Help! 06 Tundra died at full throttle 70mph????? - Page 3
+ Reply to Thread
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 86
Like Tree33Likes
Thread: Help! 06 Tundra died at full throttle 70mph?????
  1. #31
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    341
    Liked
    182 times
    Rep Power
    5945
    Default Re: Help! 06 Tundra died at full throttle 70mph?????
    Quote Originally Posted by jsncal View Post
    Maybe I did not describe the problem or my approach to replicate it correctly, but I assure everyone this is not Operator error. There is a problem with the vehicle. I can make this problem happen without CC, when I rev it up real high, this is not my driving style. I am trying to replicate a problem scenario, which obviously points to a problem. I don't have traction control.
    I also was thinking fuel problem, I guess I'll have to take it to the shop because the fuel filter is in the tank (I don't see it under the vehicle) and that sounds like a pita. Also, just thought I'd mention another possibly unrelated detail. This truck sucks to fill up with gas. The pump will keep clicking off unless it is held pushed all the way into the fill nozzle. I've heard people saying this is from clogged fuel tank vent, is this correct? could this affect the fuel flow? I know, its a long shot but while I've got everyones attention.
    Thanks for the good suggestions.
    And come on.....I've owned only Toyota trucks since my old 84 xtracab, to my 99 tacoma and now the tundra....and a few inbetween They have all been great to own, well engineered machines. The day you tell me; if I floor my Toyota V8 up a little hill too hard it might refuse and instead shut off, I'm buying an F150. Or better yet, your expectations of your vehicles are entirely too low, and maybe you should drive an F150. Good day.
    Yes it could. If air can't get into the tank then fuel is giong to have trouble getting out. Under full throttle you may be drawing more fuel out then air can get in and once you get out of it and allow it to catch up it's ok again.
    Remmy700P likes this.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #32
    Rookie TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001 has done just about everything...and then some. TTU2001's Avatar
    Join Date
    Dec 2006
    Location
    Lewisville
    Posts
    10
    Liked
    4 times
    Rep Power
    0
    First...thanks...I have been on this site since 2003(through two names due to lost logins). I am replying in this post because it is the closest 'symptom' to what I am experiencing.
    BASICS: I have a 2000 Tundra Limited V8 2wd. I currently have 185K and will be doing the next timing belt at 190K(last done at 100K). '
    Symptoms: When accelerating onto the freeway or moving through traffic OCCASIONALLY (1 of 10 times) and never replicated in a particular way....the engine will lose all power. Let me make it clear, the engine never dies. Today, I had more space ahead of me, so when this happened(4500 rpm) I kept my foot in it. The engine simply returns/stays at idle, even with the pedal down. Release the pedal and gently ease into the throttle, any everything seems to be fine. NEVER have any lights or warnings come on throughout these ordeals.
    THOUGHTS: (1) The engine didn't race with the foot in it, so I am doubtful of any transmission issues(although I am still on the original which had issues of being problematic in the 2000 model)
    (2) The theory some have posted of the fuel filter could definitely be the culprit. I have never replaced the darn thing--never had a need.
    (3) Looked in my Haynes manual...where is this gas tank breather you all are referring to?
    (4) Throttle body sensor...at a loss here.
    I have had this truck for 13 years...since new. It's cost a pretty penny in the last 2 years(rear axel seals, steering rack plus the third brake job and new tires...of course the last two are just maintenance issues. I would like to hear some ideas from you all on this issue. Price points would be great too.
    SuckersWalk likes this.
  4. #33
    Junior Member cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some. cmichtrd has done just about everything...and then some.
    Join Date
    Dec 2006
    Location
    Middle of the Mitten
    Posts
    55
    Liked
    10 times
    Rep Power
    848
    Not to butt in, but I am amazed at the thought of hitting 4500rpm's as being "normal." I have had my tundra for 13years and I don't know if I have ever hit 4500rpms.
    Uphill grades means CC off, OD off and foot on the gas pedal.
  5. #34
    Rookie c4yourself2 is on a distinguished road.
    Join Date
    Mar 2009
    Location
    York, PA
    Posts
    17
    Liked
    0 times
    Rep Power
    0
    Sounds like a fuel issue, weak pump, clogging filter, dirty sock at the pump. What is the rev limiter set at with the toyota V-8?
    Chuck
    2006 Tundra Limited 4door 4X4 White/Tan leather int.
    1984 Buick Grand National 11.17 @127.78 1/4 mile blast
    Original owner, no it's not stock... but is a V-6 22.6 mpg highway/ 13 mpg city.
  6. #35
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,645
    Liked
    846 times
    Images
    24
    Rep Power
    20864
    Quote Originally Posted by cmichtrd View Post
    You should try it doing 70mph going up a long steep grade while in 3rd or even 2nd gear. Good times
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  7. #36
    Join Date
    Dec 2006
    Location
    Posts
    55
    Liked
    10 times
    Rep Power
    848
    Quote Originally Posted by SuckersWalk View Post
    No Thanks. I am already nervous enough about my transmission and the OD planetary gears. I go to great lengths not to abuse my transmission.
    Every time I read the initial post in this thread I can only feel a sense of bewilderment. Good Lord, 5000rpms?
  8. #37
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,372
    Liked
    1296 times
    Blog Entries
    78
    Images
    65
    Rep Power
    175260
    Quote Originally Posted by c4yourself2 View Post
    Tundra rev limiter kicks in at around 5200 or 5500 RPMs.
    tundrunk likes this.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  9. #38
    Join Date
    Dec 2006
    Location
    Lewisville
    Posts
    10
    Liked
    4 times
    Rep Power
    0
    I guess I am amazed at those who are surprized that every once in a while....(not very often or frequently)...one must 'giver all she's got' to merge into traffic or make a pass. I have never 'abused' the truck or hot-rodded the truck around. When traffic is moving at 75 mph...you need to merge and move fast. When you're passing on 2 lane highways or farm to market roads to pass water fracking trucks or whatever, I use the V8 power I bought(hence the reason I didn't by the V6). Cruise control...well I never have had an issue...use it on the highway on flat or slightly hilly terrain that doesn't ask a lot of the engine or transmission. I appreciate the responses that give an answer or insight. For those who are amazed at even the possibility of going above 4500 rpm....please understand that I don't believe any of us are looking for a critique of our driving skills, but rather a solution to our problem. Case in point...I have driven my truck for 13 years...I have averaged 17.3 mpg over that time(60% city 40% highway). If I were abusing the engine or 'gassing' it often, that milage would be substantially worse. I fair better than most on the various mpg websites and count myself lucky. I've flirted with the 'keep it under 2000 rpm' theory for maxing gas milage...not worth the 18.6 to 19.3 I could pull in my opinion.
    I will start with the fuel filter and see if there is any resolution to the problem. If not, it appears from many of you my next solution will be to check the 'breathing' of the fuel tank and then eventually the fuel pump if it comes to that.
    tundrunk, CoachRon and DanoDavis like this.
  10. #39
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,215
    Liked
    1131 times
    Images
    216
    Rep Power
    190649
    *Disclaimer, Tundrunk does not condone nor endorse driving in an idiotic fashion, please do not try this at home. The views and opinions of Tundrunk are solely his and do not represent Tundra Solutions.
    Wow, now I feel like I drive crazy... maybe it's a California thing. I've punched it going 70 many times, while going up fair grades. I've let my motor race way more times than any truck motor should in all sorts of stressful conditions, but never had it cut out like described. I may or may not have hit the top speed limiter a few times as well, and it does not cut the power out in the manner described.
    That said, a change in driving habits is recommended. Why are you going so fast and punching it to begin with? It isn't safe and isn't optimal for the longevity of your truck.
    Those things said, first thing I thought was fuel starvation, much like previous members said. Fuel filter, fuel pump, possible clogged injectors, lots of things to check into. I don't feel it is normal for these trucks to cut out as described, however I wouldn't rule out any chance of an issue with the drive by wire...
    CoachRon likes this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  11. #40
    Veteran Member kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes.
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    770
    Liked
    85 times
    Images
    48
    Rep Power
    4291
    TTU2001, does your truck have VSC and traction control? These were optional for 2006 models.
    SR5
    4.7L V8 engine
    Automatic transmission
    Up to 16 cty/21 hwy mpg
    4-wheel drive
    Navigation System (Optional)
    Stability Control (Optional)
    Traction Control (Optional)
    The VSC will cause the motor to power down. "The VSC Off switch actually handles more than just the Tundra’s electronic stability control – it also interacts with Traction Control (TRAC) and the Automatic Limited-Slip Differential (Auto LSD) features. Basically, when you turn on your truck, TRAC and VSC are armed and Auto LSD is not. This is known as “Normal” mode, and if the truck should start to fishtail or the tires start to spin each system will kick in automatically, braking or powering down the engine as required."
    Here is a thread that discuss traction control and VSC and 0 point calibration (TSB), which I found interesting. traction control problems with lift
  12. #41
    Supercharged Member Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff is more than famous, they're infamous. Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    49
    Posts
    2,686
    Liked
    63 times
    Images
    45
    Rep Power
    2514
    Lots of traffic in the big city boys and you have to get in it to merge around here. If I have to mat her then I mat her no problem.
    2006 Tundra DC with: Eclipse AVN5500 Navigation System, Kicker IX500.4 driving infinity kappa 60.9cs door speakers, Kenwood KAC-X20 driving an infinity kappa 100.9w sub in sound ordnance bass bunker, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Ballistic Enigma 20x9 wheels & Nitto nt420 285/50R20 tires, Hellwig 7697 & 7700 sway bars, Stinger SPP2150 Battery, Big 3 wire upgrade with 1/0 Raptor, Rancho RS5000 struts/shocks, Dynomax VT 17956 muffler, EBC Slotted Sport Rotors & Yellowstuff Kevlar pads, Russell SS brake lines, Cheetah GPS Mirror, Volant CAI
  13. #42
    Supporter kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    42
    Posts
    2,552
    Liked
    564 times
    Images
    27
    Rep Power
    186294
    Try driving in Massachusetts .
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  14. #43
    Junior Member Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind. Sportsmanphil is a pinnacle in their own mind.
    Join Date
    Sep 2012
    Location
    North Carolina
    Posts
    134
    Liked
    43 times
    Rep Power
    1663
    WOW...
    1st off my 06 DC does the same thing in CC. Many times on the slightest of rolling highway inclines. If I run he same section of road with out the CC, I can maintain the exact speed with my foot, therefore the CC should be able to do the same as the engine can obviously pull the hill in top/locked gear.
    The CC problem is very common with this truck and YES your truck is fine using the cruise @70mph. Mine has kicked the RPMs right to 4500 before on a slight rolling grade. I have 4 trucks, 1 of which is a full size V8 and it can run the same sections of highway pulling a steel trailer with 3 ATV's in cruise and never miss a beat. The Tundra should be able to do the same empty.
    IMO, I would consider fuel starvation. Before I dropped money in a fuel filter and pump, I would run a fuel gauge through the hood and tape it to the windshield. This is a common practice in dealerships to monitor fuel pressure during diagnosis. More than likely you are loosing engine performance due to a lack of fuel flow. Throttle off, the engine can idle while coasting until it regains proper pressure. This would also explain why the engine stalled after trying WOT.
    Personally I think Toyota should have offered a fix for this COMMON cruise problem by now. Like I stated earlier, if I can maintain speed up the same hill by foot, the cruise can do the same.
    jjsinaz likes this.
  15. #44
    Join Date
    Dec 2006
    Location
    Lewisville
    Posts
    10
    Liked
    4 times
    Rep Power
    0
    It's a 2000 Model, so no VSC or traction control was available. Heck...in 2000, you couldn't even get a limited slip differential(at least not in the 2wd models).
    Quote Originally Posted by kanaduh View Post
    SR5
    4.7L V8 engine
    4-wheel drive
  16. #45
    Veteran Member PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some. PapaPS has done just about everything...and then some.
    Join Date
    Jun 2003
    Location
    sarasota fl
    Age
    57
    Posts
    639
    Liked
    44 times
    Rep Power
    993
    mine see's 5000 -5200 rpms at least once a week............no hills down here...........but would kick way down on my trips to north fla too...............gotta be some sort of fuel starvation issue in my opinion.......175000 plus
    STATE OF CONFUSION
Posting Permissions
  • You may not post replies
  • You may not edit your posts
