SureTrax Max-Pax - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Like Tree5Likes
Thread: SureTrax Max-Pax
  1. #16
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    844 times
    Images
    24
    Rep Power
    20864
    Default Re: SureTrax Max-Pax
    bought mine in the off-season and it was much closer to $125 than it was $60. but since you are willing to forego the rest of this winter without it, don't bother. you either need it, or you don't.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Veteran Member mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77's Avatar
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    556
    Liked
    30 times
    Rep Power
    280
    Thread Starter
    I've been driving around for the past two days with the water-filled air mattress and it has made a world of difference. No slipping on the ice/snow and no spinning out in the rain. I am definitely going to buy one. Did you get the mid/compact version (CLW-0048) or full size (CLW0056)? The mid-size is about 8" narrower and holds 300 lbs compared to 400 lbs for the full size. I'm inclined to go with the mid-size not only because it is cheaper, but also because I can fill it up completely. I think 300 lbs. is just about right. 400 lbs. seems like a little much, but I really don't know. What do you think? Get the mid-size and fill it up all the way or get the full size and fill it 2/3 of the way? Is it critical for the bladder to span the entire width between the wheel wells?
  4. #18
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    844 times
    Images
    24
    Rep Power
    20864
    i've got the big-daddy. you've got a full-size truck, get the full-size. you've got time to watch prices so just keep an eye on three or four of your favorite websites (include amazon) and pull the trigger when it drops in price that is in your budget. cut-out the weekly happy meals and you can save up enough money to pay for it.
  5. #19
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    556
    Liked
    30 times
    Rep Power
    280
    Thread Starter
    I bought the full size. Manufacturer said the mid-size would work but the grommets would eventually be damaged because of the additional strain exherted by the increased angle with the tie down. Not sure I buy that, but whatever, it was only a $15 difference in price.
  6. #20
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    844 times
    Images
    24
    Rep Power
    20864
    that was some BS for sure. make sure you tie it down on all four corners with something other than bungee cords. i use bungee cords, but i have a rubber bedmat and an undercover tonneau so i'm not worried about it going anywhere. use some 1/4 cotton braided line.
  7. #21
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    556
    Liked
    30 times
    Rep Power
    280
    Thread Starter
    Do you have yours filled up all the way? Is 400 lbs a bit much in your opinion or just right? I noticed inhibited acceleration when I had the mattress in the bed, but it wasn't too bad. It was definitely much more stable though, no tires spinning, etc. I would say there was about 300 lbs in there.
  8. #22
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    844 times
    Images
    24
    Rep Power
    20864
    not filled to the rim
  9. #23
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    556
    Liked
    30 times
    Rep Power
    280
    Thread Starter
    SuckersWalk: Should have taken your advice regarding not using bungee cords. I figured it would be ok if I used the more rigid rubber type, but they are came disconnected. I'll be using braided cord as recommended.
  10. #24
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,627
    Liked
    844 times
    Images
    24
    Rep Power
    20864
    lol. did you have it up on two wheels? the line will keep it from moving (safer), whereas the bungee cords will give, a lot.
    oh yeah, enjoy the bonus feature....a leveling kit that only takes 20 mins to install. it can be adjusted or removed in a matter of minutes. all the cool kids will envy you.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
