05 Tundra rear axel differential water contamination
+ Reply to Thread
Results 1 to 4 of 4
Like Tree6Likes
  • 4 Post By seanpistol
  • 2 Post By Remmy700P
Thread: 05 Tundra rear axel differential water contamination
  1. #1
    Rookie schoperide is on a distinguished road.
    Join Date
    Nov 2011
    Location
    Truckee
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default 05 Tundra rear axel differential water contamination
    3rd time in about 16 months I have had to take my 2005 Tundra into the dealer to get the driver rear wheel bearing and seals replaced!
    First stock OEM lasted until about 120,000, not bad, no complaints. Dealer replaces it, at a hefty cost I might add.
    6 months later, same issue, making crunching noise, squealing and eventually, causing the ABS light to come. Dealer warranties the repair.
    6 months later - same problem.
    This time they are telling me water is entering the axel house/diff. and contaminating the oil and causing the bearing and seals to go???
    There plan is to extend the vent line to stop the problem. Makes since.
    Catch is, the axel hasn't been submerged under water. I don't have a boat, I don't forge streams. I live where it snows and rains but I wouldn't expect that road slush/rain would be enough to enter the vent and cause this issue and if that is the case, why now and not on first 120k??
    Any one else herd of this???
    I'm thinking they are missing a larger problem here or something?? cracked axe housing or something?
    Thanks for any info regarding.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol has a criminal record for giving away rep points. seanpistol's Avatar
    Join Date
    Feb 2012
    Location
    666, Utah
    Age
    25
    Posts
    379
    Liked
    166 times
    Images
    36
    Rep Power
    8787
    Default Re: 05 Tundra rear axel differential water contamination
    I'm not sure about the wheel bearing but a cracked axle housing would probably stand out due to leaking gear oil. i'd guess that the dealer could be pulling your leg about about water entering the pumpkin. Maybe they just figured out the breather has been clogged the whole time and they are retarded- your axle seals don't have a chance with a gunked up breather. You need to extend the breather to somewhere that it won't get clogged with crap, like up behind the drivers side tail light. The axle doesn't have to be submerged to get clogged with mud, road grime, etc and blow out your axle seals trying to equalize the pressure inside the diff when it heats up.
    save some money and know it's done right by extending the rear diff breather yourself. it will take you about 10 minutes in the driveway. order these two parts online:
    90930-03136 (breather)
    90404-51319 (union)
    buy 7' of 3/8" ID fuel hose from an auto parts store and run it loosely along your brake line with zip ties and up the bedside to behind the drivers tail light. give the hose enough room to stretch when your suspension is stretched.
    01 Tundra 4.7L 4x4 TRD access cab- Camburg uniball UCAs, OME 886 coils, 5100s
    Dynapro ATM 285/75r16 on American Racing Chamber teflon wheels
    electric fans, undercover snorkel, extended breathers, muffler swap, dvd player, remote start
    slow build thread - http://www.expeditionportal.com/foru...ol-s-01-Tundra
  4. #3
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,109
    Liked
    2023 times
    Images
    47
    Rep Power
    121449
    BamZipPow and Highwaylizard like this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  5. #4
    Veteran Member INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind. INDYMAC is a pinnacle in their own mind.
    Join Date
    Feb 2005
    Location
    Texas
    Posts
    583
    Liked
    42 times
    Images
    7
    Rep Power
    2080
    Did you do a used oil analysis to see if there actually is water contamination? Or are you just taking the dealership's word for it?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
