lower ball joints
+ Reply to Thread
Results 1 to 7 of 7
Thread: lower ball joints
  1. #1
    Rookie nanoboy is on a distinguished road.
    Join Date
    Oct 2006
    Location
    gastonia, nc
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default lower ball joints
    Hello,
    I have a 2000, 4.7, 4x4 with 265,000 and it is time to change the lower ball joints. I have never tackled anything like this before, but I am fairly handy. I have read the previous posts about this and I am trying to decide if I can do it myself or I need to hire it out. Has any rookie ever tackled this before? Any adcice?
    Thanks,
    Jon
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow is more than famous, they're infamous. wunderwhatnow's Avatar
    Join Date
    Apr 2012
    Location
    Florida
    Posts
    245
    Liked
    47 times
    Blog Entries
    1
    Rep Power
    3010
    Default Re: lower ball joints
    I might be doing the same soon I got some clunking going on and I figure easiest way. To fix it is replace everything . Toyota keeps telling me everything is fine but trust me the clunk is not fine. I've changed my timing belt already so I wont let the suspension work scare me off. It's the money for parts that's hard to come up with
    As I drive through the woods I stop to offer a hand to jeeps, dodges, chevys, and fords. They just cant believe I stopped right next to em and never got stuck! This Yota Uses the I-Force!
  4. #3
    Senior Contributor jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy wants you off his porch. jack mccarthy's Avatar
    Join Date
    May 2002
    Location
    boston, ma
    Posts
    5,230
    Liked
    534 times
    Images
    1
    Rep Power
    290957
    It's a relatively easy job if you have the right tools. Advanced Auto has a 5 piece front end kit that has the proper tools to pop out both the tie rod and ball joint that you can borrow for $100 (fully refundable).
    If you had the prior ball joint recall performed you may run into issues like myself of them overtorquing the ball joint nut and the use of oversize cotter pins.
    Since your replacing them, the cotter pins can be cut flush with the threads if you can't remove them and the use of an impact wrench may or may not be necessary. I've used an impact to remove the 4 bolts from the knuckle/spindle only because too much locktite was used and I couldn't wrestle it off by hand. I ended up tearing both ball joint protector shrouds. I'd be careful not to damage the left one as there is no replacement part at the moment (Toyota lists the same part # for both and they are NOT identical). It might be best if you apply some heat or rust penetrant from the top side to help break the loctite bond and take them off with a small 15" breaker bar/socket wrench if necessary. Since your both from the south, rust shouldn't be an issue.
    "I always give 100% at work: 13% Monday; 22% Tuesday; 26% Wednesday; 35% Thursday; 4% Friday."
    "Failure is not an option; its a lifesytle"
    How to perform a search: Select "Advanced Search" -> Choose the "Single Search Content Type" tab, Enter the "Keyword", Select Search in Forum "1st Gen Tundra", Search by Prefix "any thread", Show results as: Choose either "Posts" or "Threads", then click on "Search Now".
  5. #4
    Join Date
    Apr 2012
    Location
    Florida
    Posts
    245
    Liked
    47 times
    Blog Entries
    1
    Rep Power
    3010
    Nope no rust here. ;-) just gotta get a new jack my two ton looks ready to snap the wheels off.
  6. #5
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    If you don't have any rust, it isn't that hard, just time consuming. There are a lot of short cuts that I took when doing it, but I would avoid them if I were you.
    Loosen lug nuts, lift front end on stands, remove tires. Remove brake calipers and rotors, put them aside. Remove coilover assembly to get rid of the tension(this can be skipped if you have extra hands around but can get dangerous). From here you just have to pull the outer tie rod end off, pop the lower ball joint out of the spindle, then remove the 4 bolts. Install is the opposite of removal, use penetrating lube and locktite, good luck.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  7. #6
    Veteran Member CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon's Avatar
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    23
    Posts
    560
    Liked
    61 times
    Images
    26
    Rep Power
    5420
    Pretty easy to do. Once you have the front end on jack stands and the front tires off, I would jack up the LCA (just an inch or so) to take the strain off of the four bolts on the LBJ/spindle (can unbolt the shock for extra safety). Unbolt the four bolts (evenly), move the spindle/brakes to the side (helps to have a small jack stand to set the bottom of the spindle on), remove TRE from the LBJ, and remove the LBJ from the LCA. Putting it back together is just the reverse procedure.
    Same thing tundrunk said, but just a different order. You can remove the TRE first, can take the brake calipers off if you want, doesn't really matter as long as you don't put stress on your brake lines, and don't put stress on those four bolts (They will strip!).
    It's helpful if you rent a ball joint press. If you don't have any rust and you're taking your time, you're looking at probably 2-3 hours.
    Check RockAuto.com for Moog ball joints. They're priced cheap and are built really well.
    2000 Tundra SR5 2WD... Camburg UCAs, Camburg 2.5" coil-overs, Deaver 10-packs, Bilstein 5100s, Moog LBJs, BFG A/T 285/75/16s, TRD bead-lock wheels, K&N air filter, 18" MagnaFlow muffler, clear corners, Sylvania fog/headlights, full LED conversion, Kenwood head unit & 6-3/4" 3-way speakers, Sound Ordnance B-8PT 8" subwoofer, Coverking neoprene seat covers... so far...
  8. #7
    Join Date
    Apr 2012
    Location
    Florida
    Posts
    245
    Liked
    47 times
    Blog Entries
    1
    Rep Power
    3010
    Thanks for all the advice will let everyone know how it went when it finally gets done
Posting Permissions
  • You may not post replies
  • You may not edit your posts
