911 - stripped rear diff fill bolt leaking gear oil
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree14Likes
Thread: 911 - stripped rear diff fill bolt leaking gear oil
  1. #1
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Default 911 - stripped rear diff fill bolt leaking gear oil
    Someone helping me do some maintenance on my truck today used an impact wrench to put the 15/16 rear diff fill bolt back in after we topped off the gear oil..... now it's stripped. It won't tighten or come out, just spins. I drove around the block and it's leaking gear oil. I'm supposed to drive the truck from Idaho to Oklahoma this weekend, so I need to solve this quickly.
    What can I do to fix this?! Thanks for the help TS, you helped me change my timing belt successfully this weekend.
    EDIT: I seem to be assuming that I stripped the threads on the diff itself and not just the threads on the bolt. What are the chances the threads on the bolt are all that stripped and I just need a new bolt?
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  2. #2
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Thread Starter
    Default Re: 911 - stripped rear diff fill bolt leaking gear oil
    Tomorrow morning I'm going to attempt to get the bolt out and then tap the hole to a larger size. Wondering if anyone has better advice than that, maybe speaking from experience.
  3. #3
    Rookie 01TulsaTundra is on a distinguished road.
    Join Date
    Mar 2010
    Location
    Middletown, DE
    Posts
    14
    Liked
    2 times
    Rep Power
    0
    Quote Originally Posted by seanpistol View Post
    This is what I would do. You could always swap it out later if you feel uncomfortable with your new large tapped plug.
  4. #4
    Junior Member UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder likes to be on top. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    417
    Liked
    256 times
    Rep Power
    11457
    Try wedging something under it and pry as you turn to get it out. Wood chisels work good for that, if you don't mind dinging them up.
    seanpistol likes this.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, Pacesetter longtube headers, stock cats, Magnaflow 12586's.
    http://thebrakedoctor.com
  5. #5
    Beer Me ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra's Avatar
    Join Date
    Feb 2008
    Location
    Central California
    Age
    25
    Posts
    1,642
    Liked
    360 times
    Images
    57
    Rep Power
    22264
    why in zuseus bunghole would you use an impact on something like that? hope you get it fixed!
    Jason
    It's got 4 wheels with a bed and it starts every time I turn the key.
    If You seek advice, then LISTEN with your EARS not your MOUTH.....
  6. #6
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Thread Starter
    Quote Originally Posted by 01TulsaTundra View Post
    swap it out later?
  7. #7
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    417
    Liked
    256 times
    Rep Power
    11457
    If you can't save the threads you could weld a new bung right on top of the old one. 1/2" pipe plug would work for that.
  8. #8
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,478
    Liked
    1378 times
    Blog Entries
    78
    Images
    65
    Rep Power
    182202
    Wow. Wooooowwwwww wow. Dude. Okay. I need a minute here.
    Alright.
    If you pull on the bolt with a pair of vice grips is it still holding in there? If so there are threads on the far end of the bolt inside the differential holding it in. If you stripped the threads on the differential housing I think the bolt would come right out. It may be possible to band aid this with some rubber and wire wrapped really tight between the nut head and the differential housing but I would not do that on my own truck and drive it.
    I think you can back it out of there using said vice grips and two flat head screwdrivers wedged on either side while turning the bolt with the vice grips accompanied by a simultaneous outward pulling motion with the vice grips. Probably would be even better to have another set of hands to work the flat heads and keep them positioned.
    Going to need to do a REALLY good flush of the differential to get any shavings out of there.
    Hippo likes this.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  9. #9
    Supporter SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,758
    Liked
    924 times
    Images
    24
    Rep Power
    26125
    Quote Originally Posted by ZapcoTundra View Post
    zuseus bunghole
    if it doesn't clear up in a few days, you can probably get a shot for that.
    tundrunk and Hippo like this.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  10. #10
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,306
    Liked
    1241 times
    Images
    216
    Rep Power
    196487
    My good buddy uses his impact gun to tighten everything... except when he helps me on my truck. I hide that damn thing, I hate them.
    What Lizard said sounds reasonable, and if you are going to try tapping that out for the next size thread, be sure to change your fluid before you go driving it. I doubt it will leak enough fluid to cause any harm while driving, the fluid shouldn't touch that hole when cold at rest. When warm and splashing around, it shouldn't leak an amount that will cause harm.
    Good luck, this sucks knowing you just got your truck back from that accident.
    Hippo and seanpistol like this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  11. #11
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Thread Starter
    It's in there. I am pretty confident I'll be able to get it out by prying it and using a wrench simultaneously, then replace the plug with a new one from the stealership. I won't band-aid it. Good thing I have a bunch of gear oil sitting around for a flush... I'll let ya guys know how it goes.
  12. #12
    Veteran Member Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,086
    Liked
    305 times
    Images
    1
    Rep Power
    13247
    Since you are getting ready for a long trip, and are time strapped, I woulda suggested cleaning around the bolt head real good with acetone or something, then using JB Weld or similar to seal around the hex of the plug....Or maybe even just use RTV....THEN worry about a permanent fix when you get back.
    I bet BOTH the threads on the hole, AND the bolt threads are stripped, and like Highway said, the threads further down the bolt that are now past the hole threads, are what is keeping it in.
    Cuz if the threads in the hole were NOT stripped, you SHOULD be able to pry out on the plug, and get it restarted coming out. But if that doesnt work, I bet both sets are stripped, or at least definately the ones in the hole. There are only a few threads in the hole, making it easier to strip than just the ones on the bolt alone.
    And, Man, that really sux!....Yeah, that diff plug does NOT need a whole lot of torque AT ALL!!
  13. #13
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Thread Starter
    Problem is fixed.
    Got the fill plug out with vice grips. Wasn't able to wedge anything behind the plug while it twisted. It appeared to be that just the outer two threads of the diff were damaged, and the threads were smashed flat on one whole side of the plug.
    Bought a new plug and a set of taps. Tap size for the threads in the diff is 18x1.5 for anyone looking in the future. Drained and refilled the gear oil, ready to go.
    Highwaylizard likes this.
  14. #14
    Senior Contributor jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy's Avatar
    Join Date
    May 2002
    Location
    boston, ma
    Posts
    5,268
    Liked
    570 times
    Images
    1
    Rep Power
    295934
    I want to see the vehicle your friend there drives. Anyone using an unregulated impact wrench on a drain/fill plug probably has more problems on their vehicle than yours!
    Hippo likes this.
    "I always give 100% at work: 13% Monday; 22% Tuesday; 26% Wednesday; 35% Thursday; 4% Friday."
    "Failure is not an option; its a lifesytle"
    How to perform a search: Select "Advanced Search" -> Choose the "Single Search Content Type" tab, Enter the "Keyword", Select Search in Forum "1st Gen Tundra", Search by Prefix "any thread", Show results as: Choose either "Posts" or "Threads", then click on "Search Now".
  15. #15
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Thread Starter
    Quote Originally Posted by jack mccarthy View Post
    Surprisingly he is a mechanical engineer that drives a pristine 1984 diesel F-250 that he has done all the work on. He knew he goofed up and we fixed it so I'm not mad. I guarantee he won't use an impact to tighten anything again.
    DanoDavis likes this.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
