Question Poor fuel mileage on 2000 3.4
+ Reply to Thread
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By tundra3400
Thread: Poor fuel mileage on 2000 3.4
  1. #1
    Rookie chatfield is on a distinguished road.
    Join Date
    Aug 2012
    Location
    Colorado
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Default Poor fuel mileage on 2000 3.4
    Just seeing if anyone has had a similar problem. I was getting a lean code....replaced the mass air flow sensor. Code is gone but now my fuel mileage is significantly less which is the opposite of what I anticipated. Does anyone have any suggestions?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,668
    Liked
    856 times
    Images
    24
    Rep Power
    21818
    Default Re: Poor fuel mileage on 2000 3.4
    significantly less? as compared to what? what are you getting now?
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  4. #3
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    Give us some reference points to work with. What was your mileage previous and what is it now? How long have you tracked your mileage? Also, colder temperatures equate to longer warm-up times and combined with winter-blend fuel will ding your mileage.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  5. #4
    Veteran Member kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family.
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    773
    Liked
    87 times
    Images
    48
    Rep Power
    5746
    What are you running for tires? What was the actual code that was read? What is the current mileage on the truck, and what maintenance and mods have been done?
  6. #5
    Lurking Member Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod's Avatar
    Join Date
    Oct 2012
    Location
    Sacramento
    Posts
    24
    Liked
    8 times
    Rep Power
    865
    Did you clear your ecu's memory during/after swapping MAFs (either with code-reader or by disconnecting battery for 10 minutes or so)?
    FWIW, with my 3.4L I get anywhere from 16.5mpg @ 75mph to 22mpg @ 55mph on the highway and ~14mpg city. I also get roughly 0.5 mpg better fuel economy with 88-89 octane vs 87 (counter-intuitive because 87 octane actually has more energy content per volume). The truck idles noticeably smoother on mid-grade fuel too.
  7. #6
    Join Date
    Aug 2012
    Location
    Colorado
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Been off for a while thanks for replies...I used to consistantly get 18 to 20 mpg. The code was a bank 1 system lean. Code was cleared before new maf. Theres 200,000 on it and I'm running cooper discoverers atp. Now I'm getting around 14 or 15 consistantly.....same driving conditions. No codes truck runs great.
  8. #7
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    179 times
    Images
    27
    Rep Power
    6289
    Quote Originally Posted by chatfield View Post
    my 2000 3.4 gets close to the same mileage your talking about. ill get 20-22 on the highway in the summer and i get 14-16 around town in the winter and its a little better in the summer. just lay off the pedal and get her into overdrive as soon as possible and keep her there and she wont chug gas.
    buglao likes this.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
Posting Permissions
  • You may not post replies
  • You may not edit your posts
