Anyone with a double cab switched to higher rear end ratio. results.
+ Reply to Thread
Results 1 to 13 of 13
Like Tree11Likes
  • 2 Post By tundrunk
  • 2 Post By BamZipPow
  • 3 Post By tundrunk
  • 3 Post By skilife
  • 1 Post By tundrunk
Thread: Anyone with a double cab switched to higher rear end ratio. results.
  1. #1
    Rookie oldtech is on a distinguished road.
    Join Date
    Oct 2012
    Location
    los angeles
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default Anyone with a double cab switched to higher rear end ratio. results.
    I have a 2005 tundra double cab. I read somewhere that the double cab has a 390 rear end ratio and the access cab has a 360 ratio. We only pull 2000 lbs occasionally . Would like to hear from anyone who has made the change and did you pick up any mpg. Thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,095
    Liked
    170 times
    Images
    27
    Rep Power
    6284
    Default Re: Anyone with a double cab switched to higher rear end ratio. results.
    well the 2005 DC do come with 390s but the 2005 AC dont come with 360 they come with 376s in the SR5 2WD models. the 4WD and limited models come with 390s. changing up ratios may give you more gas mileage but it will kill power.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 196,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch, 5000K 35 Watt HID Fog Lights
  4. #3
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,371
    Liked
    1294 times
    Blog Entries
    78
    Images
    65
    Rep Power
    175260
    Quote Originally Posted by oldtech View Post
    I went from the stock 4.10 gearing to 3.90, not entirely by choice (but that is a story for another time), and picked up a little mileage. I used to own and operate a landscaping company and tree service and never had a problem pulling trailers anywhere from 3,000 pounds to well over 7,000. I was able to switch the differentials at minimum cost due to the kindness of a couple of members here who sold me theirs at very reasonable cost.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  5. #4
    Senior Contributor tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk wants you off his porch. tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    The only stock ratios I've ever heard of in Tundra's is 3.91 or 4.10, never heard of 3.60 or 3.76...
    T100's came with 4.30 though.
    ZapcoTundra and Highwaylizard like this.
    El que se rie, de sus maldades se acuersa..
    Quote Originally Posted by Highwaylizard View Post
    And on the eighth day the Lizard of the Highway BANNED tundrunk for gloating (a vice)
  6. #5
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,371
    Liked
    1294 times
    Blog Entries
    78
    Images
    65
    Rep Power
    175260
    Quote Originally Posted by tundrunk View Post
    Me too - but then again this is not my department.
  7. #6
    Supporter skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife is almost part of the TundraSolutions family. skilife's Avatar
    Join Date
    Nov 2012
    Location
    Morgantown, WV
    Posts
    186
    Liked
    94 times
    Images
    1
    Rep Power
    7249
    Just so we're clear...
    Going with a "lower" # ie 3.91 like in my '05 DC vs. 4.10, 4.30, would mean less power (because of the ratio) better mileage right? Higher # better power less mileage??? Kind of thinking like a manual transmission, the higher the gear you shift into the less power but better mileage... I guess that's what I thought is the purpose of regearing was when you put on bigger tires... (maybe I can learn something here)
    Oldtech- What are you wanting to do?
  8. #7
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,095
    Liked
    170 times
    Images
    27
    Rep Power
    6284
    and the V6 auto tundra comes with 430s. my tundra has em.
    this site has all the gear ratios for toyota vehicles: Toyota Motor Company Axle Gear Ratios
    CBTMA Member
  9. #8
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,095
    Liked
    170 times
    Images
    27
    Rep Power
    6284
    Quote Originally Posted by skilife View Post
    thats correct skilife.
    CBTMA Member
  10. #9
    Veteran Member BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow has done just about everything...and then some. BamZipPow's Avatar
    Join Date
    Feb 2007
    Location
    League City, TX
    Posts
    646
    Liked
    50 times
    Images
    2
    Rep Power
    982
    Here's a listing of what differential ratios that came with the T-100...on www.car-part.com.
    1993 Toyota T100 (6cyl = 3.0L engine)
    Carrier
    Rear Axle, (6 cyl), 4x2, 1 ton, ABS, AT (4.70 ratio)
    Rear Axle, (6 cyl), 4x2, 1 ton, ABS, MT (4.46 ratio)
    Rear Axle, (6 cyl), 4x2, 1 ton, w/o ABS; AT (4.70 ratio)
    Rear Axle, (6 cyl), 4x2, 1 ton, w/o ABS; MT (4.46 ratio)
    Rear Axle, (6 cyl), 4x2, 1/2 ton, ABS, AT (4.27 ratio)
    Rear Axle, (6 cyl), 4x2, 1/2 ton, ABS, MT (4.08 ratio)
    Rear Axle, (6 cyl), 4x2, 1/2 ton, w/o ABS; AT (4.27 ratio)
    Rear Axle, (6 cyl), 4x2, 1/2 ton, w/o ABS; MT (4.08 ratio)
    Rear Axle, (6 cyl), 4x4, ABS, 4.46 ratio (MT)
    Rear Axle, (6 cyl), 4x4, ABS, 4.70 ratio
    Rear Axle, (6 cyl), 4x4, ABS, 4.90 ratio (AT)
    Rear Axle, (6 cyl), 4x4, w/o ABS; 4.46 ratio (MT)
    Rear Axle, (6 cyl), 4x4, w/o ABS; 4.70 ratio
    Rear Axle, (6 cyl), 4x4, w/o ABS; 4.90 ratio (AT)
    1994 Toyota T100 (6cyl = 3.0L engine)
    Carrier
    Rear Axle, 4 cyl, ABS, 3.62 ratio
    Rear Axle, 4 cyl, ABS, 3.77 ratio
    Rear Axle, 4 cyl, w/o ABS; 3.62 ratio
    Rear Axle, 4 cyl, w/o ABS; 3.77 ratio
    Rear Axle, 6 cyl, 4x2, 1 ton, ABS, AT (4.70 ratio)
    Rear Axle, 6 cyl, 4x2, 1 ton, ABS, MT (4.46 ratio)
    Rear Axle, 6 cyl, 4x2, 1 ton, w/o ABS; AT (4.70 ratio)
    Rear Axle, 6 cyl, 4x2, 1 ton, w/o ABS; MT (4.46 ratio)
    Rear Axle, 6 cyl, 4x2, 1/2 ton, ABS, AT (4.27 ratio)
    Rear Axle, 6 cyl, 4x2, 1/2 ton, ABS, MT (4.08 ratio)
    Rear Axle, 6 cyl, 4x2, 1/2 ton, w/o ABS; AT (4.27 ratio)
    Rear Axle, 6 cyl, 4x2, 1/2 ton, w/o ABS; MT (4.08 ratio)
    Rear Axle, 6 cyl, 4x4, ABS, 4.46 ratio (MT)
    Rear Axle, 6 cyl, 4x4, ABS, 4.70 ratio
    Rear Axle, 6 cyl, 4x4, ABS, 4.90 ratio (AT)
    Rear Axle, 6 cyl, 4x4, w/o ABS; 4.46 ratio (MT)
    Rear Axle, 6 cyl, 4x4, w/o ABS; 4.70 ratio
    Rear Axle, 6 cyl, 4x4, w/o ABS; 4.90 ratio (AT)
    1995 Toyota T100
    Carrier
    Rear Axle, 4 cyl, AT, 3.91 ratio
    Rear Axle, 4 cyl, AT, 4.08 ratio
    Rear Axle, 4 cyl, MT, 3.62 ratio
    Rear Axle, 4 cyl, MT, 3.77 ratio
    Rear Axle, 6 cyl, 4x2, 1 ton (3.91 ratio)
    Rear Axle, 6 cyl, 4x2, 1/2 ton, 3.77 ratio
    Rear Axle, 6 cyl, 4x2, 1/2 ton, 3.91 ratio
    Rear Axle, 6 cyl, 4x4, AT, 4.10 ratio
    Rear Axle, 6 cyl, 4x4, AT, 4.30 ratio
    Rear Axle, 6 cyl, 4x4, MT, 3.91 ratio
    Rear Axle, 6 cyl, 4x4, MT, 4.10 ratio
    1996 Toyota T100
    Carrier
    1997 Toyota T100
    Carrier
    1998 Toyota T100
    Carrier
    This is what they are showing fer the 2005 Tundra...
    2005 Toyota Tundra
    Carrier
    Front Axle, (8 cyl, 3.91 ratio)
    Rear Axle, 6 cyl (3.77 ratio)
    Rear Axle, 8 cyl, 4x2, 3.62 ratio, locking (posi)
    Rear Axle, 8 cyl, 4x2, 3.62 ratio, w/o locking
    Rear Axle, 8 cyl, 4x2, 3.92 ratio, locking (posi)
    Rear Axle, 8 cyl, 4x2, 3.92 ratio, w/o locking
    Rear Axle, 8 cyl, 4x4, (3.91 ratio), locking (posi)
    Rear Axle, 8 cyl, 4x4, (3.91 ratio), w/o locking
    ...and fer the 2004 Tundra.
    2004 Toyota Tundra
    Carrier
    Front Axle, 6 cyl, AT (4.30 ratio)
    Front Axle, 6 cyl, MT (4.10 ratio)
    Front Axle, 8 cyl, 3.91 ratio
    Front Axle, 8 cyl, 4.10 ratio
    Rear Axle, 4x2, 6 cyl (4.08 ratio)
    Rear Axle, 4x4, 6 cyl, AT (4.30 ratio)
    Rear Axle, 4x4, 6 cyl, MT (4.10 ratio)
    Rear Axle, 4x4, 8 cyl, 3.91 ratio, locking (posi)
    Rear Axle, 4x4, 8 cyl, 3.91 ratio, non-locking
    Rear Axle, 4x2, 8 cyl, 3.91 ratio, locking (posi)
    Rear Axle, 4x2, 8 cyl, 3.91 ratio, non-locking
    Rear Axle, 4x2, 8 cyl, 4.08 ratio, Double Cab (4 Dr), locking (posi)
    Rear Axle, 4x2, 8 cyl, 4.08 ratio, Double Cab (4 Dr), w/o locking
    Rear Axle, 4x2, 8 cyl, 4.08 ratio, w/o Double Cab
    Rear Axle, 4x4, 8 cyl, 4.10 ratio, Double Cab (4 Dr), locking (posi)
    Rear Axle, 4x4, 8 cyl, 4.10 ratio, Double Cab (4 Dr), w/o locking
    Rear Axle, 4x4, 8 cyl, 4.10 ratio, w/o Double Cab
    tundrunk and tundra3400 like this.
  11. #10
    Join Date
    Nov 2009
    Location
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    It isn't as simple as that but you are on the right track, the power part is essentially correct. It seems fair to conclude that at any given speed (lets say 60mph) the lower the RPM your motor spins at, the less fuel you will consume. The logic would be that since your motor is spinning less, it is completing less combustion cycles and therefore burning less fuel. The problem with that logic is that your motor doesn't consume the same ratio amount of fuel per combustion cycle at 1500 as it does at 2500. There is a sweet spot for your 4.7L to run at its best efficiency, and depending on several variables (weight, gearing, motor modifications, air temperature, altitude, wind resistance, road grade, etc) the sweet spot will be different for different trucks.
    For example, my truck has 285/75/16 tires, headers/exhaust and carries an extra 200lbs give or take not counting me. When I ran on 3.91 gears, my highway averages were in the 17-18mpg range running around 65-70MPH with an RPM range from 1600-1900. I later went to 4.56 gears and my highway average is up to 19-20mpg range running 65-70MPH with RPMs running between 2200-2400. Sounds counter intuitive right? The secret is that my motor was previously operating at a range where the torque power band wasn't optimal, the term used by hot rodders would be "bogging". It now is in a very good power band and uses less fuel to motivate my truck. I can actually touch on 21-22MPG on longer highway trips now provided the right weather and traffic conditions as long as I stay around 68MPH. That's Highwaylizard territory but with a lot of mods that should be killing my gas mileage, in Toby's defense he does have a larger and heavier truck since he had a 4x4 DC and I have a 2WD AC.
    I don't know enough about the Tundra's ignition system, fuel system or valve operation to understand all of the variables. There are a lot of factors to consider when it comes to fuel efficiency, but in my case the lowered (or numerically raised) gear ratio worked in my favor for operating with more power available and better fuel economy. Lizard has increased fuel economy by going with higher gearing (numerically lower) which I would assume is because he stuck to a more reasonable tire size than I did.
    Thanks for that info Bamzippow, nice to learn something new. Now I'm curious if Tundras with the 3.62 gears were only offered with the 245 tires, those don't seem very common. Points on the way if I'm able to send.
  12. #11
    Join Date
    Nov 2012
    Location
    Morgantown, WV
    Posts
    186
    Liked
    94 times
    Images
    1
    Rep Power
    7249
    Old tech,
    I at some point will be doing 4.56 front/rear in mine. (expensive? YES!!) I'm going up and doing bigger tires so I can't comment now as to how it will affect anything but....
    I wouldn't think you would really need a regear if only towing 2k "occasionally"
    But what's the point in what you really need and what you want?!!!!
    I don't NEED to buy bigger tires, buy and get the diffs removed, rebuilt, and replaced, buy pretty much a whole new suspension for what I WANT but I WANT to.... Because every vehicle I've ever owned has had something done to it...It's fun!
    Great info Drunk! and everyone else!
    DAMN I love this site!
  13. #12
    Join Date
    Nov 2009
    Location
    Posts
    5,212
    Liked
    1129 times
    Images
    216
    Rep Power
    190649
    I don't think I've NEEDED to do anything I've done to my truck, it was all WANT... except my rear end rebuild because that was blown out.
    skilife likes this.
  14. #13
    Lurking Member RingSteel is on a distinguished road.
    Join Date
    Aug 2010
    Location
    Cypress
    Posts
    25
    Liked
    1 times
    Rep Power
    3
    Thanks for the great real-world info!
    Was it difficult to get your speedo re-calibrated to match the new gearing?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
