any of you guys try one of these??
i am looking at replacing 4sensors and expecting the worst
If you use a torch on the pipe bung you probably won't strip anything and the sensor will come out.
2001 Tundra V6 3.4 5 spd manual 4WD
You can get a re-threading tool at any auto part store if the manifold is stripped from the O2 Sensor. Dealer stripped the hell out of my manifold when they replaced one of mine. I had hell getting it out. Hell of a time. The threads were stripped pretty good.
Actually I got a spark plug re-threading tool from Napa that had the correct size on the other side of it. Auto stores should have a O2 sensor re-threading tool itself at least I know autozone does.
2002 Tundra 4x4 Extended Cab. 4.7 V8 Automatic
Valvoline Synthetic in the Engine. Royal Purple in the rear differential, front differential & transfer case.
Leer camper shell, matching color. Toyo Open Country AT tires.
