2000 Access cab - will 2003 access cab cap fit?
+ Reply to Thread
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By 4doubleyaD
Thread: 2000 Access cab - will 2003 access cab cap fit?
  1. #1
    Rookie 74kaak47 is on a distinguished road.
    Join Date
    Sep 2012
    Location
    ohio
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default 2000 Access cab - will 2003 access cab cap fit?
    Hello, I have a 2000 access cab SR5, and need a fiberglass cap for the bed. I cannot afford a brand new cap, so I have been searching the second hand market. I have found a few caps listed as fitting 2003-2006, question I have is, will a cap from an `03 fit on a `00? I called a distributer for ARE and Leer, and when I asked this question, I was told that he didnt see any reason they would not be interchangable. I would think the dimmensions would be the same, wondering if the profile of the cab to cap gap would be different. Anyone out there been down this road? I could not find any info on the subject anywhere, and have found lots of good info on this forum on other topics, any help is really appreciated.
    Thanks in advance
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    180 times
    Images
    27
    Rep Power
    6289
    Default Re: 2000 Access cab - will 2003 access cab cap fit?
    i dont see why it wouldnt but for good measure, measure the dimensions of the bed and then get the dimensions of the cap.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  4. #3
    Yes, I know for a fact that it will fit as long as it is an AC specific cap. I have an '01 AC and bought a used ARE from a guy who had it on his '06. It fits perfect. The only difference between a '99-'02 and an '03-'06 AC Tundra, body wise, is the front bumper and grill. The bed box is exactly the same.
    oofy15354 likes this.
  5. #4
    Supporter ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik has done just about everything...and then some. ricqik's Avatar
    Join Date
    Feb 2002
    Location
    Twin Cities, MN
    Posts
    1,446
    Liked
    25 times
    Images
    4
    Rep Power
    973
    dont forget that the stepside bed is different, it is also an access cab truck configuration.
    '00 tundra
    '06 sequoia
    '98 forester
  6. #5
    Rookie TheSkitch6 is on a distinguished road.
    Join Date
    Jul 2012
    Location
    Magna, UT
    Posts
    13
    Liked
    2 times
    Rep Power
    0
    I bought a Leer cap from a 2000 AC for my 2002 AC and they are exactly the same. Hope that helps. If you weren't so far away I'd sell you mine.
  7. #6
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    it'll fit. a cap for a double cab will be off by a few inches.
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
Posting Permissions
  • You may not post replies
  • You may not edit your posts
