Electric cooling fan kit! - Page 2
+ Reply to Thread
Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 16 to 30 of 113
Like Tree46Likes
Thread: Electric cooling fan kit!
  1. #16
    Junior Member texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96's Avatar
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Default Re: Electric cooling fan kit!
    I can't help but notice that your user name is tundra3400, If your interrested I will need to to find out if the plate will mount the same between the V6 to V8 radiators because the part#'s are different from V6 to V8 but all yrs are the same from 2000-2006.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Junior Member smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some. smokincobra has done just about everything...and then some.
    Join Date
    Dec 2010
    Location
    Illinois
    Posts
    137
    Liked
    19 times
    Rep Power
    837
    subin, I might be interested in this.
  4. #18
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    I am just wondering if you have to drain cooling system to take shroud off the Gen1 like you do on the Gen2 and if I had the shroud I could make the plates and find a member that wants to do this so I could have the cooling fan assembly paid for and then use his truck to do the fitment.
  5. #19
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    327
    Liked
    165 times
    Rep Power
    5076
    Quote Originally Posted by texasranger96 View Post
    I had to pull the upper radiator hose to pull my shroud out.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
  6. #20
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,362
    Liked
    1285 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    You need to drain out a little from the cooling system to remove the shroud. I drained out about a half a coffee can's worth of fluid when I removed my shroud today. One thing that I forgot to do was to place washers back on the studs for the water pump pulley and WOW I knew it RIGHT AWAY. Running without the stock clutch fan and while moving the truck runs the same temperature as before - 192 degrees. Stopped, in a drivethrough, the truck got up to 202 degrees. Outside temperature was 45 degrees.
    UPbuilder likes this.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  7. #21
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    I will sell the kit with controller and everything for the first one as a courtesy for $350.00 and I will not be making much as I will be buying a shroud and then research time and then the time to do the drawings. but it will be a complete bolt on all connections made and the plate will be powder coated.
    Paypal only!
    seanpistol likes this.
  8. #22
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    327
    Liked
    165 times
    Rep Power
    5076
    Quote Originally Posted by Highwaylizard View Post
    Awesome, I was wondering if you'd try this. So far it's been a worthwhile mod and I'm looking forward to an electric fan for next summer. Btw, LOL at the water pump pulley
    Highwaylizard likes this.
  9. #23
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,362
    Liked
    1285 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    Quote Originally Posted by UPbuilder View Post
    The noise it made scared the hell out of me. Glad I caught it right away otherwise it could have been serious. Truck seems to run with a little more power and definitely revs faster. Could be all psychological but the mileage is better already.
  10. #24
    Junior Member GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous. GEE-BEE is more than famous, they're infamous.
    Join Date
    Feb 2002
    Location
    Rancho Mirage, CA
    Age
    53
    Posts
    172
    Liked
    49 times
    Images
    5
    Rep Power
    3086
    I did the Flexalit install. perfect and it was a freebie from Fleaxalite ( sema ) show..
    GB
  11. #25
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    I just don't feel like there kit is designed for the truck as it doesn't cover the radiator, but I guess you can't look a gift horse in the mouth!
  12. #26
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    good eye texasranger, and what kind of dimensions/info will you need in order to replicate the plate?
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 196,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch, 5000K 35 Watt HID Fog Lights
  13. #27
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    I just need a shroud as that is how we did the drawings of the Gen2 kit.
  14. #28
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,362
    Liked
    1285 times
    Blog Entries
    78
    Images
    65
    Rep Power
    173757
    I would be inclined to agree with you but I have a reservation about this. It is my opinion that there are two factors at play here. First, the radiator is over-sized for the truck which is a good thing when people actually use it to tow with. Second, cooling is a function of air passing through the radiator so unless the shroud has space to allow the air to pass through all of the radiator it is not necessary to cover the entire surface area of the radiator.
    Just my two coppers for what they are (or are not) worth
  15. #29
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,077
    Liked
    167 times
    Images
    27
    Rep Power
    6284
    idk if i could take mine off and send it to you so that you could dimension it. i was looking at the cost of a new shroud and its $83 for one shroud and $13 for a second shroud. im not sure if they both are needed but im guessing that the $83 one is the one you would need.
    CBTMA Member
  16. #30
    Rookie markmartin is on a distinguished road.
    Join Date
    Sep 2012
    Location
    arkansas
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    When you get this mod up and running send me a message. I plan on buying one before spring.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
