New 5100's Installed.......again.
+ Reply to Thread
Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By tundrunk
  • 1 Post By TheGryme
  • 1 Post By Stone_Blue
Thread: New 5100's Installed.......again.
  1. #1
    Supportive Supporter TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme's Avatar
    Join Date
    Sep 2004
    Location
    Wrightwood, CA
    Posts
    923
    Liked
    37 times
    Images
    25
    Rep Power
    2904
    Default New 5100's Installed.......again.
    That was fun. (the forth time is always fun!!!!!!!)
    This time I set them to the forth clip setting.....the truck is setting nice right now.
    There was some difficulty getting the shock shaft to go thru the end plate (FSM calls them a suspension support) with the Bilstien supplied new rubber cushions (doughnuts)....they were too thick installed in any configuration to make them fit.
    I ended up having to cut the inside (lower) one down on both sides....just enough to get the threads to stick thru and start the nut.
    What a PITA.
    Now I've looked at the FSM and it doesn't show 2 rubber doughnuts (cushions) only 1 on the top!!!!
    I think every shock I've ever replaced had 2 rubber cushions, one on each side of the frame or mount....
    I hope I didn't phuck up and they don't break again.
    TheGryme Do It Right, No One Remembers. Do It Wrong....No One Forgets!
    '04 Tundra DC
    Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, 5100's Front & Rear, Total Chaos UCAz, Toyo Open Country A/T 265 75 16 ~ 6 Ply's, Magnaflowed, UNIChipped, True~Flowed (w/ Secret AirBox Mods!), DeBadged, ScanGaged, XM'ed, a Few Scrapes and Dings.....Yeah!
    '92 4Runner
    Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
    '04 YZ250F
    Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, Maxxis Desert IT Tires, ASV Controls....
    '87 Nissan Pathfinder......gone but not forgotten.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    293 times
    Rep Power
    12181
    Default Re: New 5100's Installed.......again.
    Thats because the top plates come with a bushing already press-fit on the bottom side.
    I posted pics here: http://www.tundrasolutions.com/forum...uestion-print/
  4. #3
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,634
    Liked
    845 times
    Images
    24
    Rep Power
    20864
    you are on your forth set of bilstein 5100's on your tundra? wth dude?
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  5. #4
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    Quote Originally Posted by SuckersWalk View Post
    He must not be a tame driver.
    tundra3400 likes this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  6. #5
    Join Date
    Sep 2004
    Location
    Wrightwood, CA
    Posts
    923
    Liked
    37 times
    Images
    25
    Rep Power
    2904
    Thread Starter
    Quote Originally Posted by tundrunk View Post
    Yeah.......that's putting it mildly!
    It's a 4 x 4 truck and it gets treated and used as such. But it is well cared for and thanked kindly for it's service!
    I'm still wondering if the extra rubber thingys I installed on the 5100's will cause any problems!
    6 inches of new snow this morning and once again the mighty Tundra was first to make tracks!
    YeeeHaaaaaaa!
    '04 Tundra DC
    '92 4Runner
    '04 YZ250F
  7. #6
    Lurking Member Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod has done just about everything...and then some. Pushrod's Avatar
    Join Date
    Oct 2012
    Location
    Sacramento
    Posts
    24
    Liked
    8 times
    Rep Power
    865
    4th set? wow... Are you having the worn ones rebuilt, or just replacing them?
  8. #7
    Join Date
    Sep 2004
    Location
    Wrightwood, CA
    Posts
    923
    Liked
    37 times
    Images
    25
    Rep Power
    2904
    Thread Starter
    I had one rear blow a seal, replaced both rears.
    One front blew a seal, replaced both fronts.
    Both fronts lost the lower vulcanized bushing/ mount.....replaced both again.
    This last time the drivers side front lost the lower bushing again.....I kept driving it for a couple of weeks. I was out playing in some fresh snow and hit a big hole I didn't see and tore the lower mount completly off the shock! Fortuantely the shock got caught on the lower "A" arm and I was able to limp it home without any further damage.
    I replaced them once again.....
    '04 Tundra DC
    '92 4Runner
    '04 YZ250F
  9. #8
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,634
    Liked
    845 times
    Images
    24
    Rep Power
    20864
    are these being made in china now? that would explain the drop off in quality.
  10. #9
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    293 times
    Rep Power
    12181
    Wow...If youre wheeling hard enough to kill the bushings and blow seals, isnt it about time (and wouldnt it be cheaper in the long run, and less of a PIA to keep replacing them), to think about getting some reservoired coil-overs? Like some Kings, Icons or Fox's?
    ZapcoTundra likes this.
  11. #10
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    Doesn't Bilstein offer free replacement lower bushing sets for the 5100s??
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  12. #11
    Veteran Member Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24 likes to be on top. Derek24's Avatar
    Join Date
    Feb 2007
    Location
    Sunnyvale,CA
    Posts
    1,335
    Liked
    126 times
    Images
    108
    Rep Power
    11913
    You need a gopro and a YouTube account!
    2000 Tundra TRD 4x4: 5100's & OME 885~Camburg UCA's~3 Leaf Progessive Pack~ARB RD129~JBA Headers~14" Magnaflow single out~Volant CAI~Raceline wheels~265 MTZs~re-badged black~WAAG Push Bumper~(4)55W 6000K HID Spot Lights~Diff breather mod~clear corners~TC Bushings~No Sway Bars~35%/5% tint~Sound-deadening everywhere
    Life's a bore, I'm going pig hunting...
  13. #12
    Join Date
    Sep 2004
    Location
    Wrightwood, CA
    Posts
    923
    Liked
    37 times
    Images
    25
    Rep Power
    2904
    Thread Starter
    Quote Originally Posted by Remmy700P View Post
    Shockwarehouse says the lower bushings are vulcanized into the shock, so they are not replacable. I could probably find something that would work if I had that kind of time.....
    '04 Tundra DC
    '92 4Runner
    '04 YZ250F
  14. #13
    Join Date
    Sep 2004
    Location
    Wrightwood, CA
    Posts
    923
    Liked
    37 times
    Images
    25
    Rep Power
    2904
    Thread Starter
    Quote Originally Posted by Stone_Blue View Post
    Then I'd need wheels and bigger tires......it never ends!
    '04 Tundra DC
    '92 4Runner
    '04 YZ250F
Posting Permissions
  • You may not post replies
  • You may not edit your posts
