Question My 03 Tundra has oil pressure issues after changing to synthetic. Help???
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree8Likes
Thread: My 03 Tundra has oil pressure issues after changing to synthetic. Help???
  1. #1
    Rookie 03LimitedYoda is on a distinguished road.
    Join Date
    Jan 2013
    Location
    United States
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Exclamation My 03 Tundra has oil pressure issues after changing to synthetic. Help???
    When I first start the truck the pressure is fine at halfway, as the vehicle warms up it will drop to the low line and spike up as I push down on the gas. I have read some of the other postings and other people have the same problem, if you could call it that. What Im getting is a rough running engine when the oil pressure gauge reads on the lower line.
    That cant possibly be good. No leaks, everything is fine there.
    Mobil 1 synthetic 5w30 6.5 quarts in my 4.7 liter V8. Can anyone clarify that this is not an issue at all or that its not connected to the oil pressure gauge issue?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some. Mongoose has done just about everything...and then some.
    Join Date
    Jun 2003
    Location
    LA.....Lower Arkansas
    Age
    42
    Posts
    181
    Liked
    11 times
    Rep Power
    832
    Default Re: My 03 Tundra has oil pressure issues after changing to synthetic. Help???
    Thats Strange... I've been considering swapping to Mobil 1 synthetic, so I'll be watching this thread topic.
  4. #3
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    The 2UZ-FE's oil pump is crank-driven, so oil pressure is a function of engine RPMs. Your oil pressure gauge is functioning exactly as it was designed. Your idling issues have nothing to do with oil pressure.
    Welcome to the forum.
    Gatorman76 and tundra3400 like this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  5. #4
    Join Date
    Jan 2013
    Location
    United States
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Its not an idle issue. I have read through the forums and DO know that the pressure gauge is "crank driven". What Im experiencing is when the pressure "gauge" is on the low line, not idling, the vehicle is at lower rpms, the engine feels as though its running rough, a faint sputter or bog if you will. Is this connected to the crank driven gauge reading low? Or is this something else entirely.... Thanks for your detailed responses, hopefully someone will know whats going on.
    And thank you, Ive been a reader and user for sometime, this site has lots of intelligent people and posts. Decided to register finally
  6. #5
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,104
    Liked
    2020 times
    Images
    47
    Rep Power
    121449
    Quote Originally Posted by 03LimitedYoda View Post
    To clarify, the oil pressure gauge in your dash is not "crank driven", the oil pump -- and the resulting pressures -- are.
    Further, let me repeat: oil pressure is not causal to poor idling, stumbles, stutters, etc unless you essentially are running it with no oil and it is on it's way to complete seizure.
    I suggest standard maintenance first, i.e. cleaning the throttle body, MAF, replacing the air filter (if needed), replacing the spark plugs (if needed), etc and see if you can narrow down and isolate the problem.
    kerryman71 and tundra3400 like this.
  7. #6
    Veteran Member INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind.
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    583
    Liked
    42 times
    Images
    7
    Rep Power
    2080
    If this is something that happened immediately after an oil and filter change, then change the oil filter. You may have been unlucky and gotten a defective filter. I'm assuming by your description (low line) that the guage is reading zero psi at low RPM's. This is certain disaster.
  8. #7
    Join Date
    Jan 2013
    Location
    United States
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Air filter is clean as a whistle, spark plugs are great, throttle body is being cleaned now, MAF? As my profile states Im a rookie lol cut me a little slack this is my first yoda and Ive had it for 4 months. Also, would there be a reason why before I switched to synthetic the needle on the gauge did not do anything of the sort?
  9. #8
    Join Date
    Jan 2013
    Location
    United States
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by INDYMAC View Post
    Crap. That sounds bad... I did use a filter that came with the truck, and apparently was from Japan not sure if it was OEM or not... I will change the filter immediately.
  10. #9
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,634
    Liked
    845 times
    Images
    24
    Rep Power
    20864
    You have no idea what your oil pressure was before OR after the switch to synthetic. Why? Because the oil pressure gauge in your dash is a "dummy" gauge. If you really want to know what your oil pressure is, hook up an aftermarket oil pressure gauge. However, since you are convinced synthetic oil is the problem, run down to wally-mart and buy 6.5 qts of dino oil and do a drain and fill; problem solved.
    kerryman71 likes this.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  11. #10
    Supporter kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    42
    Posts
    2,551
    Liked
    562 times
    Images
    27
    Rep Power
    186294
    Some more info may help. Did you change the oil yourself and if so, did you do one of those engine flush in a can deals? Did the problem start immediately after changing the oil, meaning you changed it, started the truck and presto, it was there? You say you've had it for four months. Do you know the previous owner or have any maintenance records?
    Mongoose, do the switch, you shouldn't have a problem. I switched to synthetic (Mobil 1 0W30) 35K miles ago with no problems.
    John
    tundra3400 likes this.
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  12. #11
    Junior Member asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light. asc08 is a glorious beacon of light.
    Join Date
    Dec 2005
    Location
    Mechanicsburg, PA
    Posts
    59
    Liked
    10 times
    Rep Power
    186
    I had a Chevy some years ago. Driving on the highway, everything was fine. Came up to a traffic light, and when I stopped, the oil pressure dropped to zero, and the light came on. Not hearing any engine noise, like lifter tap, or bearing knock, I pulled over, checked the oil level, and it was fine. Turned out to be a bad oil pressure sending unit.
    I think what Remmy was pointing out was the rough running engine should not be caused by the low oil pressure reading, but the low oil pressure reading may be caused by the rough running engine.
    I have no idea where the oil pressure sending unit is on the Tundra, but a good old dial gauge connected in place of the sending unit will put your mind at ease, and let you know if you are actually experiencing low oil pressure.
    When the engine is running rough, what do the RPMs fall down to?
    Jonesy likes this.
    2013 Tundra DC 4X2 4.6l Silver Sky Metallic
    2010 Camry
    2000 Echo
  13. #12
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,634
    Liked
    845 times
    Images
    24
    Rep Power
    20864
    OP - you made no mention if the oil light in your gauge cluster comes on; a MUCH better indication there is an oil pressure issue. if you don't know where it is, just put your key in the ignition and turn the key to on without cranking it over.
    To "clarify", Mobil 1 5W-30 is not an issue at all and is not connected to your perceived oil pressure problem.
  14. #13
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    Hello 03limitedyoda,
    Go back and check the dipstick, my truck takes 7qts, not 6.5. You'll want the oil at the higher end of the indicator markings. Also, I don't think rough running would be caused by oil, more likely a fuel/ignition related issue.
    From your description, it sounds like your gauge is working normal. Mine has mid level pressure at start up, as the motor warms the pressure lowers, and as I accelerate the pressure builds. When you say it goes to low level line, to you mean the gauge pins at the very bottom, or just in the lower range?
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  15. #14
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,634
    Liked
    845 times
    Images
    24
    Rep Power
    20864
    i had to put on an oversized filter to get 7 qts into mine. before, only 6.5 qts. did you?
  16. #15
    Join Date
    Nov 2009
    Location
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    I always run Toyota filters, the D3 one. I don't think larger filter will hold half a quart, unless you're talking a huge filter. The Toyota one only holds a few ounces before it gushes back out.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
