2003 Ext cab door latch
+ Reply to Thread
Results 1 to 4 of 4
Thread: 2003 Ext cab door latch
  1. #1
    Rookie bachelier is on a distinguished road.
    Join Date
    Nov 2011
    Location
    Kittanning
    Posts
    7
    Liked
    2 times
    Rep Power
    0
    Default 2003 Ext cab door latch
    It appears that the cable which controls the door latching does not release all the way causing the door not to latch at the top. I can push the cable end with a screw driver until it is in position and allows the door to latch. My question is there a spring in this door assembly that controls the cable returning to position? If not how do I adjust the cable? Thx
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some.
    Join Date
    Jun 2003
    Location
    sarasota fl
    Age
    57
    Posts
    639
    Liked
    44 times
    Rep Power
    993
    Default Re: 2003 Ext cab door latch
    have you tried to lube it?
    STATE OF CONFUSION
  4. #3
    Join Date
    Nov 2011
    Location
    Kittanning
    Posts
    7
    Liked
    2 times
    Rep Power
    0
    Thread Starter
    I did try some spray lube. Should I try grease or something else? Thx
  5. #4
    Join Date
    Jun 2003
    Location
    sarasota fl
    Age
    57
    Posts
    639
    Liked
    44 times
    Rep Power
    993
    that was "just" a guess..........other than that I have no idea...........
    STATE OF CONFUSION
Posting Permissions
  • You may not post replies
  • You may not edit your posts
