What Tires To Get?!?!?!
+ Reply to Thread
Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By DanoDavis
  • 1 Post By Remmy700P
Thread: What Tires To Get?!?!?!
  1. #1
    Rookie 00yota4x4 is on a distinguished road.
    Join Date
    Dec 2012
    Location
    Kent,Ohio
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default What Tires To Get?!?!?!
    I know this subject has probably been beaten to death on this site but i couldn't exactly find the answer I was looking for. I have a 2000 Tundra SR5 Reg Cab Long Bed that has been leveled with the bilstein 5100s(top setting) Im wondering if 305/70/16 will fit. Also, what if I go with a 1.5" wheel spacer? Ill be using stock rims also which I think on these first gens are 16x7. If those don't fit I'll probably get some 285/75/16. Been thinking about some Goodyear Duratracs as I can get a discount on them but curious what everyone else is running and how they like them.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis is more than famous, they're infamous. DanoDavis's Avatar
    Join Date
    Jan 2012
    Location
    Inland Empire, CA
    Posts
    98
    Liked
    62 times
    Rep Power
    3283
    Default Re: What Tires To Get?!?!?!
    The search option will *Show you the worrrrllldd*
    I just started a thread about the tires I've been using for some time,meow.
    So I got some new tires.
    kanaduh and tundra3400 like this.
    2000 TRD 4.7 4x4
    Volant Intake
    Electric Fan
    Long Tube Headers, True Duals and BAmufflers (Thanks to Escondidotundra/Dirtydeedsindustries)
    Hellwig 770 Swaybar, Poly. Steering Bushings
    2 1/2 Lift with Bilsteins all around
    Camper Shell
    280HP 360FTLBS at the crank
    19MPG Average
    Ask me how!
  4. #3
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    180 times
    Images
    27
    Rep Power
    6289
    and im pretty sure the 305s wont "fit" without some trimming or pounding on something.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  5. #4
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,113
    Liked
    2029 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by tundra3400 View Post
    Generally, 285s (33") won't fit without a little "sculpting" as well...
    tundra3400 likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #5
    Lurking Member speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal is a splendid one to behold. speed metal's Avatar
    Join Date
    Apr 2010
    Location
    CA, just north of mexico
    Posts
    40
    Liked
    3 times
    Images
    2
    Rep Power
    9
    I have 305/70/16 tires on a 01 AC. Rims have 4 back spacing, Camburg CO's and UCA's. Tires would hit the front bumper on turns so I trimmed it, then later did a full on tube bumper. No rubbing even with dirt bikes in the back and driving in the dez.
  7. #6
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,231
    Liked
    1140 times
    Images
    216
    Rep Power
    191632
    I've trimmed my pinch weld out and I still hit on 285's when I turn and stuff tire, results WILL vary.
    Right tires to get? Tires that fit. 265/75/16
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  8. #7
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,670
    Liked
    857 times
    Images
    24
    Rep Power
    21818
    Quote Originally Posted by tundrunk View Post
    there's no better advice out there.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
