help with Bilstein 5100 and ready lift level kit
+ Reply to Thread
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 58
Like Tree15Likes
Thread: help with Bilstein 5100 and ready lift level kit
  1. #1
    Junior Member krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84 has done just about everything...and then some. krprice84's Avatar
    Join Date
    Aug 2012
    Location
    Calgary, Alberta, Canada
    Posts
    148
    Liked
    22 times
    Rep Power
    1037
    Default help with Bilstein 5100 and ready lift level kit
    So I need some advice here please. First some background, I needed new front shocks on my 02 tundra, so I got the Bilstein 5100 that are height adjustable. Went to put the springs on the shocks and found that there was no chance in hell I could compress the springs far enough to get to the 2 inch lift position. This made me wonder though, how does raising up the bottom of the spring make the truck lifted? It should just compress the spring more, shouldn't it? Or do these shocks somehow adjust their height depending on the static spring force? Something seems odd here....
    Anyways, I decided screw it I will just install the shocks at stock ride height and put the level kit in that I had bought a while ago instead of u using the adjustable ride height feature. So much for selling t the level kit.....
    So I put the spacers on, and now I find there is absolutely no chance in hell that the shocks will fit into the truck. No matter how much I push with a crowbar pushing down on her upper or lower control arm, can I get e enough space.... What the heel? Can someone please give me some advice I'm about to just lose it. Ben working at this all day and am just pissed right off now.
    Thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,619
    Liked
    835 times
    Images
    24
    Rep Power
    20864
    Default Re: help with Bilstein 5100 and ready lift level kit
    you are doing it wrong. yank that level kit back off and only use the 5100s. did you find the step-by-step tutorial using the search feature?
    Remmy700P likes this.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  4. #3
    Veteran Member CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon is almost part of the TundraSolutions family. CoachRon's Avatar
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    23
    Posts
    560
    Liked
    61 times
    Images
    26
    Rep Power
    5420
    I'm going to make this short. You can research the details yourself if you want.
    Take the "leveling kit" off the top of the 5100s. The whole point of the 5100s is to eliminate the need for a "spacer lift", and using both is stupid/pointless. The spacers can be dangerous depending on what size they are, especially if the 5100s are set to anything other than stock height (with the spacers on there). The 5100s use the spring to lift the truck (don't worry about why/how, it just does). The 5100s are going to be a little hard to squeeze in there, but are designed to work without damaging the truck (if your springs won't compress, try harder). Don't feel comfortable with that? Buy uni-ball UCAs or put the spring perch on the 3rd notch instead of the 4th or 5th.
    If you have a 4WD, use the diff drop and save yourself from future problems.
    There is a market for spacers, it's called the trash can. If you want to sell them to somebody who doesn't know better, try Craigslist or Ebay.
    SuckersWalk and tundra3400 like this.
    2000 Tundra SR5 2WD... Camburg UCAs, Camburg 2.5" coil-overs, Deaver 10-packs, Bilstein 5100s, Moog LBJs, BFG A/T 285/75/16s, TRD bead-lock wheels, K&N air filter, 18" MagnaFlow muffler, clear corners, Sylvania fog/headlights, full LED conversion, Kenwood head unit & 6-3/4" 3-way speakers, Sound Ordnance B-8PT 8" subwoofer, Coverking neoprene seat covers... so far...
  5. #4
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2013 times
    Images
    47
    Rep Power
    120525
    You need someone with a wall- or floor-mount coil compressor. The cheapo rented ones from Vatozone are made for automobile coils and are not up to the task of compressing truck coils. Trying it with those is unduly dangerous.
    SuckersWalk likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 0W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  6. #5
    Join Date
    Aug 2012
    Location
    Posts
    148
    Liked
    22 times
    Rep Power
    1037
    Thread Starter
    Thanks for the responses sho far, this place is a great wealth of knowledgeable people!
    So where I am at now is I have the shocks on the truck with no spacers, with the ring set at the stock ride height. My issue here is, at the stock spring height, my truck front end is now raised up from what it was at before. It used to have a slight slight rake to it, now the front end is noticeable higher than the back.when parked on a level road you can see the tilt on the box....I'd say it went up about two inches or so. Any idea why? The stock shocks where the blue and yellow Bilstein ones, but I suspect they may not be the original. The truck has 275k on it and I noticed that the springs had been sprayed black (I could see over spray on the shock body so I know they were s sprayed. Possible that they are stiffer and thus the front end is higher from that? That still would not make sense to me because that should have still been the case with the old ones. I do know that the lower bushing was so worn out that it was at least 3/8 inch up from being in the centre of the mount.....maybe that plus the added height of the New shocks caused the height change?
    Also, when I was putting the spring on these shocks I found that there was absolutely no way I could compress it enough to get anywhere past about the middle setting.....even on the second from bottom setting the coils were so tight that I had to wack the spring compressor hooks out with a hammer
    Everyone else deal with this much hassle? Or does it look like my springs may not be stock?
    Also can anyone link me to the step by step for these? I can't seem to find it, I can only find the newer truck step by step and then just a bunch of help me or question threads but nothing that is a step by step tutorial
    Thanks so much again everyone!
  7. #6
    Veteran Member kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes. kanaduh comes in many shapes and sizes.
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    770
    Liked
    85 times
    Images
    48
    Rep Power
    4291
    krprice84, do you have the top plate on upside down? Check the instructions that came with the 5100's. There have been others who have done it, so don't feel bad if it is. This may help. You can also do a search "5100 install" for more results. Don't forget the alignment when you are done. Get DJ's specs from the DIY section. Good Luck, and Welcome to the Forum. Pictures are required when you are done.
    DIY: Installing Bilstein 5100's on the front of the Tundra
    Help with Bilstein 5100 install
  8. #7
    Join Date
    Aug 2012
    Location
    Posts
    148
    Liked
    22 times
    Rep Power
    1037
    Thread Starter
    I am pretty sure I do not have the top plate on upside down, but what plate is it that you are talking about? the little steel washer looking things are facing so that the cupped side is facing towards the plate with the 3 studs, and the rubber compressable bushing-type things are on the inside (on the cupped side) of each, with the little ridged part going right against the 3 studded plate. the 3 stud plate is in the middle of this sandwich, with the bolt on the top...
    i'm just boggled by how tight that spring has to be compressed to make it on there, i mean if i wanted to put the height adjusting ring on anything but 1 up from stock, almost all of the coils are damn near touching each other, and i actually had to use two sets of spring compressors rented from autoValue, they are the ones with the machined blocks with the hook piece and the large threaded rod between, to compress the hooked pieces together. i dunno but i'm just amazed with how much effort it took to even get to the stock position.
    a secondary question... i've seen sites suggest that the rear 5100 are height adjustable too... how can that be so? i just ordered a pair for the rear but i'm wondering if they really are height adjustable, or will i need a set of blocks to level out my ride now that the front is up higher than the rear?
    Quote Originally Posted by kanaduh View Post
  9. #8
    Join Date
    Aug 2012
    Location
    Posts
    148
    Liked
    22 times
    Rep Power
    1037
    Thread Starter
    SON OF A *****!!!!!
    I just realized what i did wrong.... i put the spring retainers on the bottom... UPSIDE DOWN!!!
    I'm going to take some pics of this, because if i'm going to pull it all apart again and fix it, i sure as hell better have some pics to show off my stupidness!!!
  10. #9
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    770
    Liked
    85 times
    Images
    48
    Rep Power
    4291
    krprice84, I'm sure that it's been done before, and I'm sure it will be done again by others. We can't wait to see pics. Bilstein install directions. Bilstein Instructions.pdf
  11. #10
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,101
    Liked
    2013 times
    Images
    47
    Rep Power
    120525
    It's easy to put the lower spring perch on upside down if you aren't careful. Sounds like that's what happened. No big deal; you caught it in time. There have been those who have headed down the road with it like that and then have the entire assembly collapse causing all kinds of havoc.
    The spring perch rides over and encapsulates the c-clip. See attached.
    Attached Thumbnails Attached Thumbnails help with Bilstein 5100 and ready lift level kit-bilstein-5100-spring-perch-settings.jpg
  12. #11
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,619
    Liked
    835 times
    Images
    24
    Rep Power
    20864
    Quote Originally Posted by krprice84 View Post
    SON OF A *****!!!!!
    glad you figured it out. those "ah ****" moments can be priceless.
  13. #12
    Join Date
    Aug 2012
    Location
    Posts
    148
    Liked
    22 times
    Rep Power
    1037
    Thread Starter
    lol this was an example of one of those who has headed down the road like this, though the whole thing did not collapse, thank god!!!
    when i put it together last night, i tried to compress the spring again when it was all together, so i could move it up one notch or two, from stock, and i guess when the spring force was not totally even on the clip, it actually popped it down a hair, thank god the compressor caught the spring or it would have blown it right down and into my man-parts :O
    i ended up driving with it on stock height, though upside down, to and from work, out on lunch to get some materials for the site, back home, realized what i had done after i got home, but still had to pick up my daughter and grab a good spring compressor.... that was a scary drive once i realized what i did!!!! :O
    but i did make it back, and when i had a decent compressor it all went like butter, one hour per side or so, and i threw on the diff drops from my spacer kit because i noticed today (after just driving today) that my cv boots were starting to throw a little grease...one side threw a fair bit
    does this mean i need to start screwing with cv boots or joints, or now that i have the drop spacers on the diff should it be ok? can i replace the grease somehow with minimal work, or do i have to pull the whole shebang apart??
    thanks for all the help
    oh and about pics... my daughter was harrassing me to come play with her, so i rushed the first side so i could play, then i had to get the second side done before 11pm when i can't run a compressor any longer... so sorry guys, i totally forgot to take pics in the rush! but you can imagine how dumb it looked!!! the clips were starting to bend outwards a hair, so i'm very thankful that they didn't blow apart!
    thanks again for all the help and suggestions, great bunch of guys on here
    Quote Originally Posted by Remmy700P View Post
  14. #13
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,619
    Liked
    835 times
    Images
    24
    Rep Power
    20864
    do the "cv boot mod", even if you don't end up going with the diff-drop. don't forget about a good alignment using "DJ's alignment specs".
  15. #14
    Join Date
    Dec 2009
    Location
    Plant City, FL
    Age
    23
    Posts
    560
    Liked
    61 times
    Images
    26
    Rep Power
    5420
    Glad you got it figured out!
    Also, the rear 5100s are not height adjustable. They can accommodate up to a 1" rear lift, whether it's from an add-a-leaf or a block. Rear shocks do not add lift.
  16. #15
    Join Date
    Aug 2012
    Location
    Posts
    148
    Liked
    22 times
    Rep Power
    1037
    Thread Starter
    So does this mean that I can not use a 1.5 inch add a leaf or block set? I am pretty certain I have seen other members doing just that or Ann I mistaken?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
