SureTrax Max-Pax
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Like Tree5Likes
Thread: SureTrax Max-Pax
  1. #1
    Supporter mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77 is a name known to all. mossman77's Avatar
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Default SureTrax Max-Pax
    Does anyone have a SureTrax Max-Pax in the bed of their 2WD Tundra? I'm looking for something similar to add weight to the bed of my truck to give it better traction. The bag is designed to freeze, but what about when the water is not frozen? Doesn't the bag/water slosh around making handling worse?
  2. #2
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    167 times
    Images
    36
    Rep Power
    8787
    Default Re: SureTrax Max-Pax
    it probably wouldn't slosh around if it were full?
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  3. #3
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Thread Starter
    I would hope not, but it appears to be a flexible bladder. It looks to be pretty low profile so any sloshing/shifting should hopefully be minimal. It's the "designed to freeze" statement in the advertisement that has me a little worried. Does this thing only work if frozen?
  4. #4
    Supporter kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    42
    Posts
    2,596
    Liked
    622 times
    Images
    27
    Rep Power
    192270
    Buckets of sand don't freeze nor slosh around. As an added bonus, you could use the sand for traction of needed.
    FWIW, I work on a truck that has a 500 gallon tank of water on it. Never had a problem with sloshing or shifting if the driver knows how to operate it.
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  5. #5
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Thread Starter
    Has anyone used a twin air mattress and filled it with water? I can get one of those for $12 whereas the ShurTrax costs $125. If it eventually leaks, so what, hopefully it would last a few months and it's only $12. Like this one: http://www.walmart.com/ip/Intex-Viny...ndingMethod=rr
  6. #6
    They have welded baffles inside that prevent sloshing.... Pretty smart idea, but not as smart as having 4WD...
  7. #7
    Supporter SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk wants you off his porch. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,763
    Liked
    924 times
    Images
    24
    Rep Power
    26125
    i've got one. has baffles. no sloshing around preventing weight transfer and getting the truck up on two wheels; and damn it, i've tried much safer than tubes of sand or whatever other flying projectile others decide to use that do go rolling from one side to the other when cornering like danica; been there, done that too. the shurtrax can move around (the bladder itself) a bit when pulling some good g-forces (driving like you stole it) if it isn't strapped to all four corners of the bed; duh!, that's why there are four grommets on the bladder.
    tundra3400 likes this.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  8. #8
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Thread Starter
    I am going to try the air mattress idea. However, I can't fill it up all the way because that would be 1,000 lbs., so I only filled it up 1/3 of the way. I'm thinking this could be a bad idea if the water isn't constantly frozen. Could this increase the rollover risk when it is thawed? If so, I think I may pull the plug. It would be one thing if it were just me driving it, but my wife drives it as well with our 2-year old toddler. Any thoughts? By the way, the mattress spans the entire length of the bed and there is about 2" clearance from the wheel wells on either side. 1/3 full equals about 3" of water, so perhaps rollover risk isn't a concern, but 300+ lbs. of water shifting left/right could make spinning out more likely, which is one of the very reasons I decided to add weight in the first place. Maybe I should just play it safe and fork out the $125 for the ShurTrax.
  9. #9
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,763
    Liked
    924 times
    Images
    24
    Rep Power
    26125
    Quote Originally Posted by mossman77 View Post
    just install some baffles inside the mattress and put some grommets, one each corner, so you can secure it to prevent shifting weight causing instability in handling. your family will be nice and safe that way, which is your priority.
  10. #10
    ^ Worth a try, but for safety's sake make sure that sucker is strapped down tight.
  11. #11
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Thread Starter
    4doubleyaD: It's not strapped down at all. I figured the weight alone would keep it in place. Plus it reaches from the cab all the way to the tail gate and nearly wheel well to wheel well. Is it necessary to secure it?
    SuckersWalk: I have to assume you are being sarcastic when you say install baffles and grommets to an air mattress. I'll likely just buy a ShurTrax tonight once I get a few more drinks in me!
  12. #12
    If the thing freezes solid you will have a 4'x6' 400lb block of ice in the back of your truck... Probably not the best thing to have lying loose in case of an accident... Can't hurt to strap it down. Just thinking out loud here but if you can figure out a way to ratchet-strap it down low to the floor of the bed then it will kind-of act like baffles.
  13. #13
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Thread Starter
    I could install two 2x8's left-to-right, one about a foot from the cab and one a foot from the tailgate (there are notches in my bedliner). Then install tie downs diagonally underneath the 2x8's (forming baffles) and two tie downs over top to hold the 2x8's down tight. Man, sounds like I should just fork out the $125.
  14. #14
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    42
    Posts
    2,596
    Liked
    622 times
    Images
    27
    Rep Power
    192270
    By the time you pull the trigger and buy the damn thing it will probably be marked down because of spring time closeout sale.
    John
    SuckersWalk likes this.
  15. #15
    Join Date
    Jan 2007
    Location
    Montclair, VA
    Posts
    625
    Liked
    41 times
    Rep Power
    280
    Thread Starter
    Yeah. Think I'll hold off until the off-season. Hopefully it will be cheaper then. I've seen previous posts where people mentioned $60 for one, but right now they are $125.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
