Question new foglights !
+ Reply to Thread
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By rotty
Thread: new foglights !
  1. #1
    Lurking Member tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future. tjend has a brilliant future.
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    34
    Liked
    11 times
    Rep Power
    110
    Default new foglights !
    ok got hid foglights from ebay for 100$ i installed them and they are plugged into the factory pre wiring (very convenient ) but now how do i get them to work, i would think you just need to install a fog relay switch or somthing? ive skimmed over diy threads on foglights for the tundra but seems like a lot of work. i have the 2006 tundra double cab 4.7 any help is appreciated
  2. #2
    Veteran Member tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400 has a criminal record for giving away rep points. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    9693
    Default Re: new foglights !
    if you already have the factory wire harness for the fogs then you will need to atleast get a 4 pin relay from toyota or a toyota parts distributor and a switch as well unless the switch is on the headlight column stick.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 198,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  3. #3
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    34
    Liked
    11 times
    Rep Power
    110
    Thread Starter
    i think ill need the switch, because i have three headlight settings, off ,daytime lights, then headlights. if i dont get a switch would the foglights work ?? thanks
  4. #4
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    9693
    mine didnt on my 2000, you need the relay and switch. there should be knockouts on the dash to the left of the steering wheel. if its prewired, there should be a harness there and it will plug right into the switch. try here for discounted parts: Toyota Parts - Genuine OEM Toyota Auto Parts and Accessories
    CBTMA Member
  5. #5
    Junior Member rotty is on a distinguished road.
    Join Date
    Jun 2006
    Location
    So Cal
    Posts
    56
    Liked
    6 times
    Rep Power
    8
    On my 06 I had to add a relay and the switch on the column.
  6. #6
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    9693
    Quote Originally Posted by rotty View Post
    switch on the column sounds like a PITA to install. glad mine was on the dash instead.
    CBTMA Member
  7. #7
    Join Date
    Nov 2012
    Location
    San Antonio
    Posts
    34
    Liked
    11 times
    Rep Power
    110
    Thread Starter
    ok where does this relay install ? in the fuse box in the engine bay ? theres 3 which one haha, and i got a rocker switch ill put in instead of buying the 50$ switch from toyota
  8. #8
    Join Date
    Jun 2006
    Location
    So Cal
    Posts
    56
    Liked
    6 times
    Rep Power
    8
    Quote Originally Posted by tundra3400 View Post
    A few screws to take off the column cover and 2 screws for the switch. As far as the location of the relay you need to check the fusebox lid.
    tundra3400 likes this.
  9. #9
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,162
    Liked
    194 times
    Images
    27
    Rep Power
    9693
    yes the cover on the fuse box in the engine room should tell you were the fog relay goes.
    CBTMA Member
Posting Permissions
  • You may not post replies
  • You may not edit your posts
