Question HELP PLEASE!!!!! Brakes are all rear!
+ Reply to Thread
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By kovawa
Thread: HELP PLEASE!!!!! Brakes are all rear!
  1. #1
    Rookie mengquis is on a distinguished road.
    Join Date
    Jan 2013
    Location
    Phoenix
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Exclamation HELP PLEASE!!!!! Brakes are all rear!
    So I was driving around yesterday and then all of the sudden the pedal went ALMOST to the floor with little feedback.
    I babied her home safely and adjusted the rear brakes this morning. BETTER! But still ALL rear braking. Very little front brakes and still pretty spongy. ANY ideas?????
    The truck is a 01 Tundra, v6 2wd. Nothing special, 210k miles.
    Recent maint: Got a brake light, replaced the brake fluid in res with new dot 3. Still has a green tint to it. Light went out. ANY help would be of GREAT appreciation!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family. Thundra04struck is almost part of the TundraSolutions family.
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    Default Re: HELP PLEASE!!!!! Brakes are all rear!
    Have you taken the front wheels off to look at the calipers/brake lines at all?
    See if there is any brake pad left or if a line has ruptured or is leaking?
    How about looking under the hood at the master cylinder and the metal lines going to the front brakes?
    You could have blown out the master cylinder.
  4. #3
    Junior Member kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa comes in many shapes and sizes. kovawa's Avatar
    Join Date
    Feb 2008
    Location
    so cal
    Posts
    469
    Liked
    111 times
    Rep Power
    5000
    210K? I'm betting it needs a new master.
    tundra3400 likes this.
    2006 DC 4X4 SR5 Phantom Grey Metallic. Mods include: Full Tint,LED lighting inside & Out. Front End Leveling Kit, 900 watt JBL/Alpine audio System, Mishimoto Aluminum Radiator, OBX Stainless Steel Headers, Magniflow Muffler, TRD Dual Exhaust, Polyurethane Upper/Lower Control Arm & P/S Rack Bushings.
  5. #4
    Join Date
    Jan 2013
    Location
    Phoenix
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    I did a visual on all the brake lines, no problems seen. No fluid lost anywhere.
    Just bled the brakes, nothing major to report. Bled the prop valve as well.
    Still just as bad! No front brakes at all. Brake pedal WILL hold pressure, no leak down at all.
  6. #5
    Lurking Member santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322 is a splendid one to behold. santi2322's Avatar
    Join Date
    Sep 2011
    Location
    Albuquerque
    Posts
    29
    Liked
    4 times
    Rep Power
    8
    Agree with the above.. your master is probably shot..
    2011 TRD Metallic Grey
    LED Tail lights
    20" American Outlaw Wheels
    305/50 Nitto Terra Grapplers
    Line X Spray Liner
    Tint all-around
    T-Shifter
    BHLM
    Stubby Antenna
    Clazzio Custom Seat Covers
    Bushwacker Pocket Flares
  7. #6
    Join Date
    Feb 2008
    Location
    so cal
    Posts
    469
    Liked
    111 times
    Rep Power
    5000
    Quote Originally Posted by mengquis View Post
    When you say it holds pressure- are you stomping on the pedal or just gently resting your foot on it? I ask because - many times a failing master cylinder will feel as if it's working properly when you stomp on it. But if you gently apply pressure to the pedal it will slowly sink to the floor. This is due to the fact that sudden application of the pedal has enough force to make the o-ring seals move and make a tight seal. Slow application of the brake pedal allows enough time for the brake fluid to leak past or "bypass" a worn o-ring and results in the "spongy pedal" when braking normally.
  8. #7
    Join Date
    Jan 2013
    Location
    Phoenix
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    So update!
    Changed master cylinder, bench bled before install and everything. Bled all 4 wheels and proportioning valve. No change. Still sucks!
    I did notice that i had microbial growth in the old reservoir (hence the green tint) and replaced with new res.
    Still no idea what is wrong!
  9. #8
    Junior Member doubleds65 is on a distinguished road.
    Join Date
    Dec 2012
    Location
    las vegas
    Posts
    195
    Liked
    21 times
    Rep Power
    1
    Did u check 4 leaks on the pistons in the caliper?
    Sent from my HTC_Amaze_4G using AutoGuide.Com Free App
  10. #9
    Join Date
    Jan 2013
    Location
    Phoenix
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Yep! Just checked that, no leaks
    SO here is where I am at after working all day on it:
    master cylinder changed
    brakes bled to NEW fluid flowing through with no air
    Brakes inspected for operation:
    So here is where I found something interesting------Brakes only move a little and pedal locks up before hitting the rotor. NO braking available with engine off and pedal is SUPER firm!
    I moved the front left pads away from the rotor 1/4" and with engine off- the pedal locked up and no more movement after 1/8"
    Clunking noise heard when pushing pedal all the time.
  11. #10
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,668
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    after replacing the mc assuming you don't have any leaks as you state, my money is on either air in your system or you have a problem with your proportioning valve or your new mc isn't functioning property. likely your new mc is fine since you have the same problem now as you did with your old mc. personally, i would hit up the Brakes sub-forum and take a look at this How to Troubleshoot Brake Problems - For Dummies and this http://www.mpbrakes.com/uploads/docu...hootingpdf.pdf . you may just want to stop working on your not working brakes and find someone that can stop what they are doing and stop by your house to fix your brakes for you so you can stop pulling your hair out
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  12. #11
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,225
    Liked
    1139 times
    Images
    216
    Rep Power
    190697
    Booster? Interesting that the pedal hits floor before the pads hit rotor.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  13. #12
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,668
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    that would be easier to understand tham if he had a firm pedal and still no front brakes i guess. then i would suspect the adjustment he did to his rear brakes needs to now be backed off just for ****s and grins
  14. #13
    Join Date
    Sep 2007
    Location
    MA
    Posts
    745
    Liked
    70 times
    Rep Power
    5392
    You said you " . . . moved the left front pads . . . " so that means that at least those locating pins for the brake pads are not seized up, preventing the pads from moving anywhere.
    I had an issue where the pins were seized in the caliper causing me to have to pump my pedal twice to get good braking action, otherwise the pedal was very soft. Probably not the issue but worth looking at
    I have heard about the need to bench-bleed the MC before install as air can get trapped in them and regular bleeding doesn't work the air out.
  15. #14
    Junior Member burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300 has done just about everything...and then some. burned300's Avatar
    Join Date
    Jul 2009
    Location
    Columbus, Ohio
    Posts
    275
    Liked
    40 times
    Images
    7
    Rep Power
    1043
    Forgive me for not knowing, but does an 01 have anti-lock? if so, when bleeding you never want to let brake system get any air. MC need to stay full at all times. I've seen were people have just let all their fluid out & go to refill, and air gets trapped in the anti-lock system.
    2005 Silver Sky 4X4 AC SR5 V8
Posting Permissions
  • You may not post replies
  • You may not edit your posts
