Adjusting Bilstein 5100's
+ Reply to Thread
Results 1 to 12 of 12
Like Tree7Likes
  • 3 Post By Stone_Blue
  • 1 Post By tundrunk
  • 1 Post By seanpistol
  • 2 Post By Auburn02
Thread: Adjusting Bilstein 5100's
  1. #1
    Junior Member 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner is a pinnacle in their own mind. 87runner's Avatar
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    141
    Liked
    18 times
    Rep Power
    2162
    Default Adjusting Bilstein 5100's
    Searched around a bit and didn't seem to find a definitive answer to my question. Truck is a 2000 4x4 Tundra. Got 5100's up front currently set at 2". Want to drop down to 1". Do I have to completely remove the spring to adjust the collar or can I compress the spring to relieve the pressure and adjust it that way without pulling it all apart?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,111
    Liked
    2029 times
    Images
    47
    Rep Power
    121449
    Default Re: Adjusting Bilstein 5100's
    I'm fairly certain you will need to disassemble the coil-strut assembly. The issue is you need to be able to compress the coil sufficient to have the lower spring perch slide up and clear the c-clip, and there isn't enough available compression length to do that.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #3
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    141
    Liked
    18 times
    Rep Power
    2162
    Thread Starter
    Quote Originally Posted by Remmy700P View Post
    Thanks Remmy, I rented a spring compressor tool from the local parts store in hopes that this will be a relatively easy job. I have done the timing belt, swapped the rack and pinion, etc. on the truck, never have jimmied with coil springs though. I had a shop install the springs at the 2" setting last time, seeing as this is my first time attempting to adjust the 5100's, is this a fairly easy task or should I pony up the $20-$30 and just have the shop adjust the settings?
  5. #4
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,040
    Liked
    294 times
    Rep Power
    12181
    If its only $20-$30, dont even wonder, just let the shop do it....
    Remmy700P, Jonesy and seanpistol like this.
  6. #5
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,225
    Liked
    1139 times
    Images
    216
    Rep Power
    190697
    In theory, since you are lowering the perch and not raising it, it should be possible to do this without removing the spring. In actuality, that would be a very dangerous act to work on a coilover assembly with a loaded spring.
    I'd toss some cash at a shop with a fork style wall mounted unit, the rented spring compressors are typically of bad quality and aren't well cared for. They work great for smaller springs like those of a Honda Civic, but the springs under a Tundra are fairly heavy duty and harder to compress.
    tundra3400 likes this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  7. #6
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    $20-$30? I had to haggle a place to come down to $75 for the pair. Everywhere near me seemed to want $150 for the effort... ridiculous!
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  8. #7
    Join Date
    Nov 2009
    Location
    Posts
    5,225
    Liked
    1139 times
    Images
    216
    Rep Power
    190697
    That's obscene, it's no more than 30 minutes work with a wall mount unit.
  9. #8
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    Quote Originally Posted by tundrunk View Post
    That's what I explained to them to get the price down... said if I had their equipment I could do it in half an hour! Walked out of the first tire shop because they refused to come down from $150 (and I brought everything in... they didn't even have to take anything off my truck). Also, a couple places I called before that refused to touch the things because they didn't sell me the parts. It was a frustrating time.
    Found a good 4x4 shop that was willing to put them together, and I waited for about an hour and a half for them to finish... and this was with 2 guys working on them. Apparently my coils are pretty stiff and took some wrestlin', and they had to cut and hammer out the rusty top studs from the stock setup to re-use the top plates. I wouldn't want to try it myself with a little rented spring compressor, that's for sure.
    Remmy700P likes this.
  10. #9
    Rookie Auburn02 is on a distinguished road.
    Join Date
    Oct 2011
    Location
    Alabama
    Posts
    12
    Liked
    3 times
    Rep Power
    0
    I did exactly what you're asking about, going from 2" to 1.5" with the compressor just holding the coils enough to relieve the pressure on the perch clip. It's scary, but no more so than using the ****ty cheap compressor in the first place. The actual time to re-position the clip is in the neighborhood of 7 seconds. If I knew of a shop that'd do it for 30 or 40 bucks I wouldn't even consider dealing with it myself. I tossed the cheap spring compressor in the garbage when I was done so I wouldn't be tempted to re-use them, after seeing how much they bent under the force of the spring.
    Jonesy and Stone_Blue like this.
  11. #10
    Join Date
    Feb 2011
    Location
    Flagstaff
    Posts
    141
    Liked
    18 times
    Rep Power
    2162
    Thread Starter
    After some debate, I opted to just have the shop do it. Course my $30 estimate was way off, they charged $80! Little spendy especially considering I dropped the units off, they didn't have to do any wrenching. Easiest money they have ever made I'm sure. Either way though I'm happy with the ride quality. Little plusher than the 2 inch setting. Still clear my 255 85/16's no prob
  12. #11
    Junior Member thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub is a pinnacle in their own mind. thecayub's Avatar
    Join Date
    Jul 2011
    Location
    Decatur, IN
    Posts
    66
    Liked
    10 times
    Rep Power
    1399
    I did it with them on my truck once. got a spring compressor, hooked it up to my coils while the truck was on the ground. then compressed the coils as much as i could (constraint was the room I had, not the tension) then I jacked up the front end and had plenty of room to slide up the bottom spring pad, and lower the circlip. then let the truck down, and released spring compressors. wuala!
    2000 Tundra 4.7L access cab
    Converted to 5spd manual, 550 ft. lb. clutch
    Downey midlength headers; Custom Y pipe and full dual exhaust completely straight piped; Custom ram air intake; Air conditioner delete; Blacked out grille, bumpers, flares, trim, badges, wheel wells; Painted factory 16" alloys, red calipers and drums; Bilstien 5100's on top notch; Custom rig job front lift (lowered front subframe); Poly bushings all around; Rear add-a-leaf; Home made shackle flip mounts; 2" blocks; Red intake, valve covers, plenum, fuel rails, headers; Fog light mod; 305/70/16 m/t tires
  13. #12
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    179 times
    Images
    27
    Rep Power
    6289
    Quote Originally Posted by Auburn02 View Post
    we have a 20 ton floor compressor at work and the top bar that the hydraulic jack pushed down on is slightly bent and this is at a toyota collision shop. these springs have incredible compression forces.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
Posting Permissions
  • You may not post replies
  • You may not edit your posts
