Difference between 2WD & 4WD rear axles?
+ Reply to Thread
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By silet
  • 1 Post By UPbuilder
Thread: Difference between 2WD & 4WD rear axles?
  1. #1
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,035
    Liked
    293 times
    Rep Power
    12181
    Default Difference between 2WD & 4WD rear axles?
    Does anyone know the difference between the two?....I'm calling around to possibly find a replacement rear axle, and it seems there is a difference between 2WD & 4WD...
    And no, its not just because of gear ratios, or ABS vs non-ABS, or locking vs non-locking... There supposedly is some other difference....???
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter bobbygail@aol.com has disabled reputation
    Join Date
    Jun 2008
    Location
    New Orleans, LA
    Posts
    31
    Liked
    7 times
    Rep Power
    875
    Default Re: Difference between 2WD & 4WD rear axles?
    The flange where the rear driveshaft bolts to the differential is different on 2wd vs 4wd. On the 2wd version there are four bolts that are fixed on the flange unless you take the flange off and remove the bolts (PIA). On the 4wd version there are four bolts you can completely remove to bolt the rear driveshaft onto the rear axle flange. The bolt hole patterns are the same on the 2wd and 4wd flanges. The 4wd rear driveshaft has a slip yoke at the rear that allows for in and out movement. That is the only difference I have noticed. If you have a 2005-2006 you could use either a 2wd or 4wd rear axle. Not sure about other models.
  4. #3
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,035
    Liked
    293 times
    Rep Power
    12181
    Thread Starter
    Thanx! Thats a good start.
    Well, I just did a little more research, and it seems there IS a difference between the gearing on 2WD vs 4WD.
    Even though both "officially" list a 3.91 or 4.10 ratio, the 2WD 3.91s have a 3.916 ratio, with a 47/12 tooth ring/pinion.
    While the 4WD have a 3.909 ratio, with a 43/11 tooth ring/pinion.
    Which means the 4WD is probably quite a bit stronger (less teeth means thicker, beefier teeth, and more meat on the gears themselves).
    Same thing applies to the 4.10 gearing.
    2WD= 4.083 ratio, 49/12 tooth ring/pinion.
    4WD= 4.100 ratio, 41/10 tooth ring/pinion.
    The minute differences in gear ratio MIGHT not make a difference, but for anyone sourcing new gears/diffs/complete axles, that tooth count is definately something to consider. Also, if getting just gears, I bet the shims, spacers and spider gears will be different, due to different thicknesses of the ring gear....Probably other internall diff parts differences as well, like possibly bearings and even carriers.
    So as far as the differential goes, definately best to make sure you stick with either the same 2wd vs 4wd application that you are replacing.
    I still wonder if there are any differences between the housings themselves? I know Toyota has different part numbers for 2WD & 4WD...
    Sooo... I guess my original question is moot at this point, and I better stick to the same application I have (4WD).
    But I was also wondering if an ABS rear could be used to replace a non-ABS.
    I dont know much about ABS, but I'm under the impression that ABS just has sensors installed at the four corners, wired into a module under the hood that is plumbed into the brake lines, and THAT is what controls the pulsed pumping of the brake system?....So everything else at the four corners should be the same as non-ABS? (ie wheel cylinders, shoes, calipers, pads, lines, and the rear brake hardware?)
    Also, if a locking (not true locking, just has an LSD) rear axle, could be installed in place of a non-locking. (This question, I would be inclined to say Yes, other than maybe the flange difference that bobbygail mentioned). But then again, the LSD WAS offered in both 2WD & 4WD flavors.... ??
    Anyone have any ideas?
  5. #4
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,110
    Liked
    175 times
    Images
    27
    Rep Power
    6289
    the axles will also have a ratio of 4:30 if it came out of a 3.4L v6 automatic tundra.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  6. #5
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,035
    Liked
    293 times
    Rep Power
    12181
    Thread Starter
    Quote Originally Posted by tundra3400 View Post
    Yup ...I didnt mention the 4.30s, because all the 4.30s seem to be the same, whether from 2wd, 4wd. All are 43/10 teeth ring/pinion.
  7. #6
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,109
    Liked
    2022 times
    Images
    47
    Rep Power
    121449
    Vehicles equipped with ABS will have some sort of toothed collar on the axle just inboard of the hub.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  8. #7
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,035
    Liked
    293 times
    Rep Power
    12181
    Thread Starter
    Yup...I guess I knew that too. But having the sensors and the rings wont have any other affect on anything, if they are left ungplugged, right?
  9. #8
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,109
    Liked
    2022 times
    Images
    47
    Rep Power
    121449
    Not sure what you're asking. If your vehicle has an ABS system, the ECU will throw a fault code if you do not have all the sensors properly connected and functioning.
    If you don't have ABS, I'm not sure if an ABS sensor ring-equipped axle will fit or not.
  10. #9
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,035
    Liked
    293 times
    Rep Power
    12181
    Thread Starter
    Quote Originally Posted by Remmy700P View Post
    Yup, this one ^^
    I have an '00, so NO ABS installed....I've looked quite a bit, and not many 1 Gen rear axles around the NE....So wondering if it would be OK to use an 03-06 rear WITH ABS, to increase my chances of finding a rear axle...I guess I just need to know if there are any other differences in the rear axle assembly itself, besides just the sensors and rings... like if the sensors arent hooked up, do the rear brakes still work the same as a non-ABS?
  11. #10
    Junior Member silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous. silet is more than famous, they're infamous.
    Join Date
    Mar 2010
    Location
    Poughkeepsie, NY
    Posts
    293
    Liked
    36 times
    Rep Power
    2677
    In most cases ABS axels, diffs and hubs can be used in non-ABS suspensions.
    Stone_Blue likes this.
    2001 Tundra V6 3.4 5 spd manual 4WD
  12. #11
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    346
    Liked
    184 times
    Rep Power
    5945
    Quote Originally Posted by Stone_Blue View Post
    Yup, this one ^^
    The brakes will work just fine using an ABS rear with them not hooked up in a non ABS vehicle.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
  13. #12
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,035
    Liked
    293 times
    Rep Power
    12181
    Thread Starter
    Kewl Thats what I needed to know...So I cant think of anything else that would be a problem using an ABS rear assembly in a non-ABS....That will help me source an axle assembly.
  14. #13
    Join Date
    Mar 2010
    Location
    Poughkeepsie, NY
    Posts
    293
    Liked
    36 times
    Rep Power
    2677
    Stone_Blue, are you looking for a complete rear axle and why? Also what year model do you have?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
