Clunk in under driverside floor board when turning left?!
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Like Tree12Likes
Thread: Clunk in under driverside floor board when turning left?!
  1. #1
    Lurking Member dloney's Avatar
    Join Date
    Jan 2013
    Location
    Enumclaw
    Posts
    37
    Liked
    3 times
    Thanks
    0
    Images
    1
    Rep Power
    3
    Default Clunk in under driverside floor board when turning left?!
    Hi Guys,
    This is my first post and I'm excited to be apart of this group. I picked up an 02 Tundra SR5 V8 4x4 with 114k on it last week. Since then I've noticed that when turning left at a slow rate of speed say into a parking lot, if there is an incline that I hit while turning I hear a fairly loud clunk under my feet. I can feel it too. It only seems to happen when turning left, going slow and hitting a bump or incline. I have not a clue in the world what it is but the noise makes me concerned. Anyone have any ideas? Would love some feedback
    Thanks!!
    Dave
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,422
    Liked
    2013 times
    Thanks
    0
    Images
    26
    Rep Power
    65979
    Default Re: Clunk in under driverside floor board when turning left?!
    Go Hawks!
    Sway bar or end link bushings, transmission mount?
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Search for your answer.
    http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  4. #3
    Supporter kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    44
    Posts
    2,697
    Liked
    807 times
    Thanks
    0
    Images
    27
    Rep Power
    231947
    Check the leaf springs and rear shocks too. It's amazing how sound travels in vehicle. Something you swear is coming from the front ends up being in back.
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  5. #4
    Join Date
    Dec 2012
    Location
    leesburg
    Posts
    69
    Liked
    11 times
    Thanks
    0
    Rep Power
    20
    that is low miles. what did u pay for it-if i may ask.
    make sure the timing belt has been done -pronto!
    very important!!
  6. #5
    Junior Member Bradthetech's Avatar
    Join Date
    Mar 2012
    Location
    Arlington, OH
    Posts
    57
    Liked
    28 times
    Thanks
    0
    Images
    5
    Rep Power
    4
    For starters crawl under the drivers side or crank the wheel far right to look under. Check to make sure the stabilizier links are attached on both ends. These are the bars that attach the stabilizer bar to each side. If you are missing one, it could make a popping sound while turning. Check the CV boot just behind the wheel for tears or leaking grease. If it is torn, the grease may be gone and it would make noise. These are prob the most common problems for you to check. Either way, check Rockauto.com for the new parts. You can google a discount code for them as well. Good Luck!
  7. #6
    Junior Member yotabangin's Avatar
    Join Date
    Jun 2012
    Location
    Round Rock, TX
    Posts
    157
    Liked
    40 times
    Thanks
    0
    Images
    3
    Rep Power
    871
    any suspension mods to the truck? sometimes upper ball joints can make clunks or pops, along with what everything else people said. tranny mounts, shock mounts, sway bar, diagnosing clunks and noises can be pretty tough sometimes. Most people here have had one at sometime and most have all been something different. I know mine was upper ball joints. I also had a spacer lift in that could have been the culprit as well.
    CoachRon likes this.
    2003 Access cab step side / bilsteins all the way around / OME 886 springs / camburg UCA and uniballs / removed sway bar / toytec AAL in the rear with 2 inch blocks and hellwig 1250 helpers / toytec 3 degree shims / streetacos carrier bearing drop 2 1/4inch / Pro Comp alloys 16x8 and firestone destination all terrains 285/75/r16 / Alpine type R 12' sub and deck
  8. #7
    Join Date
    Jan 2013
    Location
    Enumclaw
    Posts
    37
    Liked
    3 times
    Thanks
    0
    Images
    1
    Rep Power
    3
    Thread Starter
    Man you guys rock! I just checked this thread and numerous responses, I appreciate it. As far as I know the truck is still stock. It has slightly larger tires then stock that look brand new (BF Goodrich ATs) but as far as I know, there were no mods completed to the suspension. I did just hear back from the seller and he let me know the timing belt hasn't been done so I will get on that ASAP.
    @bigjeffie. I paid $11,500 for the truck and did a lot of research ahead of time. I'll upload an image shortly.
    I really appreciate your responses everyone and I'll take a look at each of the suggestions.
    Highwaylizard and tundra3400 like this.
  9. #8
    Junior Member wunderwhatnow's Avatar
    Join Date
    Apr 2012
    Location
    Florida
    Posts
    469
    Liked
    88 times
    Thanks
    0
    Rep Power
    8706
    My truck has a pop to it same thing backing outta a driveway on incline or whenever I turn hard. I took my truck to toyota to have them look at it the said everything looked good by my lower control arms were loose said and alignment would fix r up and even after the alignment my truck still pulled and damn sure still pops. I guess one day soon ill crawl under my tundra and take a long nap under there and maybe an idea of what it is will come to me. Till then im stumped hope you have better results. Let us know what you find.
  10. #9
    Supporter UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    930
    Liked
    752 times
    Thanks
    0
    Rep Power
    52957
    There are a lot of us that have a mysterious pop when driving over uneven terrain, myself included. I have a lift in my shop and have looked for this clunk to no end. There is a super long thread about this somewhere in here with no real resolve of the noise. Don't know if this is the same noise you are hearing but just wanted to put it out there that many of us have a similar clunk. If everything checks out you might just be joining that club.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, Pacesetter longtube headers, stock cats, Magnaflow 12586's (No CEL's!).
    http://thebrakedoctor.com
    http://uptrailerandhitch.com
  11. #10
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,583
    Liked
    994 times
    Thanks
    0
    Images
    38
    Rep Power
    44364
    i developed this same clunking after i had the frame replaced. i does it on a sharp low speed u turn when the truck meets to different heights in the road surface or when pulling in or out of the drive way, but will randomly do it. i cant replicate it when i want to hear it. it can be heard very loudly from the outside of the vehicle but ive only heard it once. sounds like meta hitting metal. i think its either the trans mount or a front diff mount or a rack mount. it is possible that its the sway bar end links but mine are brand new since the frame replacement but might as well check them anyway.
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 214,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s
    CBTMA Member
    Sometime in the Future:
    3" LED flood cubes, 4" LED hyperspot Pods
  12. #11
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,052
    Liked
    785 times
    Thanks
    0
    Images
    14
    Rep Power
    40847
    don't trip. mine makes all kind of pops and clanks too. just get in and drive it til it breaks then you'll know what it was.
    SuckersWalk likes this.
    All you Baja lovers check out: http://www.MasOlas.com
  13. #12
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,583
    Liked
    994 times
    Thanks
    0
    Images
    38
    Rep Power
    44364
    Quote Originally Posted by 2003bajatundra4x4ac View Post
    you sound exactly like me. ill worry about them but if i can see the actual problem ill just wait it out until if fails, breaks, falls off and then i deal with it.
    CBTMA Member
  14. #13
    Junior Member jthemmer's Avatar
    Join Date
    Nov 2011
    Location
    Polk City, IA
    Posts
    51
    Liked
    5 times
    Thanks
    0
    Rep Power
    4
    I have the pop too in my 2000. Just had the frame done about 2k miles ago and I wonder if that has something to do with it, like something didnt get tightened up all the way?
  15. #14
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,583
    Liked
    994 times
    Thanks
    0
    Images
    38
    Rep Power
    44364
    Quote Originally Posted by jthemmer View Post
    or something that was rusted solid, was then broken free and now it hangs up due to the rust and crud on it.
    CBTMA Member
  16. #15
    Junior Member jm.hammond's Avatar
    Join Date
    Dec 2010
    Location
    Fort Collins
    Posts
    101
    Liked
    13 times
    Thanks
    0
    Rep Power
    846
    This is perfect timing. I have a 2001 Tundra with 45,000 miles on it. I have the same noise turning left as well. I had taken it to the dealership several times and they could never figure it out. I finally got under the truck and noticed that the sway bar link bushings were completely gone. I got some for like 10 bucks at my local part store and maybe 30 min of my time. Hope that fixes your issue. Welcome to the site by the way.
    2001 TRD Limited, 3" Maganflow exhaust, AFE Stage 2 CAI, JBA Headers, Resonator Delete, Toytec Bilstein 5100 coilovers, Kartek CV Boots, Camburg UCAs, 2" AAL, 285/75/16 BFG Mudders, Spidertrax Wheel Spacers, Goodyear Gatorback belt, 20% window tint, Uniden Bearcat CB, Pioneer AVH-P4300 DVD Deck, Scangauge II, Break Conversion, Fluid Film Frame Protection, Camo truck balls.
    Thanks to Extreme 4X4 Offroad in Fort Collins, CO.
    Thanks to Muffler Masters in Colorado Springs, CO.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
