Double Cab Bazooka VSE harness plug-n-play or sub/amp?
+ Reply to Thread
Results 1 to 3 of 3
Thread: Double Cab Bazooka VSE harness plug-n-play or sub/amp?
  1. #1
    Lurking Member 2rz-fte is on a distinguished road.
    Join Date
    Sep 2006
    Location
    91/605
    Posts
    22
    Liked
    0 times
    Rep Power
    7
    Question Double Cab Bazooka VSE harness plug-n-play or sub/amp?
    so obviously its terribly difficult to get my hands on this dang VSE for my 05 dub cab.
    however, if the harness is just plu an play (with a ground), then can i just get my hands on a harness and use my own amp sub? this would make the install damn near plug n play. no wires to run, or whatever (the part of a sub install that takes the most amount of time, usually)
    when can i get this harness? or is it even possible with more than 100w sub?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes.
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    772
    Liked
    86 times
    Images
    48
    Rep Power
    4291
    Default Re: Double Cab Bazooka VSE harness plug-n-play or sub/amp?
    Check these guys out. Great customer service and support. Crutchfield Customer Support. You could also post this in the audio section.
    Just found this, Subwoofer VSE by Bazooka 04-06 Tundra which lists a harness part number.
  4. #3
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,666
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    don't waste your time. you'll have to splice into the harness so it isn't plug and play. but why would you want to? if you are gonna run a 100w (or more) pushing a 100w sub, you'll need a lot bigger power wire and ground that what the oem harness (20 gauge?) can give you. do it right the first time. hit up the http://www.tundrasolutions.com/forums/audio-and-stereo/ forum here for some how-to directions and answers to the basic questions you have.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
