2004 Tundra O2 Sensors or ECM
+ Reply to Thread
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Remmy700P
Thread: 2004 Tundra O2 Sensors or ECM
  1. #1
    Rookie NevadaWalt is on a distinguished road.
    Join Date
    Dec 2012
    Location
    Carson City, NV
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default 2004 Tundra O2 Sensors or ECM
    I have a 2004 Tundra that the check engine light came on then later went off. Toyota dealer look at it and it had 4 codes P0032, P0038, P0052 and P0058 but they said they could not diagnose the actual problen unless the check engine light was on when they looked at it. My questions are does the check engine light need to be on at the time of diagnoses before you can determine if the O2 sensors or the ECM is bad? Has anyone had a bad ECM?
    First time poster and have read lots on the forum concerning the O2 sensors. Lots of great information. Thanks in advance.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    Default Re: 2004 Tundra O2 Sensors or ECM
    Those are error codes for the heater circuits of all four oxygen sensors. That they all fired off at the same time is mildly suspicious.
    1. How many miles on the vehicle?
    2. Did all the codes set at the same time?
    3. Did you recently do any maintenance on the vehicle and/or any electrical/battery work?
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #3
    Join Date
    Dec 2012
    Location
    Carson City, NV
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for your response. In answer to your questions:
    1. 65000
    2. Yes
    3. No
    The only thing in common I can find is all the sensors ground through the ECM. That is why I was concerned about the ECM.
    Again thanks.
  5. #4
    Veteran Member 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac likes to be on top. 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    1,437
    Liked
    228 times
    Images
    14
    Rep Power
    12376
    the only thing in common, in my world, is that the dealer is a rapist! did you pull your own codes or did the dealer? that A-hole could be telling you anything to make a $......
    buy a $35 code reader from amazon.com and when the CEL glows next time you can walk into the dealer armed with some facts and see how they treat you-but pretend you're clueless at that time!!!!
  6. #5
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2015 times
    Images
    47
    Rep Power
    120525
    Walt, even if the CEL light isn't on, the previous codes will still be stored in memory. The dealer's statement that they "...could not diagnose the actual problem unless the check engine light was on when they looked at it...." is pure horse****.
    It's unfortunate, but oxygen sensor replacement is a big scare-tactic money-maker for dealer service centers. Typically, they get twice the part cost + $200 or more to replace just one sensor.
    Call around to your local auto parts stores and find one willing to hook up a code reader and have them pull the codes for you -- just to back check the quote. Post back up what they find.
  7. #6
    Join Date
    Sep 2009
    Location
    Posts
    1,437
    Liked
    228 times
    Images
    14
    Rep Power
    12376
    what Remmy said ^^^
  8. #7
    Rookie parkpaul67 is on a distinguished road.
    Join Date
    May 2012
    Location
    Buena Park
    Posts
    12
    Liked
    0 times
    Rep Power
    0
    From my experince all 2 O2 sensor dosnt go bad at one time. you might have a one bad sensor if check engine light off justwait until light comes again see how many codes it show. Nomally problems like yours maybe just intermittent fault codes Since your truck only has 65000miles.
  9. #8
    Junior Member tundra2000boy is on a distinguished road.
    Join Date
    Sep 2010
    Location
    pelican rapids
    Posts
    155
    Liked
    6 times
    Rep Power
    3
    yeah get your own code reader, but if the MIL light goes off it's usually stored in the pcm and i'm sure the dealer has some expensive scan tools that can read history codes, the ones we have at school cost about $2k and can read pretty everything including history codes
  10. #9
    Join Date
    Dec 2012
    Location
    Carson City, NV
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Dealer called, said they found a short in the wiring harness fixed that drove it CEL came on so now they are replacing the computer. Will keep you posted. Thanks for all the info.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
