Steering issues
+ Reply to Thread
Results 1 to 11 of 11
Thread: Steering issues
  1. #1
    Rookie Chuckster_ca is on a distinguished road.
    Join Date
    Nov 2012
    Location
    Hazelton
    Posts
    12
    Liked
    1 times
    Rep Power
    0
    Default Steering issues
    Hi All,
    I just purchased an 05 with 205K (not sure what that is in miles) on it - it has a 2.5" levelling kit and I'm running Goodyear duratrack 18" studded tires. (275/75/R18). I've noticed while driving at highway speeds that the steering feels a little loose and there's a bit of play - I find myself having to constantly adjust the wheel in order to keep'er straight.
    I've heard sometimes the levelling kits can do this but I'm really new to trucks so can't back that up. Before I bring it in to have it looked at, I thought I'd post it on here and see what you guys think.
    Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,027
    Liked
    293 times
    Rep Power
    11256
    Default Re: Steering issues
    I would speculate tie-rods as primary cause...but you should also check steering rack for leaks, worn bushings/rack looseness, and upper & lower ball joints. Then inspect all the A-arm bushings, too.
    What does the level kit consist of?....Did you buy it with the same tires that are on it, and did the PO give you any history on when the lift & tires were installed? and most important, if a proper alignment was done? Anytime suspension & tires are changed, an alignment should be done. Before going for an alignment, do a search here for "DJs alignment specs".
  4. #3
    Join Date
    Nov 2012
    Location
    Hazelton
    Posts
    12
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    I can't say much about the kit but what I can say is: the truck failed inspection because the guy I bought it off of was running 33's x 12.5 inch tires and they were rubbing against the strut assembly. (the truck was purchased out of province thus the need to have it inspected in order to get it insured).
    I should mention too: there is some humming noise when the vehicle is running at normal and highway speeds which to me, sounds like bearings but what do I know!. I can say that on my camry when I turned sharply to the left, I heard a grinding noise; not to hard to figure out that is was a wheel bearing issue - replaced and the noise went away.
  5. #4
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,027
    Liked
    293 times
    Rep Power
    11256
    With 12.5s, you'll need wheel spacers. The humming is probably the tires rubbing against the Upper A-arm. If the lift is a spacer type, and the tires are rubbing, you're wheel bearings could very well be going, as well as ball joints. Sounds like you need to check the CV shafts/boots as well. Unfortunately, you better basically check your whole front end.
  6. #5
    Join Date
    Nov 2012
    Location
    Hazelton
    Posts
    12
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    thanks - ya, the 12.5's were removed a while ago. I'm running 10.5's or whatever 275mm equates to- maybe the previous owner did some damage running those tires without spacers? I'll ask my buddy to have a look - should I take it it and get an alignment done in the mean time? Apparently there's a shop that has a top of the line machine to do it.
  7. #6
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    845 times
    Images
    24
    Rep Power
    20864
    what kind of maintenance has been done on the truck? with 155,000 miles, it is not unheard of for your front-end to need refreshing (bushings, tie rods, shocks, etc.) if it hasn't been loved.
    humming could be the tires.
    assuming you have 4wd, grease the prop.
    may as well order up a set of steering rack bushings right now; you need them.
    are you shocks original? if so, plan on replacing them and you may as well go with bilstein 5100s what will allow you to yank you level kit and run a shock that is built for the lift.
    i'd do all the work asap and then go get the alignment with DJs specs. doing it now and not having to redo it after you do all the work it needs will only save you time, money, and potentially bad tire wear.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  8. #7
    Join Date
    Nov 2012
    Location
    Hazelton
    Posts
    12
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    The previous owner faxed to me the service records. It shows at 196000 the front and rear shocks were replaced, steering gear replaced (bushings and bolts, rack and pinion), lower ball joints. Aignment done when tires, rims and leveling kit installed. Along with battery replacement, diff and trany fluid change. Timing belt done at 167k.
    So I'm thinking getting the bearings looked at and possibly an alignment since the tires I just put on are new and quite smaller than the one that were on there.
  9. #8
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,088
    Liked
    169 times
    Images
    27
    Rep Power
    6284
    also with a lift you want to set the Caster higher for better highway stability. that will most likely solve the steering issue. like said look up DJs alignment numbers and have it done to them.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 196,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch, 5000K 35 Watt HID Fog Lights
  10. #9
    Join Date
    Nov 2012
    Location
    Hazelton
    Posts
    12
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Thanks - it's on the hoist as I type. Buddy figures maybe tie rods, CV joints. We'll have a look and make the necessary changes before getting an alignment done.
    Regardless of what we find, I will get an alignment and use those specs as outlined in DJ's. About that: do I simply tell the mechanic that I want those exact numbers for those 3 settings? I'm concerned they'll come back and say something along the lines of "oh, those numbers don't match with what Toyota says" or you know, something similar to that.
    Thanks
  11. #10
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    If the alignment tech knows what he is doing and is properly trained on the equipment, he should have no problem meeting/getting very close to those specs. They are all within the Toyota specs predefined in the alignment software so there is no reason whatsoever for them to balk at it. If they do, it means they don't know what they are doing and are not willing to admit it. Find someone else. Ideally, you want to find a shop that uses one of the Hunter alignment consoles and understands the benefits of using the CAMM (Control Arm Movement Monitor) screen.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  12. #11
    Join Date
    Nov 2012
    Location
    Hazelton
    Posts
    12
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Brought it in and this is what they said: specified degrees are not attainable due to rusted sleeves on adj. bolts.
    They did get them to
    Camber: Lf: 0.2. Rf: 0.1.
    Caster: L.f: 1.2. R.f: 1.4.
    Toe: Lf. 0.03. Rf: 0.05
    Total toe: 0.07
    Camber: Lr: -0.5, rr: -0.2.
    Toe: Lr: -0.25. Rr: -0.02.
    Total toe: -0.27
    Dj's specs:
    camber: +0.25 degrees
    caster: +2.00 degrees
    total toe: +0.08 degrees
Posting Permissions
  • You may not post replies
  • You may not edit your posts
