Help! Drum will only go about 80% off of the hub
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree7Likes
Thread: Help! Drum will only go about 80% off of the hub
  1. #1
    Lurking Member troutman561 is on a distinguished road.
    Join Date
    Jan 2008
    Location
    Palm Beach Gardens
    Posts
    29
    Liked
    1 times
    Rep Power
    6
    Default Help! Drum will only go about 80% off of the hub
    So after much research I decided to tackle my drum brakes on my 01. I made the mistake of letting them get down to the metal grinding sound point. I am assuming the shoe is probably stuck to the drum or something like this. The truck moved fine before this issue. What am I missing. It is stuck where its at and wont go back on or off. Whats the next step? Can I access the adjuster from the back? if so, where is the hole to access? I looked but didn't see anything promising.
  2. #2
    Here for the long haul!!!! navytoy82 will become famous soon enough. navytoy82 will become famous soon enough. navytoy82 will become famous soon enough. navytoy82 will become famous soon enough. navytoy82 will become famous soon enough. navytoy82 will become famous soon enough. navytoy82's Avatar
    Join Date
    Jan 2007
    Location
    Silverdale, WA
    Posts
    131
    Liked
    3 times
    Images
    9
    Rep Power
    10
    Default Re: Help! Drum will only go about 80% off of the hub
    I know on my 06 theres 2 threaded holes just screw the right size bolt in there a little at a time and it should pull the drums off.
    2006 Tundra XSP DC, 4WD, 3" ToyTec Lift, Hellwig Rear Anti-Sway Bar, Camburg UCA, 33" NITTO Tera Grapplers, FloPro Custom Exhaust, Fitch Fuel Catalyst, N-Fab Nerf Steps.
  3. #3
    Senior Contributor Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P wants you off his porch. Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,173
    Liked
    2091 times
    Images
    47
    Rep Power
    126643
    The problem is that the shoes have probably ground a groove in the drum surface and the groove is deep enough to prevent the drums from sliding off absent the shoes being retracted.
    The solution is to back off the star adjuster. See attached.
    Attached Thumbnails Attached Thumbnails Help! Drum will only go about 80% off of the hub-drum-brake-star-adjuster-back-off
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads are JUNK!
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * I highly recommend Auto-Rx for your engine and transmission. * * *
    * * * O2 Sensor Replacement DIY * * *
  4. #4
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,480
    Liked
    1379 times
    Blog Entries
    78
    Images
    65
    Rep Power
    183163
    May sound stupid but do you have the parking brake set? First time I went to replace mine I had mistakenly set the parking brake.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  5. #5
    Join Date
    Jan 2008
    Location
    Palm Beach Gardens
    Posts
    29
    Liked
    1 times
    Rep Power
    6
    Thread Starter
    Quote Originally Posted by Remmy700P View Post
    Which leads me to my next question: Where is this access? Is it one of those 2 round bolt looking deals at the bottom of the backing plate?
    Navy, The bolt thing got me to this point
    And yes, the parking brake is off
  6. #6
    Veteran Member kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family. kanaduh is almost part of the TundraSolutions family.
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    783
    Liked
    92 times
    Images
    48
    Rep Power
    5844
    Bolt thread size is M8-1.25. have you checked to make sure that your bell cranks are not stuck? E-Brake may be off, but if the cranks are stuck, it is still engaged.
    Highwaylizard likes this.
  7. #7
    Rookie bfrench116 is on a distinguished road.
    Join Date
    Mar 2012
    Location
    Maine
    Posts
    16
    Liked
    7 times
    Rep Power
    0
    If you are unable to locate the adjuster and are replacing the drums anyway I would break the drum. What I do when replacing drums if they won't come off I take my Snap On hammer and hit the drum with the ball peen side and it will usually brake them into pieces. Give it a few good swings and it should break or at least split which will relieve the tension.
  8. #8
    Join Date
    Jan 2008
    Location
    Palm Beach Gardens
    Posts
    29
    Liked
    1 times
    Rep Power
    6
    Thread Starter
    Quote Originally Posted by kanaduh View Post
    I removed the springs from the E brake assembly on the back and was able to move it by hand. I assume that means it isn't stuck?
  9. #9
    Join Date
    Jan 2008
    Location
    Palm Beach Gardens
    Posts
    29
    Liked
    1 times
    Rep Power
    6
    Thread Starter
    I was just able to get back out to the truck before it for too dark. I found the rounded rectangular rubber deal right below where the brake cable goes into the top of the backing plate. If that where I can find the adjuster? Not enough light to see it but its the only thing that would make sense..
  10. #10
    Veteran Member Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue has mentally logged off-topic. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,089
    Liked
    305 times
    Images
    1
    Rep Power
    13247
    Yes, that long oval hole with the rubber plug, above the axle, is the adjuster hole. Now the fun begins!...
    Its quite a tedious thing to stick the screwdriver in there blindly, to push on the locking lever...Once you do push the lever off the star, you need to stick another THIN, WIDE bladed screwdriver, or better, a brake adjusting tool to catch and turn the adjuster wheel...May take quite a few full turns to back off the shoes enough to get them past the edge of the drum.
    And yes, if you can move the e-brake adjusting levers, it SHOULD be disengaged.
  11. #11
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Posts
    7,173
    Liked
    2091 times
    Images
    47
    Rep Power
    126643
    Quote Originally Posted by troutman561 View Post
    I was just able to get back out to the truck before it for too dark. I found the rounded rectangular rubber deal right below where the brake cable goes into the top of the backing plate. Is that where I can find the adjuster? Not enough light to see it but its the only thing that would make sense..
    The star adjuster is behind the topmost center access hole, located over the axle, and usually protected by an oval rubber plug.
  12. #12
    Join Date
    Jan 2008
    Location
    Palm Beach Gardens
    Posts
    29
    Liked
    1 times
    Rep Power
    6
    Thread Starter
    Thanks guys. At least I have a direction to go in tomorrow morning. I think I was so frustrated earlier that I didn't even notice the rubber plug when I was looking for something like that. I was ready to cut the drum in half, but that wouldn't be wise. Hopefully it all goes a smoothly as possible, but its definitely not as easy as a front pad change which takes all of 20 minutes. I get to finish this and then tackle the alternator on Tuesday.. Cant wait.
  13. #13
    Supporter kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71 wants you off his porch. kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    42
    Posts
    2,596
    Liked
    622 times
    Images
    27
    Rep Power
    192270
    Yeah, it sucks. What Remmy mentioned is exactly what I would bet is happening. Isn't it nice how you get them to the point where you think they're about to come off...but nope!! Good luck.
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  14. #14
    Junior Member neumannbruce is on a distinguished road.
    Join Date
    Mar 2010
    Location
    Utah
    Posts
    68
    Liked
    8 times
    Rep Power
    4
    I was doing my rear brakes today. One of my drums wouldn't come off, but what I noticed was that there was a ton of rust on the hub. I cleaned it, and sprayed some pb blaster on it and it slid right off. Don't know if that will help you. Also if you buy those 8mm 1.25 bolts, make sure you get them as long as possible.
    I had to call it quits tonight as well. The second NEW wheel cyclinder I installed started squirting fluid from the plunger. The first was from Toyota, the second was from Checker. Toyota's failure shocked me, Checkers didn't (i've had that happen before), but was additional frustration. Tomorrow, I will try the made in china part lottery at Checker - and hopefully I win.
  15. #15
    Junior Member pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind. pxsp is a pinnacle in their own mind.
    Join Date
    Jan 2009
    Location
    SC
    Posts
    193
    Liked
    45 times
    Rep Power
    1349
    Quote Originally Posted by Highwaylizard View Post
    LOL... been there.. done that.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
