New wheels! but need spacers
+ Reply to Thread
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By kanaduh
Thread: New wheels! but need spacers
  1. #1
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    55
    Liked
    21 times
    Rep Power
    1371
    Default New wheels! but need spacers
    ok i just bought new ion 174 wheels 16x8 but test fitting them, they dont fit the front ones rub on the disk brake caliper i think i only need 3/8 inch more of an offset so i ordered these 7mm spacers off ebay for 20$ that use the original studs. the spacer just slides over the studs, is there anything wrong doing this ? the rear wheels fit fine. thanks in advance
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    2,151
    Liked
    872 times
    Images
    4
    Rep Power
    42260
    Default Re: New wheels! but need spacers
    That should work...I dont believe you should have any issues...Just make sure you still have enough thread left on the lug studs to FULLY engage your lug nuts. To check, you could always just pick up an open acorn style lug nut, and snug it on to make sure you have at least a couple extra threads extending past the end of the nut.
    As to the rears, yeah, just run them without spacers...14mm (about 7/16") total track width difference between front and rear shouldnt even be noticeable.
  4. #3
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    55
    Liked
    21 times
    Rep Power
    1371
    Thread Starter
    i would think they will work fine but i was wondering with the stock wheels being hub centric or whatever and having all the weight on the studs instead of the center of the wheel ? im not really sure
  5. #4
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    896
    Liked
    163 times
    Images
    48
    Rep Power
    12661
    Show us a picture of the spacers, or a brand name for the spacer. I personally wouldn't use anything other than Spidertrax spacers. Hub centric is the way to go and also make sure the studs and lug nuts are correct, and torqued to the correct amount.
  6. #5
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    55
    Liked
    21 times
    Rep Power
    1371
    Thread Starter
    Two Wheel Spacers 6 Lugs 7mm Thick Universal Fit Spacer | eBay
    they arent hubcentric i dont think my new wheels are either
  7. #6
    Join Date
    Mar 2012
    Location
    NY
    Posts
    2,151
    Liked
    872 times
    Images
    4
    Rep Power
    42260
    I wonder if those could throw off your wheel balance, since they dont have a symmetrical hole pattern?
  8. #7
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    55
    Liked
    21 times
    Rep Power
    1371
    Thread Starter
    im not to sure i wouldnt think so if the spacers fit snug and dont have any play in them. but once i get them ill test fit and see, i just thought for 20$ I could try them
  9. #8
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    896
    Liked
    163 times
    Images
    48
    Rep Power
    12661
    So, you add a 7mm wheel spacer, which then reduces the length of the available stud, to attach the wheel. Are you replacing the studs with longer ones? You no longer can get the wheel aligned with the hub, I think you are just asking for problems. A correct spacer should be hubcentric, and the studs should be an intrigal part of the spacer. Here, read this post, and then search some more regarding spacers/adapters. Be safe, and do it right. Wheel Spacers - Are they safe?
    Remmy700P likes this.
  10. #9
    Join Date
    Jul 2004
    Location
    Walla Walla, WA
    Age
    38
    Posts
    272
    Liked
    45 times
    Rep Power
    4091
    3/8ths of an inch shouldnt be a problem. as far as balance that shouldnt be a problem either. its too close to the center of the hub to make any real difference.
  11. #10
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    55
    Liked
    21 times
    Rep Power
    1371
    Thread Starter
    thats what i was hoping for but not being hubcentric anymore i dont think i could ever have a good balanced wheel.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
