Electric cooling fan kit! - Page 3
+ Reply to Thread
Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 120
Like Tree48Likes
Thread: Electric cooling fan kit!
  1. #31
    Junior Member texasranger96's Avatar
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    Default Re: Electric cooling fan kit!
    Well I bought a Gen1 Tundra shoud new for a prototyping now I will just need the truck, it was rather easy building for the Gen2 as I have a 2012 Tundra, but I have already found the fans that I want to use, this is what I came up with because the Gen1 has a smaller radiator than the Gen2 and I have to use a smaller fan, but I have been told these have been used on bigblocks Chevelle's!
    SPAL USA
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #32
    Forum Admin Tundradrenalin's Avatar
    Join Date
    Apr 2007
    Location
    Virginia Beach, VA, USA
    Age
    36
    Posts
    8,093
    Liked
    404 times
    Images
    240
    Rep Power
    5011308
    Quote Originally Posted by Highwaylizard View Post
    You need to drain out a little from the cooling system to remove the shroud. I drained out about a half a coffee can's worth of fluid when I removed my shroud today. One thing that I forgot to do was to place washers back on the studs for the water pump pulley and WOW I knew it RIGHT AWAY. Running without the stock clutch fan and while moving the truck runs the same temperature as before - 192 degrees. Stopped, in a drivethrough, the truck got up to 202 degrees. Outside temperature was 45 degrees.
    The shroud on my Tundra was 2 piece. I didn't have to remove any hoses or fluid when I installed my flex-a-lite fans. However, it would have been easier to get the stuff in and out of there without the upper rad hose in the way. But it was doable with it there. The whole install took less than an hour with the electrical work all prepped ahead of time.
    Highwaylizard likes this.
    New to the forum? CLICK HERE!
    Questions about advertising? CLICK HERE!
    Know the facts about Warranties and the Magnuson-Moss Act.
    Link to Amsoil -->
  4. #33
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    Yeah when I did the Dyno testing at MC racing in KC, I drove the truck up there with the clutch fan on and took the electric fan kit with me. When we dynoed it with the clutch fan I swapped everything, in about 15 minutes including draining a little coolant and dynoed it again.
  5. #34
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    I should be getting the Tundra shroud this week so that I can have the draings made for the shroud I am just a scared that $550 is a little much for a electric fan kit for a truck that might have over 100,000 miles on it so I might just go a head and use the lincoln MarkVIII fan as I can sell it for like $350-$400.00 complete. I would prefer to do the dual 13" Spal fans but the price makes me feel uncomfortable, what are your thoughts?
  6. #35
    Junior Member seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    27
    Posts
    455
    Liked
    244 times
    Images
    36
    Rep Power
    13752
    The flex-a-lite kit is $500 isn't it? And you can find a refurbished kit on eBay once in a while for $250+. I would love to buy a kit in the $350 price range, but don't want to sacrifice quality. I would like two fans.
    01 Tundra 4.7L 4x4 AC
    Camburg UCAs, OME coils, Bilstein shocks, 285 Duratracs on AR teflon wheels
    rear ARB locker, All-Pro sliders, homebrewed rear bumper
    build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  7. #36
    Junior Member Localsnap88's Avatar
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    87
    Liked
    24 times
    Images
    1
    Rep Power
    2844
    Quote Originally Posted by seanpistol View Post
    Hey Sean.. and everyone else... right now at AutoAnything.com you can get the Flexalite kit for $459.00 Flexalite Fans, Flex-a-lite Electric Cooling Fans, Flex a lite Cooling Fans - shipped that is! Probably gonna be one of my next couple mods too, after I finally (hopefully) get the suspension squared away this weekend.
    seanpistol likes this.
    2004 TRD AccCab 4x4 - Bilstein 5100s (f&r), OME 885s, Camburg UCAs, diff. drop, Downey HD swaybar links,
    1.25" blocks(rear),
    Airaid Intake Tube & Synthaflow-Filter, 18" Magnaflow (single in/out) , Wheeler's Poly Anti-sway kit, Level 8 Tracker wheels (16x8.5), 265/75/16 Cooper AT3's, AVS visors, Stampede bugshield, clear corners, SS Nerf Bars, Black/Red Euro-tails, LED third-brake light, BigStick stub antenna, Tinted, Adrian Steel toolbox, TRD rolled exhaust tip, Ultragauge, LED interior conversion, Kenwood h/u, Alpine coaxials (f&r)
  8. #37
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    Quote Originally Posted by Localsnap88 View Post
    I am quite certain that is not including the controller and I will sell the kit with the Mark VIII fan with controller and everything, the dual fan kit will not flow the same as the Mark VIII and it will be alot cheaper as well. About 4300CFM's.
  9. #38
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    87
    Liked
    24 times
    Images
    1
    Rep Power
    2844
    Quote Originally Posted by texasranger96 View Post
    no disrespect to what youre doing my man, good stuff. just fyi I do believe that kit I posted IS WITH the controller, as its mentioned in a response to someones question on the listing, and also because a couple weeks ago I believe there was a second Flexalite kit listed, a cheaper one that was just the fans and No controller included.
    Tundradrenalin and seanpistol like this.
    1.25" blocks(rear),
  10. #39
    Join Date
    Dec 2012
    Location
    Bay Area CA
    Posts
    21
    Liked
    0 times
    Rep Power
    3
    I rigged an electric fan when I had a jeep wrangler.. Over time the plastic started to get brittle due to heat and caused cracks.
    I gained about 1 mpg.
    Anyone using this kit come up with MPG gains?
    OP what kind of plastic material are you using for the housing?
  11. #40
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    i believe the OP stated that he would be using 5052 aluminum for the adapter plate to mound the fans.
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 212,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s
    CBTMA Member
    Sometime in the Future:
    Lock-Rite (maybe)
  12. #41
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    To be exact it is 5052 that is CNC'd plasma cut and has a very duarable textured black powder coat finnish, the Spal fans have some type of modified plastic ( same as gun stocks) it is very durable and has 3yr warranty on the fans. The kit that I will be producing will be alot didfferent than the Flexalite.
    The main problem that I have is I need to know if you guys will be able to spend $500-550.00 on the kit for the dual spal 13"s as I would trust it for towing, the cheaper model that I had plans for would be using a Mark VIII single 18" fan for around $350-400.00 that I would not guarantee for towing as it was orginally designed for a Lincoln Mark VIII 4.6. I will be recieving the shroud to do the drawings off today and the fans this week, I am willing to sell the first kit for $500.00 but I will need it soon, as I am getting ready to do the Titan fan kit and I can do them both at the same time, but if I don't have someone interrested on here I will not start on it.
  13. #42
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    Well I just got the shroud in now I just need the fans that I ordered and I can begin the process!
  14. #43
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    is there anyway to determine if the 4.7 shroud is the same as the 3.4 shroud? i really want to convert to electric fans.
    CBTMA Member
    Lock-Rite (maybe)
  15. #44
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    342
    Liked
    61 times
    Images
    3
    Rep Power
    1624
    Thread Starter
    If you get on rock auto and look at the shrouds for the Tundra V8 and V6 radiators, it apears that the water inlets are on the opposite sides and the V8 radiator is an inch" taller. I think I could just build a kit with the Linkoln Mark VIII single 19" fan for that application for like $350-$400.00 totally complete and wired up with a two speed controller, But I would need you to send me your shroud.
  16. #45
    Join Date
    Apr 2007
    Location
    Age
    36
    Posts
    8,093
    Liked
    404 times
    Images
    240
    Rep Power
    5011308
    Quote Originally Posted by bpowa View Post
    Flex-a-lite 775 installed on my 2005 Tundra for a few years now. I kept a mpg log for a while after I installed them. I have 7 months of data that showed a 14% gain in MPG.
    It's pretty significant when you're talking about an engine that gets 14-17 mpg. I'm pretty pleased. Plastic looks good as new also.
    Link to Amsoil -->
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
