Looking to put on mcthomson baja's 36's. want to install rough country 5" lift & 3" body lift. Picking out rims is one thing but, what size & back space is needed. Is there anything else needed, please help.
what uca and lca will you be using?
2005 Tundra DC Limited 4wd - Phantom Gray Pearl
Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
It seems like a bad idea to base your wants around a tire, but if that's the path you seek, you'll need to disclose what width/height the tire is. If the tire is under 12" wide, you can probably get away with a wheel 8" wide with 4" backspacing, if the tire is wider than 12" you'll need at least 3.5" backspacing. You wont need aftermarket arms if you get the right backspacing since the TC lift keeps the upper arm angle proper.
Your truck is gonna hate spinning those tires. Bigger tires, bigger problems.
Uca = upper control arm
Lca = lower control arm
Jason
It's got 4 wheels with a bed and it starts every time I turn the key.
If You seek advice, then LISTEN with your EARS not your MOUTH.....
Set aside some extra cash for a re-gear.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." - Albert Einstein
I don't entirely know what OCD is, but I know it's very fashionable to accuse people of having it if they try and do something properly. -James May
You're in over your head. Leave it alone until you learn more.
2002 Tundra V8 SR5 2WD AC
1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
* * * I highly recommend Auto-Rx for your engine and transmission. * * *
* * * O2 Sensor Replacement DIY * * *
Surely don't listen to anyone on this forum.....
Jason
What does the rough country website say? They specify what size and offset rims they recommend. It'll look sweet. Post pics!
Sent from AutoGuide.com App
2004 Sequoia Limited
2012 Sequoia SR5
Yeh, tech support says " who I purchase the rims from will tell me the size & offset". I appreciate the inputs & questions which requires another thought/question from me. The comment of putting money aside for rear gears. Will heel that warning but, what's the problem? I was hoping when coming here , that someone would have lifted an "05" to this xtent.
hoping and reality are usually two different things. do a search here for 5" lifts, 6" lifts, and body lifts. you need to read all that you can and understand what you are dealing with so you know what questions to ask. there aren't many lift-consultants here that work for free; though some do work for peanuts. seriously bro, hit up the search feature and you will learn a ton.
i have an 06, the trade off of doing a bracket lift instead of a spacer lift/shock lift etc is just that you can fit 35" tires under it. we 33s under my truck, i just wasnt happy. to me the truck looked stock as hell with the 33s and thats not what i wanted. so after years of running my spacer lift i bought a RCD. ive been very happy with it and my truck looks lifted. ive had it a year. about the only thing i dont like about it is the bumpsteer i get.
i fit 35s with room to grow under my truck. personally id like to find some 35X14.5 but they dont offer many in 16" wheels and the ones offered i wouldnt put under my truck. with the addition of the cool brotruck 17s and above is the norm now a days. the bigger the wheel the more expensive the tire.
