The fools, the fools the fools! They have left us
our Fenian dead, and while Ireland holds these
graves, Ireland unfree shall never be at peace!
Padraig Mac Piarais (Patrick Pearse)
2005 Tundra DC Limited 4wd - Phantom Gray Pearl
Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
Going to change out scoop this weekend with slightly warmer temperatures and hopefully see a slight improvement in mileage. Temperatures this week will return to their cooler temperatures similar to the previous week so I should be able to see if there is a difference. Still tank averaging right at 15 MPG which is not too bad considering temperatures, fuel, and extended warm-ups in the mornings.
Tundra Fuel Economy Blog
241,233 miles on the odometer [come see me when you get that on your ford]
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
