Help! Transmission output shaft leak?
+ Reply to Thread
Results 1 to 10 of 10
Thread: Help! Transmission output shaft leak?
  1. #1
    Lurking Member bpowa is on a distinguished road.
    Join Date
    Dec 2012
    Location
    Bay Area CA
    Posts
    21
    Liked
    0 times
    Rep Power
    1
    Default Help! Transmission output shaft leak?
    Guys. I have a 2004 tundra 2wd dc. I saw oil residue splattered under the truck. So i took a pressure wash to verify where the source of the leak is from.
    I see it is comming from the transmission output shaft right near the ujoints is.
    Any idea what part I need to buy and replace? Is it just a shaft seal? And since the transmission is sealed and i bought this truck used. Who knows how much fluid has drained.
    Any advise?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    337
    Liked
    176 times
    Rep Power
    5076
    Transmission output shaft seal. Cheap and easy to replace. You probably didn't lose much fluid but check it anyways.
    Sent from my iPhone using Autoguide
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
  4. #3
    Join Date
    Dec 2012
    Location
    Bay Area CA
    Posts
    21
    Liked
    0 times
    Rep Power
    1
    Thread Starter
    Default Re: Help! Transmission output shaft leak?
    Quote Originally Posted by UPbuilder View Post
    How do I know its really from the output shaft? And how do I check the transmission fluid without a dipstick?
  5. #4
    Lurking Member Tundra1Dan is on a distinguished road.
    Join Date
    Jun 2012
    Location
    Ontario
    Posts
    38
    Liked
    6 times
    Rep Power
    1
    You should have a dipstick,passenger side near firewall or atleast that is where it is on my 04DC.Also search here, if you look behind the u-joint you will see a plug in the end that is known to seep/leak also.
  6. #5
    Join Date
    Dec 2012
    Location
    Bay Area CA
    Posts
    21
    Liked
    0 times
    Rep Power
    1
    Thread Starter
    Quote Originally Posted by Tundra1Dan View Post
    lol.. Man thanks.. ill take another look... I read somewhere on this forum that they are a sealed unit.. Maybe its the 2005 and up..
  7. #6
    Rookie sab26az is on a distinguished road.
    Join Date
    Jun 2012
    Location
    Arizona
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Mine 2004 DC had the same problem. My mechanic advised of a technical service bulletin for this issue. TSB TC007-06. I had to replace the slip yoke, u-joints seal and center support bearing. This started when I purchased a 6000lb trailer to tow.
  8. #7
    Rookie *theTundraMan* is on a distinguished road.
    Join Date
    Dec 2011
    Location
    Austin
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    I have the same issue in my 2004AC, i went to Toyota and they said it is the yolk...there's a bulletin on it, but i dont have the link to it handy...My yolk cost me about $215 from the dealer, and about 3 hours in my driveway...just gotta learn how to not break any more u-joints...
  9. #8
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,087
    Liked
    169 times
    Images
    27
    Rep Power
    6284
    Quote Originally Posted by *theTundraMan* View Post
    breaking u joints lol. my dad told me once how him a a few buddies replaced a u joint in a 60s era chevy dumptruck with a bottle opener and a screw driver in the middle of a landfill access road.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 196,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch, 5000K 35 Watt HID Fog Lights
  10. #9
    Join Date
    Dec 2011
    Location
    Austin
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Just a word from experience, never trust your 18 yr old son to do a u-joint swap without your supervision, ESPECIALLY when his only experience is watching Ian Johnson on Extreme 4x4
  11. #10
    Lurking Member hockeyguy10 is on a distinguished road. hockeyguy10's Avatar
    Join Date
    Apr 2006
    Location
    San Bernardino
    Posts
    27
    Liked
    0 times
    Rep Power
    8
    I had the same issue recently. First from the seal(after sitting, there would be a drop stuck to the lip of the output shaft). I tried changing the seal, still leaked. I found out there is a metal bushing inside the output shaft housing. It helps spread fluid around the yoke. If it wears too much, the fluid goes back to the seal, and can leak no matter how good the rear seal is. Toyota said they only supply the complete housing. They wanted $500 bucks. A friend called his friend at a transmission shop, who sent me to a transmission parts place. I took the housing into them, 10 mins and $30 later, I was out with a new bushing and seal. That stopped the leaking for about a week. Then the yoke decided to leak. You can tell because the fluid spatter was right above the u-joint. I took the drive shaft back off, cleaned the finish down to bare metal on the back of the yoke, and used JB Weld to seal it. All the leaks went away.
    Now that I have fixed the leaks, I was on my way home tonight, and lost 1st gear. As I tried to baby it home, the trans made an awful noise, like I was dragging metal under the truck. Then it would clunk into gear, and so on. I usually back into my driveway. Tonight it clunked and moaned as I got it in. I guess 225,000 miles was too much for it. That, being lifted, and towing my 6000lb trailer 5 times a year for 200 miles for the last few years. Tomorrow I search for a used tranny with low miles.
    04 2wd AC SR5 Debadged
    TC 4.5" lift, 2.5" Sway-a-way coilovers(6" front lift and 3" in rear), 285/75/16 Pro Comp Xtreme Muds, Eagle rims, Flowmaster 50 , AEM Intake, Helix throttle body spacer, Nerf bars, Snugtop deck lid, Pioneer stereo w/Ipod, Alpine door speakers, JL Audio W6 12" sub, RF 500 pro series amp. Clarion remote start alarm.....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
