Intermittent starting problem
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree8Likes
Thread: Intermittent starting problem
  1. #1
    Junior Member natemoore's Avatar
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Default Intermittent starting problem
    Once every week or two, when I attempt to start my truck, I'll turn the key to the start position, but the engine will not turn over. All the dash lights illuminate, but nothing but silence under the hood. I'll return the key to the off position, then try it again. Nothing, not even the click of the starter solenoid. Then, usually, on the third try, it will fire off strongly as if nothing were amiss.
    I suspected the battery (last one failed after about a year), so I took the truck back to Wal-Mart, and they performed a complete system check, the one where they have you turn on your high beams and blower motor. No problems were noted.
    I've read the manual and know there are a list of possible causes including the starter relay, starter solenoid, starter motor, lock-out switch, ignition switch, corroded terminals, etc, but you know how hard intermittent problems to troubleshoot. I could go through the troubleshooting procedures and everything could be fine on that particular day.
    Yesterday morning, I had to do the start-off-start-off-start thing before it fired up, but this morning, first try.
    Any ideas on the most likely culprit?
    My Tundra is a 2000 SR5 Access Cab V-8.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member silverdouble's Avatar
    Join Date
    Jun 2004
    Location
    NJ
    Posts
    129
    Liked
    21 times
    Rep Power
    449
    Default Re: Intermittent starting problem
    I suspect a starter solenoid do the lights go dim when you are trying to start it. The placement of the starter makes it very hard to trouble shoot.
    1986 Toyota Dlx Pickup 4x4 7" Lift 35x15 5:29 Gears Posi (First Yoda) Sold
    1989 Toyota Dlx Pickup 4x4 3" Lift 33x12 Sold
    2000 Tundra Access Cab 4x4 Sold
    2004 Tundra Double Cab 4x4 Sold
    2012 Tundra CrewMax 4x4 Current Ride
  4. #3
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    Quote Originally Posted by silverdouble View Post
    Do you mean headlights, or instrument lights? If instrument lights, I haven't notice a dimming.
    2000 Tundra Access Cab 4.7L
    180,000 miles
  5. #4
    Join Date
    Jun 2004
    Location
    NJ
    Posts
    129
    Liked
    21 times
    Rep Power
    449
    Have some one watch the headlights when you are having problem if the lights don't dim then the problem is on the solenoid side of the circuit or the solenoid itself.
  6. #5
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    The problem occurs very infrequently, and I'm usually the last to leave the house during the week, so I'm not sure I'll get that lucky for it to happen randomly on a random Saturday, but I'll try it a few times. Thanks.
    180,000 miles
  7. #6
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,528
    Liked
    959 times
    Images
    38
    Rep Power
    42221
    check and make sure that the wing nut on the battery is clean and tight. make sure the ground is secure and clean. my truck did this and it ended up being the starter contacts. replace the starter with a BRAND NEW one NOT a reman. i put a reman on and it was doing the same thing after 2 weeks. yours is a V8 so did it once and do it right.
    Jonesy likes this.
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 212,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s
    CBTMA Member
    Sometime in the Future:
    Lock-Rite (maybe)
  8. #7
    Veteran Member BamZipPow's Avatar
    Join Date
    Feb 2007
    Location
    College Station, TX
    Posts
    685
    Liked
    58 times
    Images
    5
    Rep Power
    4041
    Could be yer Park/Neutral safety start switch. Is yer transmission indicator lighting up correctly?
    Have you tried starting yer engine in Neutral?
  9. #8
    Join Date
    Sep 2006
    Location
    Germantown, MD
    Posts
    314
    Liked
    39 times
    Images
    1
    Rep Power
    2701
    Next time it doesn't start, tap on the starter relay then try again. Could be as simple as a sticking relay.
    If not that, my next hunches, based on your symptoms, would be a bad ignition switch or starter solenoid.
    Jerome
    '06 Tundra AC Ltd 4x2 - Phantom Gray
    '89 Porsche 944 Turbo (track car / wallet deflator)
  10. #9
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    Quote Originally Posted by tundra3400 View Post
    I cleaned the battery contacts the first time it happened. Haven't even found the starter yet. They've got it hidden pretty well.
    Jonesy likes this.
    180,000 miles
  11. #10
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    Quote Originally Posted by BamZipPow View Post
    The trans indicator lights work like they should, although the "D" bulb is burnt out...either that or it never had one. Can't recall. I did put it in neutral one time after the problem occurred, and it did start, but that doesn't really prove anything because it probably would have started on the second try in "park" anyway. If it weren't intermittent it'd be so much easier to troubleshoot.
    180,000 miles
  12. #11
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    Quote Originally Posted by p-car-tower View Post
    I hate throwing money at a problem by replacing parts willie-nillie, but I may go ahead and replace the starter relay just to eliminate that as the source. Probably an inexpensive part and it's really easy to get to, after I check the terminals on the starter, of course.
    I also understand that there is an adjustment for the park/neutral safety switch that might need adjustment. Come to think of it, if I were to try to start the truck in reverse or drive, I'd get the exact same result as when the problem occurs in park.
    180,000 miles
  13. #12
    Join Date
    Feb 2007
    Location
    College Station, TX
    Posts
    685
    Liked
    58 times
    Images
    5
    Rep Power
    4041
    Quote Originally Posted by natemoore View Post
    In case you want to pull the switch apart to clean it...the switch will be very similar although it will be different on how it's bolted to yer transmission compared to the front wheel drive Camry.
    DIY: Neutral Safety Switch Cleaning - Toyota Nation Forum : Toyota Car and Truck Forums
  14. #13
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    Although I've done nothing as far as troubleshooting, except for what I mentioned in my first post, it's been almost two weeks and nary a problem from my starting system. Know what that means? I'll back burner it until it starts happening again.
    tundra3400 likes this.
    180,000 miles
  15. #14
    Join Date
    Nov 2007
    Location
    Pensacola, FL
    Posts
    336
    Liked
    217 times
    Rep Power
    9256
    Thread Starter
    Happened again a couple of times the day before yesterday. So that's almost three months of trouble-free starting. Didn't do it at all yesterday. I think it has to do with Mercury's orbit and the way I'm holding my mouth when I turn the key.
    180,000 miles
  16. #15
    Veteran Member Antipas's Avatar
    Join Date
    Jan 2013
    Location
    Miami, FL
    Posts
    614
    Liked
    171 times
    Rep Power
    2012
    Sounds like the starter to me. Get ready to replace it. I've changed my starter twice: once at about 140,000 miles, and just recently at 290,000 miles.
    You'll need to buy new intake manifold gaskets (for about $65), and since you're taking off the intake manifold and consequently the eight fuel injectors, it's a fine idea to buy new fuel injector seals (they come in a kit) for about $25.
    Have fun changing that starter. Without ratcheting wrenches and swiveling ratchets, you'll be cussing and fighting it the entire way.
    Jonesy likes this.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
