    Liked
    294 times
    Rep Power
    12181
    Default Re: Valve cover bolts
    Prolly not much help, but I know when I had my 22R's, you only needed to go no more than about a full turn past finger tight. I think you get the leaks mostly because the rubber plugs and gaskets seem to harden up and shrink over time. I usually just loosened and retightened the valve cover nuts whenever I changed my oil to make sure it was all snug. just DONT bump or loosen the cover when you do it...I usually just loosened then tightened one nut at a time. Start with the center two, then do the end two.
    Probably overthinking it, but it was quick and easy, and I never had leaks again after putting in new gaskets and doing this. (I had three different 22R motors I did this on).
    Also, did you use FIPG sealer or RTV at the front corners of both heads with the gasket?
  4. #3
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Thread Starter
    Quote Originally Posted by Stone_Blue View Post
    I actually still have the valve cover off. The manual states to use RTV sealant, so that is what I was going to go and pick up from Autozone or wherever. What exactly is FIPG sealer? The manual does state to apply RTV sealant to the semicircular plugs at the BACK of the head. It doesn't mention anything about applying to the front though. Perhaps the 22r motor is different?
  5. #4
    Veteran Member PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some.
    Join Date
    Jun 2003
    Location
    sarasota fl
    Age
    57
    Posts
    639
    Liked
    44 times
    Rep Power
    993
    Odd as hell........but the last two days I was smelling oil..........thought that it was someone else, but today I went to the woods and when I stopped , I smelled it agian .....turnsout thevalve cover bolts were REAL loose........went home and "snugged" them up .....6 out of the lower 8 , 4 on each side........were lose.........went to town and back approx.......40 45 miles and no smell now........
    STATE OF CONFUSION
  6. #5
    Supporter arseum has disabled reputation
    Join Date
    Nov 2005
    Location
    Katy, TX
    Posts
    588
    Liked
    88 times
    Images
    11
    Rep Power
    4498
    I have the same issue on my V6, but I can only easily access like 8 of the 12 bolts. When I do get around to installing a new gasket and tightening all of the bolts, I am going to use blue loctite. Oh, and the dealer quoted $700, which is almost all labor! Hope ur V8 is easier.
    Oil leak
  7. #6
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Thread Starter
    Quote Originally Posted by arseum View Post
    Oil leak
    $700 to replace valve cover gaskets?! F*#ckin crooks! Went ahead and checked the valve cover bolts on the other bank as well today and sure enough all were loose. All bolts on the V8 are easily accessible with a swivel socket.
  8. #7
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,043
    Liked
    294 times
    Rep Power
    12181
    The FIPG is just Toyota's fancy version of RTV or similar sealant. (I'm not sure exactly what its made of). If you have the 2UZ, take a look at the diagrams in the FSM again...You should see a diagram right below the one that has the arrows pointing at the rear plugs...You should see two small squares at the front corners of the head, right near the cam gears, showing where to use the RTV.
  9. #8
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Thread Starter
    Too late, I already put everything back on. I put RTV on the two rear plugs only.
  10. #9
    Veteran Member george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60 creates their own distinguished roads. george60's Avatar
    Join Date
    Mar 2003
    Location
    Northern California
    Age
    71
    Posts
    662
    Liked
    2 times
    Rep Power
    451
    My 2003 Tundra Access Cab V8 is just coming on to 9 years of age and 71,000 miles. I went out and checked the valve cover bolts. No oil leakage. Clean and shiny. I power wash the engine compartment regularly.
    But thanks for the "heads up". I'll check all the bolts tomorrow. Regards.
    "... nevertheless, thou may chose for thyself ..."
    Mormon Doctrine
  11. #10
    Veteran Member INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind.
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    584
    Liked
    42 times
    Images
    7
    Rep Power
    2080
    Yes, mine were loose too when I went to change the gasket. Tightening them to 53" lbs probably would have solved the leak problem, but I changed the gasket and plug seals anyway. The plug seals are a real bugger. Make sure you have a few extra. They are easy to damage.
  12. #11
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    176
    Liked
    10 times
    Blog Entries
    1
    Rep Power
    104
    Thread Starter
    Quote Originally Posted by george60 View Post
    I'd put money on it that they will be loose.
    Quote Originally Posted by INDYMAC View Post
    I was under the impression that the plug seals were the rubber grommet things that go around the underside of each ignition coil. Needless to say, I didn't take the old ones off the valve cover and replace them. By the time I realized what I was supposed to replace, I had already put everything back on.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
